I have just made:
sudo pacman -Syu
and I can only see one of my external monitors.
With inxi I can’t see it:
Kernel: 6.1.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=4ed2000a-5bfc-46dc-bcf0-eb79e77a5c10 rw apparmor=1
Console: pty pts/1 DM: LightDM v: 1.32.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Dell product: G5 5590 v: N/A serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Dell model: 0D2DM3 v: A00 serial: <filter> UEFI: Dell v: 1.15.3
date: 06/04/2021
ID-1: BAT0 charge: 53.7 Wh (100.0%) condition: 53.7/90.0 Wh (59.7%)
volts: 12.8 min: 11.4 model: BYD DELL 6YV0V94 type: Li-poly serial: <filter>
status: full
System RAM: total: 16 GiB available: 15.44 GiB used: 2.38 GiB (15.4%)
Device-1: DIMM A type: DDR4 detail: synchronous size: 8 GiB
speed: 2667 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
total: 64 manufacturer: 80AD000080AD part-no: HMA81GS6JJR8N-VK
serial: <filter>
Device-2: DIMM B type: DDR4 detail: synchronous size: 8 GiB
serial: <filter>
Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 9 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF4
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4500 base/boost: 4000/4500 scaling:
driver: intel_pstate governor: powersave volts: 1.2 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800
10: 800 11: 800 12: 800 bogomips: 62431
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: DP-1 empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0380
Device-2: NVIDIA TU106BM [GeForce RTX 2070 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 535.129.03 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f50 class-ID: 0300
Device-3: Microdia [] driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0c45:671f class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.9 compositor: xfwm driver: X:
loaded: nvidia gpu: i915 tty: 80x24
Monitor-1: DP-1 model: Philips PHL 272B8Q serial: <filter> built: 2018
res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia inactive: gbm,wayland,x11,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 23.1.9-manjaro1.1
note: console (EGL sourced) renderer: NVIDIA GeForce RTX 2070 with Max-Q
Design/PCIe/SSE2, Mesa Intel UHD Graphics 630 (CFL GT2), llvmpipe (LLVM
16.0.6 256 bits)
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Device-2: NVIDIA TU106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: GN Netcom Jabra EVOLVE Link MS driver: jabra,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.4.2:9
chip-ID: 0b0e:0305 class-ID: 0300 serial: <filter>
API: ALSA v: k6.1.60-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.83 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Realtek vendor: Dell driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:2502
class-ID: 0200
IF: enp60s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
IF-ID-2: virbr0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7
Local Storage: total: 1.88 TiB used: 923.12 GiB (48.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 40.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: Ultra size: 57.91 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 1.00
scheme: MBR
ID-1: / raw-size: 1.44 TiB size: 1.42 TiB (98.36%) used: 923.05 GiB (63.7%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: 4ed2000a-5bfc-46dc-bcf0-eb79e77a5c10
ID-2: /boot/efi raw-size: 650 MiB size: 646 MiB (99.38%)
used: 75.5 MiB (11.7%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: ESP uuid: CC38-90F6
ID-1: swap-1 type: partition size: 16.76 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 2c51a501-7169-4ac2-a1ac-2f497a522193
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 353.29 GiB fs: bitlocker
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB fs: ntfs
label: WINRETOOLS uuid: 668476068475D8CF
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 16.67 GiB fs: ntfs label: Image
uuid: F04E765C4E761B92
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.28 GiB fs: ntfs
label: DELLSUPPORT uuid: 8CCC9559CC953E80
ID-6: /dev/sda1 maj-min: 8:1 size: 57.9 GiB fs: bitlocker label: N/A
uuid: N/A
Hub-2: 1-3:2 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2813
Device-1: 1-3.1:4 info: Lenovo Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 17ef:608d class-ID: 0301
Device-2: 1-3.3:6 info: Lenovo [] type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 17ef:6099 class-ID: 0300
Hub-3: 1-3.4:8 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
Device-1: 1-3.4.2:9 info: GN Netcom Jabra EVOLVE Link MS type: audio,HID
driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
Device-2: 1-5:3 info: Microdia [] type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 0c45:671f class-ID: 0e02
Device-3: 1-9:5 info: Shenzhen Goodix Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 27c6:530c class-ID: ff00
Device-4: 1-14:7 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-4: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
Hub-5: 2-3:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0813
Hub-6: 2-3.4:3 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
Device-1: 2-3.4.4:4 info: SanDisk Ultra Dual type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5590 class-ID: 0806
serial: <filter>
Hub-7: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-9: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-10: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 65.0 C pch: 67.0 C mobo: 59.0 C gpu: nvidia
temp: 54 C
Fan Speeds (rpm): cpu: 2410 fan-1: 2407
Processes: 308 Uptime: 1m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1704
pm: pacman pkgs: 1697 libs: 436 tools: pamac,yay pm: flatpak pkgs: 7
Shell: Bash (su) v: 5.2.15 running-in: pty pts/1 inxi: 3.3.31
