update
Related question is here .
My G913 interrupt the suspend of my pc.
solved by run a command in root.
Here is steps about how to make it:
stackoverflow
I get the command exec --no-startup-id echo disabled | sudo tee /sys/bus/usb/devices/1-10.1.4/power/wakeup
in my i3 config file. Which should turn the content of wakeup file from enabled to disabled.
But in fact it wont work.
in my config file I copy the file after the change like this:
exec --no-startup-id cp /sys/bus/usb/devices/1-10.1.4/power/wakeup ~/wk.bak
The content of wk.bak is enabled.
The other exec command works fine. So why this happens.
Does it do that if you run it from command line?
I would expext sudo to be problematic in an autostart script.
yeah it works from command line.
so how to start command with sudo?
What you probably mean is:
it works from command line after you did supply the admin password
I think this is the wrong question (https://xyproblem.info/ ).
A better one, if you want help, may be:
What is it that you want to achieve?
looks kike you want to wake up or put to sleep some USB device - toggle some energy saving function
addition:
if that is the case, perhaps this here can be inspiration
https://www.baeldung.com/linux/control-usb-power-supply
GitHub - ramzeto/usb-toggle: USB-Toggle is a Python script that allows to software unplug and software plug any USB device (including hubs).
You are asking the wrong question.
The right question is how do I run a script at system boot
You will need to execute the script as a systemd service and move the wk.bak file to another location e.g. /etc/wk.bak.
thanks but seems the usb plug cant bypass the root. Finally will need the root auth to make it.
Thanks for your urls you post.
Ok, you said it’s solved.
Even though I think no one here knows what you even wanted to do.
sorry
system
Closed
26 June 2024 02:46
9
