I don’t have any issues with other games (Witcher3, Divinity Original Sin2, Civ6).
I run steam via prime-run steam
I have prime-run %command%
enabled in properties.
inxi --full --admin --verbosity=7 --filter --no-host
System: Kernel: 5.12.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64 root=UUID=08a7c60e-d56a-45b2-acdd-71de83c1fe4d ro quiet apparmor=1
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 81FV v: Lenovo Legion Y530-15ICH serial: <filter> Chassis: type: 10
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO v: 8JCN56WW date: 11/30/2020
Battery: ID-1: BAT0 charge: 43.4 Wh (100.0%) condition: 43.4/52.5 Wh (82.7%) volts: 12.6 min: 11.4 model: CPT-COS L17C3PG1
type: Li-poly serial: <filter> status: Full
Memory: RAM: total: 15.51 GiB used: 4.78 GiB (30.8%)
CPU: Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: A (10) microcode: DE cache: L2: 8 MiB bogomips: 36812
Speed: 2223 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 2223 2: 2924 3: 2195 4: 1370 5: 2183 6: 1181 7: 2011
8: 918
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel UHD Graphics 630 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Lenovo driver: nvidia v: 460.73.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo bus-ID: 1-6:3 chip-ID: 13d3:56a6 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: modesetting,nvidia unloaded: intel,nouveau
alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.0.3 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Sound Server-1: ALSA v: k5.12.1-2-MANJARO running: yes
Sound Server-3: JACK v: 0.125.0 running: no
Sound Server-4: PulseAudio v: 14.2 running: yes
Sound Server-5: PipeWire v: 0.3.26 running: no
Network: Device-1: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi v: kernel port: 4000 bus-ID: 07:00.0
chip-ID: 8086:3166 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 3000
bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp8s0 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0a2a
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 1.36 TiB used: 1.08 TiB (79.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 2B2QEXM7 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: LCM2 scheme: MBR
Partition: ID-1: / raw-size: 223.58 GiB size: 219.07 GiB (97.98%) used: 160.02 GiB (73.0%) fs: ext4 dev: /dev/nvme0n1p5
maj-min: 259:5 label: N/A uuid: 08a7c60e-d56a-45b2-acdd-71de83c1fe4d
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.3 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 0227-CDD9
ID-3: /home/<filter>/pCloudDrive raw-size: N/A size: 6 GiB used: 1.71 GiB (28.6%) fs: fuse source: ERR-102
label: N/A uuid: N/A
ID-4: /run/media/ww/9270B63170B61BC3 raw-size: 585.89 GiB size: 585.89 GiB (100.00%) used: 522.36 GiB (89.2%)
fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: N/A uuid: 9270B63170B61BC3
ID-5: /run/media/ww/A03229043228E0D0 raw-size: 233.76 GiB size: 233.76 GiB (100.00%) used: 105.21 GiB (45.0%)
fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A uuid: A03229043228E0D0
ID-6: /run/media/ww/CEB24C78B24C66D5 raw-size: 344.63 GiB size: 344.63 GiB (100.00%) used: 315.88 GiB (91.7%)
fs: ntfs dev: /dev/sda3 maj-min: 8:3 label: N/A uuid: CEB24C78B24C66D5
ID-7: /run/media/ww/EE5C-6E50 raw-size: 1000 MiB size: 996 MiB (99.60%) used: 19.7 MiB (2.0%) fs: vfat
dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: EE5C-6E50
Swap: Alert: No swap data was found.
Unmounted: ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 507 MiB fs: ntfs label: N/A uuid: EC128B74128B4316
ID-3: /dev/nvme0n1p6 maj-min: 259:6 size: 7.81 GiB fs: swap label: N/A uuid: ed51cefb-cc54-45bd-8d45-8eeaefa24c06
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-3:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-6:3 info: IMC Networks Integrated Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 13d3:56a6 class-ID: 0e02 serial: <filter>
Device-3: 1-14:4 info: Intel Bluetooth wireless interface type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 8087:0a2a class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Sensors: System Temperatures: cpu: 55.0 C mobo: N/A
Info: Processes: 265 Uptime: 15m wakeups: 1 Init: systemd v: 247 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0
Packages: pacman: 1469 lib: 429 flatpak: 0 Shell: Bash v: 5.1.4 running-in: yakuake inxi: 3.3.04
mhwd:
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2020.11.30 false PCI
mhwd -l
> 0000:08:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:01:00.0 (0300:10de:1c8c) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-390xx-bumblebee 2020.11.30 false PCI
video-nvidia 2020.11.30 false PCI
video-nvidia-390xx 2020.11.30 false PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:3e9b) Display controller Intel Corporation:
I have to hard reset my laptop.
One thing that I saw in journalctl
was [UFW BLOCK]
, I tried switching firewall off, but the freezes continued.
I’m running dual-boot, and have no issues on Windows.
