I have hybrid-video-card. After first system update, external monitor stopped work.
I have reinstalled video-hybrid-intel-nvidia-prime driver, but it didn’t help. I found on forum solution to enable hdmi monitor:
sudo nvidia-xconfig
sudo cp /etc/X11/xorg.conf /etc/X11/mhwd.d/nvidia.conf
sudo mhwd-gpu --setmod nvidia --setxorg /etc/X11/mhwd.d/nvidia.conf
reboot
And now only hdmi monitor is showing.
inxi --full --admin --verbosity=3 --filter --no-host
Kernel: 5.4.138-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a5943b36-9727-4fe7-bb57-081f9d41ac14 rw quiet splash apparmor=1
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: ASUSTeK product: ROG Strix G531GT_G531GT v: 1.0
serial: <filter>
Mobo: ASUSTeK model: G531GT v: 1.0 serial: <filter>
UEFI: American Megatrends v: G531GT.308 date: 02/01/2021
ID-1: BAT0 charge: 42.6 Wh (100.0%) condition: 42.6/51.3 Wh (83.0%)
volts: 12.5 min: 12.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 12 MiB
bogomips: 62431
Speed: 1001 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 1001 2: 1000
3: 1000 4: 1000 5: 1001 6: 1000 7: 1000 8: 1000 9: 1000 10: 1000 11: 1000
12: 1000
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0300
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5.3:5
chip-ID: 0c76:161f class-ID: 0300
Sound Server-1: ALSA v: k5.4.138-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: down mac: <filter>
vendor: ASUSTeK driver: r8168 v: 8.049.02-NAPI modules: r8169 port: 3000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno2 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 704.24 GiB used: 11.93 GiB (1.7%)
model: PC SN520 SDAPNUW-256G-1002 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 20110000 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-1: / raw-size: 42.45 GiB size: 41.48 GiB (97.73%)
used: 11.72 GiB (28.3%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 507 MiB size: 506 MiB (99.80%)
used: 216 MiB (42.7%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 46.0 C mobo: N/A gpu: nvidia temp: 41 C
Fan Speeds (RPM): cpu: 2900
Processes: 320 Uptime: 28m wakeups: 1 Memory: 15.49 GiB
used: 2.93 GiB (18.9%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1133 lib: 289 flatpak: 0 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.06
sudo mhwd -li ✔
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
video-hybrid-intel-nvidia-prime 2021.07.28 false PCI
video-modesetting 2020.01.13 true PCI
inxi -G ✔
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] driver: nvidia
v: 470.57.02
Display: x11 server: X.org 1.20.13 driver: loaded: nvidia
Fabby
August 14, 2021, 9:55am
#2
This is to be expected for an ASUSTeK product: ROG Strix G531GT_G531GT because it only has electronic wiring from the Intel to the laptop screen and only electronic wiring from the HDMI port to an external screen.
And the solution you applied is for an nVidia-only machine (or a full hybrid that has the nVidia wired up to both the internal screen and HDMI port)
So:
Go to TTY2
revert your change
upgrade to kernel 5.10
remove all display drivers
add the hybrid driver back
Reboot
Thanks for your advice. I did everything, that you said, but problem hasn’t gone.
Only laptop monitor works when i login with gnome.
Only external monitor works when i login with gnome on Xorg
sudo mhwd -li
inxi --full --admin --verbosity=3 --filter --no-host ✔
Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
serial: <filter>
ID-1: BAT0 charge: 41.3 Wh (96.9%) condition: 42.6/51.3 Wh (83.0%)
status: Charging
bogomips: 62431
Speed: 900 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 900 2: 900
3: 900 4: 900 5: 901 6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 899
Type: l1tf
Display: x11 server: X.Org 1.20.13 compositor: gnome-shell driver:
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9")
s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 hz: 144 dpi: 93
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1:2 chip-ID: 0c76:161e
class-ID: 0300
Device-4: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5.3:6
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
vendor: ASUSTeK driver: N/A modules: r8169 port: 3000 bus-ID: 03:00.0
driver: btusb v: 0.8 bus-ID: 1-14:7 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 704.24 GiB used: 16.48 GiB (2.3%)
serial: <filter> rev: 20110000 temp: 34.9 C scheme: GPT
used: 16.27 GiB (39.2%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nvidia temp: 41 C
Fan Speeds (RPM): cpu: 3400
Processes: 285 Uptime: 13m wakeups: 1 Memory: 15.49 GiB
used: 1.66 GiB (10.7%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1204 lib: 293 flatpak: 0
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
cat /etc/X11/mhwd.d/nvidia.conf ✔
## Generated by mhwd - Manjaro Hardware Detection
Fabby
August 15, 2021, 4:18pm
#4
As I’m on KDE and thought you had an nVidia driver issue, I stepped in to help you from a system perspective. As I haven’t run gnome, I can’t help you any further , so I’ve edited your title.
I installed kde and reinstalled hybrid driver, but still have same problem.
I don’t understand, why i have no this problem on clear system, but after first update (with pamac or pacman) it appears.
Fabby
August 17, 2021, 1:33pm
#6
I’m confused: Did you wipe everything, install the KDE ISO and then ran into the same problem after updating?
What did you do exactly ? Please be more specific.
To be able to help you we need to know what state your system is in and as you seem to be new to Manjaro and Linux in general, please read this first:
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the trees for the wood any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&qu…
