Openbox community edition?
Hi there! I wanted to install the Manjaro Openbox community edition on an old machine, I am using this edition on my laptop since 2018. However, I cannot find the ISO! Has the edition been discontinued? All the best!
you can find the iso on my private domain https://iso.uex.dk - it is no longer a playground for dotnet code
Thank you very much! Greetings from Italy!
I can’t download the iso, sorry. It says:
HTTP Error 404.3 - Not Found
The page you are requesting cannot be served because of the extension configuration. If the page is a script, add a handler. If the file should be downloaded, add a MIME map.
Sorry!
Fixed the download on
https://iso.uex.dk
fantastic hosting company - flip a switch and you are back on linux.
Thank you again! It worked! Ciao!
