On startup, my primary display will have a mirror of my secondary display(vertical) and a partial of what should be on the primary display. Whenever I go into display config and change the display orientation and back to what it was originally the issue fixes itself. Is there a way to avoid doing this?
Kernel: 5.19.0-3-rt10-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-rt-x86_64
root=UUID=43b5181f-c3cd-4e5b-9ca0-30f9e2d63d41 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: iBUYPOWER product: AMD v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3604
date: 04/14/2021
ID-1: hidpp_battery_0 charge: 47% condition: N/A volts: 3.8 min: N/A
model: Logitech G703 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: discharging
RAM: total: 31.26 GiB used: 2.61 GiB (8.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2932 high: 4700 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2198 2: 2200
3: 2197 4: 2200 5: 2196 6: 2195 7: 3600 8: 4700 9: 3293 10: 4669 11: 3763
12: 3520 13: 2193 14: 2194 15: 2211 16: 2200 17: 2200 18: 2200 19: 3700
20: 3700 21: 3282 22: 3599 23: 3306 24: 2875 bogomips: 177602
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: Gigabyte
driver: nouveau v: kernel non-free: 515.xx+ status: current (as of 2022-08)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
empty: DP-3,HDMI-A-1,HDMI-A-2 bus-ID: 0a:00.0 chip-ID: 10de:2216
class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-4.3:7 chip-ID: 046d:082d
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: nouveau display-ID: :0
screens: 1
Screen-1: 0 s-res: 4000x2560 s-dpi: 96 s-size: 1058x677mm (41.65x26.65")
s-diag: 1256mm (49.45")
Monitor-1: DP-1 pos: primary,top-left model: ASUS VG32V serial: <filter>
built: 2021 res: 1440x2560 hz: 120 dpi: 93 gamma: 1.2
size: 393x697mm (15.47x27.44") diag: 800mm (31.5") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
Monitor-2: DP-2 pos: primary,bottom-r model: ASUS VG32V serial: <filter>
built: 2021 res: 2560x1440 hz: 120 dpi: 93 gamma: 1.2
size: 697x393mm (27.44x15.47") diag: 800mm (31.5") ratio: 16:9 modes:
OpenGL: renderer: llvmpipe (LLVM 14.0.6 256 bits) v: 4.5 Mesa 22.1.7
direct render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel bus-ID: 1-4.2:5 v: kernel pcie: chip-ID: 0909:001c
class-ID: 0300 gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1
chip-ID: 10de:1aef class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Audio-Technica AT2020USB+ type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k5.19.0-3-rt10-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:6
Local Storage: total: 8.19 TiB used: 12.89 GiB (0.2%)
model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 614600WD temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST6000NE000-2KR101
size: 5.46 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: EN01 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 12.89 GiB (0.7%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 43b5181f-c3cd-4e5b-9ca0-30f9e2d63d41
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 316 KiB
(0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 9574-8145
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: SYSTEM
uuid: 2676-5DD1
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 600 MiB fs: ntfs label: Recovery
uuid: 068476A084769243
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 930.81 GiB fs: ntfs
label: Windows uuid: A21678CC1678A2C9
ID-5: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-6: /dev/sdb2 maj-min: 8:18 size: 5.46 TiB fs: ntfs label: New Volume
uuid: 48D622E2D622CFCC
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-1:2 info: Logitech PRO Gaming Keyboard type: Keyboard,HID
power: 500mA chip-ID: 046d:c339 class-ID: 0300 serial: <filter>
Hub-2: 1-4:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-4.2:5 info: Audio-Technica AT2020USB+ type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0909:001c class-ID: 0300
Device-2: 1-4.3:7 info: Logitech HD Pro Webcam C920 type: Video,Audio
power: 500mA chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Hub-3: 1-4.4:8 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Hub-4: 1-5:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-6:6 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-5: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 2-4:2 info: Realtek Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
Hub-7: 2-4.4:3 info: Realtek Hub ports: 4 rev: 3.2 speed: 5 Gb/s
Hub-8: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-4:2 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-9: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-10: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-3:2 info: Logitech Cordless Mouse Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c539 class-ID: 0300
Hub-11: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.0 C mobo: 43.0 C
Processes: 567 Uptime: 5m wakeups: 2 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1238
pm: pacman pkgs: 1235 libs: 320 tools: pamac pm: flatpak pkgs: 0 pm: snap
pkgs: 3 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.21
