Only one display detected with Wayland after boot
Hello everyone,
I have an issue with using Wayland since one of the last bigger update packs (for a few weeks)
Wayland just detects one of my two displays which are connected via daisy chain, the other one goes into standby mode.
In the login screen, both displays are still perfectly detected.
I’ve been using Wayland without any problems before and had to switch to X11 for now, which is kind of juddery on my device and doesn’t feel very nice.
At least, X11 recognizes both displays perfectly.
With Wayland, both displays are still recognized if I unplug the Displayport cable and plug it in again. Okay as a workaround bot not satisfying.
Does anyone know this problem or can help me to fix it?
I think, it might be caused by the nVidia driver (using a 3060Ti).
WIll be able to access my computer on saturday again to deliver logs and stuff.
Thanks in advance,
rnbob
Welcome to the Manjaro community @rnbob
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Required reading
Resources
