OpenCL code hangs on clGetPlatformIDs
Hi, after update, OpenCL code hangs on clGetPlatformIDs, clinfo does not work either.
Inxi
  Host: marisa Kernel: 6.2.8-1-MANJARO arch: x86_64 bits: 64
    Desktop: KDE Plasma v: 5.27.3 Distro: Manjaro Linux
  Mobo: ASUSTeK model: TUF GAMING X670E-PLUS WIFI v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 1222
    date: 02/24/2023
  Info: 16-core model: AMD Ryzen 9 7950X bits: 64 type: MT MCP cache:
    L2: 16 MiB
  Speed (MHz): avg: 1091 min/max: 400/6021 cores: 1: 1083 2: 1080 3: 1080
    4: 1080 5: 1080 6: 1080 7: 1080 8: 1100 9: 1080 10: 1080 11: 1080 12: 1080
    13: 1083 14: 1080 15: 1080 16: 1080 17: 1083 18: 1088 19: 1083 20: 1080
    21: 1080 22: 1083 23: 1299 24: 1171 25: 1083 26: 1082 27: 1083 28: 1083
    29: 1080 30: 1080 31: 1082 32: 1080
  Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] driver: amdgpu v: kernel
  Device-2: AMD Raphael driver: amdgpu v: kernel
  Device-3: A4Tech FHD 1080P PC Camera type: USB
    driver: snd-usb-audio,uvcvideo
  Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 23.1.0 driver: X:
    loaded: modesetting dri: radeonsi gpu: amdgpu resolution: 2560x1440~144Hz
  API: OpenGL v: 4.6 Mesa 23.0.1 renderer: AMD Radeon RX 7900 XTX (gfx1100
    LLVM 15.0.7 DRM 3.49 6.2.8-1-MANJARO)
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Same pblm for me. Opencl hang and as a consequence Darktable and libre office can’t start
Uninstalling of intel-oneapi-compiler-shared-runtime and dependencies resolves the issue for me.
