So I downloaded OneNote from Snap and it doesnt start
I don’t use this software, but are you referring to p3x-onenote? If so, maybe you can try the versions that are available in the AUR. They are available via Pamac GUI, via terminal or manually by calling makepkg. I assume that you have the base-devel package installed as it is needed for AUR and AUR enabled in Pamac.
pamac build p3x-onenote
or
pamac build p3x-onenote-appimage
so I used pamac build p3x-onenote
p3x-onenote.sh gefunden
→ p3x-onenote.desktop gefunden
==> Überprüfe source Dateien mit sha256sums…
v2023.4.117.tar.gz … Erfolg
p3x-onenote.sh … Erfolg
p3x-onenote.desktop … Erfolg
==> Entferne existierendes $srcdir/ Verzeichnis…
==> Entpacke Quellen…
→ Entpacke v2023.4.117.tar.gz mit bsdtar
==> Beginne build()…
npm WARN config production Use --omit=dev
instead.
npm WARN config shrinkwrap Use the --package-lock setting instead.
npm notice
npm notice New major version of npm available! 8.19.2 → 9.7.1
npm notice Changelog:
npm notice Run npm install -g npm@9.7.1 to update!
npm notice
npm ERR! code FETCH_ERROR
npm ERR! errno FETCH_ERROR
npm ERR! invalid json response body at /got reason: Invalid response body while trying to fetch /got: read ETIMEDOUT
npm ERR! A complete log of this run can be found in:
npm ERR! /var/cache/private/pamac/p3x-onenote/src/npm_cache/_logs/2023-06-08T16_08_30_039Z-debug-0.log
==> FEHLER: Ein Fehler geschah in build().
Breche ab…
Finished with result: exit-code
Main processes terminated with: code=exited/status=4
Service runtime: 27min 301ms
CPU time consumed: 2min 34.784s
Fehler means error btw
I didn’t try that one as I do not want any electron stuff on my computer. That being said the .appimage builds here. I won’t be trying if it launches. I suggest that you try the .appimage.
/Downloads/p3x-onenote-appimage >>> makepkg -csr --skipchecksums
==> Making package: p3x-onenote-appimage 2023.4.117-3 (Thu 08 Jun 2023 01:01:31 PM EDT)
==> Retrieving sources...
-> Downloading p3x-onenote-2023.4.117.AppImage...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 92.7M 100 92.7M 0 0 34.6M 0 0:00:02 0:00:02 --:--:-- 43.9M
-> Downloading LICENSE...
100 1200 100 1200 0 0 2700 0 --:--:-- --:--:-- --:--:-- 2700
==> WARNING: Skipping verification of source file checksums.
==> Extracting sources...
==> Starting prepare()...
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "p3x-onenote-appimage"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: p3x-onenote-appimage 2023.4.117-3 (Thu 08 Jun 2023 01:02:11 PM EDT)
==> Cleaning up...
ok it works thx a lot!
