Hi all,
Since today I noticed some site take a really long time to load (if they load at all) and some other are fine :
- Google services are OK
- Facebook OK
- duckduckgo not ok
- manjaro.org not OK
- reddit not OK
The only difference I noticed between these websites is that resolvectl query google.com
will report an ipv4 and ipv6 while resolvectl query duckduckgo.com
will report ipv4 only.
$ inxi -F
System: Host: manjaro-omen Kernel: 5.4.80-2-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.20.4 Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: OMEN by HP Laptop v: Type1ProductConfigId serial: <superuser/root required>
Mobo: HP model: 8259 v: 83.72 serial: <superuser/root required> UEFI: Insyde v: F.50 date: 11/09/2018
Battery: ID-1: BAT0 charge: 49.8 Wh condition: 49.8/49.8 Wh (100%)
CPU: Info: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP L2 cache: 6144 KiB
Speed: 900 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 900 2: 899 3: 900 4: 900
Graphics: Device-1: Intel HD Graphics 630 driver: i915 v: kernel
Device-2: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.10 driver: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.2.3
Audio: Device-1: Intel CM238 HD Audio driver: snd_hda_intel
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.4.80-2-MANJARO
Network: Device-1: Intel Wireless 7265 driver: iwlwifi
IF: wlo1 state: up mac: xxxxxxxxxxx
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8168
IF: eno1 state: down mac: xxxxxxxxxxxx
Drives: Local Storage: total: 1.94 TiB used: 1.10 TiB (57.0%)
ID-1: /dev/sda vendor: A-Data model: IM2S3138E-128GM-B size: 119.24 GiB
ID-2: /dev/sdb vendor: Seagate model: ST2000LM015-2E8174 size: 1.82 TiB
Partition: ID-1: / size: 29.03 GiB used: 22.29 GiB (76.8%) fs: ext4 dev: /dev/sda5
ID-2: /home size: 23.91 GiB used: 20.89 GiB (87.4%) fs: ext4 dev: /dev/sdb1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 50.0 C mobo: N/A
Info: Processes: 206 Uptime: 48m Memory: 7.67 GiB used: 2.63 GiB (34.4%) Shell: Zsh inxi: 3.1.08
The network works well with my android phone.
