I am using the package from the repo, OnionShare version 2.4 which is the latest released version.
Using the default Tor settings (this uses the built in Tor client) starting a private chat gives the following message:
Sorry, this version of Tor doesn’t support stealth (Client Authentication). Please try with a newer version of Tor, or use ‘public’ mode if it doesn’t need to be private.
Testing the connection to the Tor network gives this information:
Connected to the Tor controller.
Tor version: 0.4.6.8
Supports ephemeral onion services: True.
Supports client authentication: False.
Supports next-gen .onion addresses: True.
Possibly related bug report: OnionShare 2.3.2 worked fine, upgraded to 2.3.3 and now repeatedly states cannot connect to Tor · Issue #1403 · onionshare/onionshare · GitHub
Log
$ onionshare -v
│ v2.4 │
│ https://onionshare.org/ │
[nov 23 2021 00:25:19] Settings.__init__
[nov 23 2021 00:25:19] Settings.load
[nov 23 2021 00:25:19] Settings.load: Trying to load /home/USERNAME/.config/onionshare/onionshare.json
[nov 23 2021 00:25:19] Onion.__init__
[nov 23 2021 00:25:19] MainWindow.__init__
[nov 23 2021 00:25:19] TabWidget.__init__
[nov 23 2021 00:25:19] EventHandlerThread.__init__
[nov 23 2021 00:25:19] EventHandlerThread.run
[nov 23 2021 00:25:19] ModeSettings.load: loaded /home/USERNAME/.config/onionshare/persistent/cherisher-sanction-cornbread.json
[nov 23 2021 00:25:19] TabWidget.add_tab: mode_settings: <onionshare_cli.mode_settings.ModeSettings object at 0x7fdce123e670>
[nov 23 2021 00:25:19] Tab.__init__
[nov 23 2021 00:25:19] OnionShare.__init__
[nov 23 2021 00:25:19] TabWidget.tab_changed: Tab was changed to 0
[nov 23 2021 00:25:19] TabWidget.change_persistent: tab_id: 0, is_persistent: True
[nov 23 2021 00:25:19] MainWindow.bring_to_front
[nov 23 2021 00:25:19] TorConnectionDialog.__init__
[nov 23 2021 00:25:19] TorConnectionDialog.start
[nov 23 2021 00:25:19] TorConnectionThread.__init__
[nov 23 2021 00:25:19] TorConnectionThread.run
[nov 23 2021 00:25:19] Onion.connect
[nov 23 2021 00:25:19] Onion.connect: tor_data_directory_name=/home/USERNAME/.config/onionshare/tor_data
[nov 23 2021 00:25:19] Common.get_resource_path: filename=torrc_template
[nov 23 2021 00:25:19] Common.get_resource_path: filename=torrc_template, path=/usr/lib/python3.9/site-packages/onionshare_cli/resources/torrc_template
Connecting to the Tor network: 100% - Done
[nov 23 2021 00:25:21] Onion.connect: Connected to tor 0.4.6.8
[nov 23 2021 00:25:21] TorConnectionDialog._connected_to_tor
[nov 23 2021 00:25:21] OnionShareGui.settings_have_changed
[nov 23 2021 00:25:21] Tab.settings_have_changed
When trying to start the chat:
[nov 23 2021 00:25:52] Tab.chat_mode_clicked
[nov 23 2021 00:25:52] Web.__init__: is_gui=True, mode=chat
[nov 23 2021 00:25:52] Common.get_resource_path: filename=static
[nov 23 2021 00:25:52] Common.get_resource_path: filename=static, path=/usr/lib/python3.9/site-packages/onionshare_cli/resources/static
[nov 23 2021 00:25:52] Common.get_resource_path: filename=templates
[nov 23 2021 00:25:52] Common.get_resource_path: filename=templates, path=/usr/lib/python3.9/site-packages/onionshare_cli/resources/templates
[nov 23 2021 00:25:52] Web.generate_static_url_path: new static_url_path is /static_ID
[nov 23 2021 00:25:52] ChatModeWeb.__init__
[nov 23 2021 00:25:52] ServerStatus.update
[nov 23 2021 00:25:56] ServerStatus.update
[nov 23 2021 00:25:56] Mode.start_server
[nov 23 2021 00:25:56] Mode.stop_server
[nov 23 2021 00:25:56] Web.stop: stopping server
[nov 23 2021 00:25:56] Web.cleanup
[nov 23 2021 00:25:56] Mode.start_server_error
[nov 23 2021 00:25:56] Alert.__init__
[nov 23 2021 00:25:59] ServerStatus.update
[nov 23 2021 00:25:59] Mode.stop_server
[nov 23 2021 00:25:59] Web.stop: stopping server
[nov 23 2021 00:25:59] Web.cleanup
[nov 23 2021 00:25:59] ChatMode.update_primary_action
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1022, resource id: 21111458, major code: 40 (TranslateCoords), minor code: 0
[nov 23 2021 00:26:10] MainWindow.closeEvent
[nov 23 2021 00:26:10] MainWindow.cleanup
[nov 23 2021 00:26:10] TabWidget.cleanup
[nov 23 2021 00:26:10] Tab.cleanup: tab_id=0
[nov 23 2021 00:26:10] Alert.__init__
[nov 23 2021 00:26:10] OnionCleanupThread.__init__
[nov 23 2021 00:26:10] OnionCleanupThread.run
[nov 23 2021 00:26:10] Onion.cleanup
Tor rendezvous circuits have closed
