"Open Folder" opens VSCode instead of Explorer/Finder
Hey guys,
every time I click on button inside a program that’s labeled like “Open Folder” VSCode is being opened instead of Explorer/Finder.
I’m using Gnome3.
I haven’t found anything useful on Google, unfortunately.
Maybe one of you can help me.
cat ~/.config/mimeapps.list
Check the inode/directory property
It appears to be the culprit, thanks :smiley:
inode/directory=code_code.desktop;
Can you tell me what the Explorer/Finder value is?
I don’t know - you can try with nautilus.desktop as nautilus is the Gnome filemanager.
It’s org.gnome.Nautilus.desktop for the Nautilus file manager.
That works. Thanks :slight_smile:
never going to be easy anymore :slight_smile: - maybe next time I should suggest doing something like this
grep -rl 'nautilus' /usr/share/applications
When I don’t have the said package installed (like in this case), I usually search for the package in the Arch/Packages website.
There the package description page has a nice “Package contents list” feature, where you can see its contents and the .desktop file(s) among them.
It works most of the times, unless it’s a Manjaro specific package. :slightly_smiling_face:
