Mint
2 December 2021 17:00
1
Hi,
I have so far managed to get OpenCL up and running on my GTX 760 graphics card, by simply installing the headers found in the AUR. However I have struggled to find headers (or any setup guide) for intel core cpu’s on an arch based system (I run manjaro xfce). I have an i9 10900kf cpu, and when I run clinfo command in the terminal, I get Number of platforms 1 , and my cpu doesn’t show up, only my GTX graphics card does . Is there any information of how to setup opencl for these cpu’s on manjaro/arch?
Ahoj
opencl-headers are in the community repo as an optional dependency of opencl-nvidia & lib32-opencl-nvidia. You should only need those.
What are you installing from the AUR? If it’s intel-opencl, that’s most likely not applicable as it’s a legacy driver for older Intel graphics chips.
Please post your system info as outlined here:
This tutorial is superseded by this one. Remember all Tutorials are wiki posts that can be edited by TL2 (Trust Level 2) members and above.
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to…
As well as:
pacman -Qs opencl
Mint
3 December 2021 15:15
3
Yeah, I have the nv repos and CL headers installed, and I’ve been using them to make OpenCL work on my graphics card
But what I now want to know is how to setup OpenCL to run on my CPU, instead of graphics card. But I am not sure what is required to set this up on an arch based system like manjaro (i.e. what repos do I need to install to enable this).
FYI this is output of the inxi --admin --verbosity=7 --filter --widthcommand:
Kernel: 5.4.159-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0ca58d64-19a6-42fc-82be-35fc4a0cc153 rw quiet udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Mobo: ASUSTeK model: TUF GAMING B460M-PLUS v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1101
date: 01/15/2021
RAM: total: 31.27 GiB used: 2.29 GiB (7.3%)
Info: 10-Core model: Intel Core i9-10900KF bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 5 microcode: E2
cache: L1: 640 KiB L2: 2.5 MiB L3: 20 MiB bogomips: 148040
Speed: 898 MHz min/max: 800/5300 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Device-1: NVIDIA GK104 [GeForce GTX 760] vendor: Gigabyte driver: nvidia
v: 470.86 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1187
class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 69 s-size: 707x392mm (27.8x15.4")
s-diag: 808mm (31.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 70 size: 698x393mm (27.5x15.5")
diag: 801mm (31.5")
OpenGL: renderer: NVIDIA GeForce GTX 760/PCIe/SSE2 v: 4.6.0 NVIDIA 470.86
direct render: Yes
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:a3f0 class-ID: 0403
Device-2: NVIDIA GK104 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e0a class-ID: 0403
Sound Server-1: ALSA v: k5.4.159-1-MANJARO running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: 3.2.6-k
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d55 class-ID: 0200
Device-2: Realtek RTL8188CUS 802.11n WLAN Adapter type: USB
driver: rtl8192cu bus-ID: 1-6:4 chip-ID: 0bda:8176 class-ID: 0000
serial: <filter>
IF: wlp0s20f0u6 state: up mac: <filter>
Local Storage: total: 465.76 GiB used: 83.35 GiB (17.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 40WD
scheme: GPT
ID-1: / raw-size: 465.47 GiB size: 457.16 GiB (98.22%)
used: 83.35 GiB (18.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 0ca58d64-19a6-42fc-82be-35fc4a0cc153
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: EE8B-3F57
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: Microdia USB DEVICE type: Keyboard,Mouse
power: 100mA chip-ID: 0c45:7697 class-ID: 0301
Device-2: 1-4:3 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s power: 98mA chip-ID: 1bcf:08a0 class-ID: 0301
Device-3: 1-6:4 info: Realtek RTL8188CUS 802.11n WLAN Adapter type: Network
driver: rtl8192cu interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 0bda:8176 class-ID: 0000 serial: <filter>
Hub-2: 1-11:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-11.3:6 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:1939 class-ID: 0300 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 8 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 34 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 20%
Processes: 357 Uptime: 1h 33m wakeups: 3 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1321
lib: 420 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.09
As well as:
pacman -Qs opencl
When I try and run that, I get this:
sudo: invalid option -- 'Q'
usage: sudo -h | -K | -k | -V
usage: sudo -v [-ABknS] [-g group] [-h host] [-p prompt] [-u user]
usage: sudo -l [-ABknS] [-g group] [-h host] [-p prompt] [-U user] [-u user]
[command]
usage: sudo [-ABbEHknPS] [-C num] [-D directory] [-g group] [-h host] [-p
prompt] [-R directory] [-T timeout] [-u user] [VAR=value] [-i|-s]
[<command>]
usage: sudo -e [-ABknS] [-C num] [-D directory] [-g group] [-h host] [-p
prompt] [-R directory] [-T timeout] [-u user] file ...
It appears you would need intel-compute-runtime and should not need anything from the AUR. See GPGPU - ArchWiki
I don’t know what command you ran, but it wasn’t pacman -Qs opencl. Don’t use sudo.
Mint
3 December 2021 18:42
5
Ok thanks for that. My bad, I ran it as sudo, here is the output:
local/clinfo 3.0.21.02.21-1
Simple OpenCL application that enumerates all available platform and device
properties
local/lib32-ocl-icd 2.3.0-1
OpenCL ICD Bindings (32-bit)
local/mingw-w64-opencl-headers 2021.06.30-1 (mingw-w64-vulkan-devel)
OpenCL (Open Computing Language) header files (mingw-w64)
local/mingw-w64-opencl-icd 2021.06.30-1 (mingw-w64-vulkan-devel)
The OpenCL ICD Loader (mingw-w64)
local/ocl-icd 2.3.1-1
OpenCL ICD Bindings
local/opencl-clhpp 2.0.15-1
OpenCL C++ header files
local/opencl-headers 2:2021.04.29-1
local/opencl-nvidia-470xx 470.86-1
OpenCL implemention for NVIDIA
