On my Hp Spectre x360 my keyboard backlight key quits working - still
I still have this problem.
I know it has to do with 6.10.x kernel and 6.11 kernel
6.6.x kernel works fine.
Where can I go to see what bugs have been entered for these kernels?
Hi @MAYBL8,
The official kernel bugzilla:
https://bugzilla.kernel.org/
That says I should report the issue to the vendor. So I guess Manjaro is the vendor?
demo@Manjaro ~]$ uname -a
Linux Manjaro 6.6.50-2-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Sep 11 00:16:29 UTC 2024 x86_64 GNU/Linux
[demo@Manjaro ~]$
I am showing the 6.6 kernel here but I have the kernels from 6.11 and 6.10 from Manjaro.
Seeing as the earlier kernels work, why not stick to them?
That is what I have been doing.
My whole reason for trying the latest kernel is the hope that someday my bluetooth will work on this laptop. Then in trying different kernels I stumble upon other issues.
AH yes, but don’t worry too much. Continue as you do. Try and get the bluetooth working in the other kernels, rather.
Do you think it is worth trying to get the bluetooth working?
I can open another post here but I have others in the past and came up empty.
Maybe. I am not at all sure. I think I remember the post(s) but I can’t remember what happened in them.
I think open a post and give the output of,
inxi -Fxxxc5
I can’t promise you anything other than I’ll have a read.
OH! And reference this, and your other posts as well.
Edit:
And also provide the output of:
lspci -nn
…please and thank you!
Edit #2:
It would seem your laptop uses the alternative bluetooth/wireless adapter (Intel BE200) and that driver seems to only have been added to kernel 6.5+:
And this page:
…on the Arch wiki states:
https://i.imgur.com/6ONUGPN.png
So it would seem it works. Where implemented.
But I’m unable to find a driver for it…
Looks like the following kernels have fixed the issue.
6.10.11-2-MANJARO
6.11.0-6
