I’ve got two monitors, an Acer and a LG. I did a full system update with sudo pacman -Syu
earlier today, and after reboot, my LG monitor is going black every second or so (not a full power off, just the screen as if it’s having trouble rendering). My Acer monitor is perfectly fine, and both monitors were working pre-update.
Edit: I’m noticing that it seems to blink less often if there’s no mouse or keyboard input. It will blink for some time after keyboard input has stopped, but will eventually calm down?
Edit 2: Changing the resolution to something else besides 2560x1440 seems to have stabilized the LG monitor. Changing it back to 2560x1440 causes the blinking to happen again.
Edit 3: I’ve disabled the Adaptive-Sync option in my LG monitor’s settings menu (GSYNC-compatible FreeSync) and the blinking has gone away. Seems like something in the update broke compatibility with it. While I can make do with this disabled for now, it’s not ideal. Is this a known issue with FreeSync and is there a fix for it?
Any help is appreciated.
I’ve tried:
- Changing the refresh rate of the LG monitor from 144Hz to 60Hz, but no dice
- Upgraded kernels from 5.4.231-1 to 6.1.12-1, but it’s still happening
Any help would be appreciated because this is a very annoying issue. Thanks.
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.26.5 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1405
date: 11/19/2019
Info: 8-core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP cache: L2: 4 MiB
Speed (MHz): avg: 2524 min/max: 2200/4426 cores: 1: 4069 2: 2200 3: 2118
4: 2200 5: 2167 6: 3366 7: 2107 8: 2100 9: 2725 10: 2136 11: 2084 12: 2261
13: 2200 14: 4313 15: 2178 16: 2171
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] driver: nvidia v: 525.89.02
Device-2: Focusrite-Novation Scarlett 2i2 Camera type: USB
driver: snd-usb-audio
Display: x11 server: X.Org v: 21.1.7 driver: X: loaded: nvidia gpu: nvidia
resolution: 1: 2560x1440 2: 2560x1440~144Hz
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce RTX 2070
SUPER/PCIe/SSE2
Device-1: NVIDIA TU104 HD Audio driver: snd_hda_intel
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Device-3: Focusrite-Novation Scarlett 2i2 Camera type: USB
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: PulseAudio v: 16.1 running: yes
Sound Server-2: PipeWire v: 0.3.65 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi
IF: wlp4s0 state: up mac: 24:ee:9a:22:37:bf
driver: r8169
IF: enp5s0 state: down mac: 04:d9:f5:82:70:79
$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.12.18 false PCI
