I love to play starblast.io (a small 3D game in browser).
Since I’ve Manjaro, I cannot solve this problem.
I start my laptop without dual screen (HDMI not connected). I can play the game (some latence but maybe, performances are lower than windows 10 ?).
Then, I connect my dual screen (LG Ultrawide) and immediately, performances falls.
My PC is modern : DELL G7 7700 with i7 and 16GB RAM and RTX2060 graphic card.
Some troubleshooting commands:
prime-run glxgears ✔
Running synchronized to the vertical refresh. The framerate should be
approximately the same as the monitor refresh rate.
715 frames in 5.0 seconds = 142.955 FPS
714 frames in 5.0 seconds = 142.744 FPS
715 frames in 5.0 seconds = 142.967 FPS
or
watch -n1 nvidia-smi
| NVIDIA-SMI 515.48.07 Driver Version: 515.48.07 CUDA Version: 11.7 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A |
| N/A 58C P5 12W / N/A | 54MiB / 6144MiB | 36% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 872 G /usr/lib/Xorg 53MiB |
Never show my browser (show gfxgears). Even if I try ‘prime-run vivaldi-stable&’ but browser shows me errors like this:
[23573:23573:0618/165846.075403:ERROR:image_generic.cc(77)] Unable to decode PNG for 1.
[23609:23609:0618/165846.094532:ERROR:angle_platform_impl.cc(43)] Display.cpp:977 (initialize): ANGLE Display::initialize error 12289: Invalid visual ID requested.
[23609:23609:0618/165846.094619:ERROR:gl_surface_egl.cc(852)] EGL Driver message (Critical) eglInitialize: Invalid visual ID requested.
[23609:23609:0618/165846.094650:ERROR:gl_surface_egl.cc(1489)] eglInitialize OpenGL failed with error EGL_NOT_INITIALIZED, trying next display type
[23609:23609:0618/165846.095310:ERROR:angle_platform_impl.cc(43)] Display.cpp:977 (initialize): ANGLE Display::initialize error 12289: Invalid visual ID requested.
[23609:23609:0618/165846.095345:ERROR:gl_surface_egl.cc(852)] EGL Driver message (Critical) eglInitialize: Invalid visual ID requested.
[23609:23609:0618/165846.095368:ERROR:gl_surface_egl.cc(1489)] eglInitialize OpenGLES failed with error EGL_NOT_INITIALIZED
[23609:23609:0618/165846.095392:ERROR:gl_ozone_egl.cc(21)] GLSurfaceEGL::InitializeOneOff failed.
[23609:23609:0618/165846.097010:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[23686:23686:0618/165846.241253:ERROR:angle_platform_impl.cc(43)] Display.cpp:977 (initialize): ANGLE Display::initialize error 12289: Invalid visual ID requested.
[23686:23686:0618/165846.241395:ERROR:gl_surface_egl.cc(852)] EGL Driver message (Critical) eglInitialize: Invalid visual ID requested.
[23686:23686:0618/165846.241432:ERROR:gl_surface_egl.cc(1489)] eglInitialize OpenGL failed with error EGL_NOT_INITIALIZED, trying next display type
[23686:23686:0618/165846.241898:ERROR:angle_platform_impl.cc(43)] Display.cpp:977 (initialize): ANGLE Display::initialize error 12289: Invalid visual ID requested.
[23686:23686:0618/165846.241943:ERROR:gl_surface_egl.cc(852)] EGL Driver message (Critical) eglInitialize: Invalid visual ID requested.
[23686:23686:0618/165846.241978:ERROR:gl_surface_egl.cc(1489)] eglInitialize OpenGLES failed with error EGL_NOT_INITIALIZED
[23686:23686:0618/165846.242010:ERROR:gl_ozone_egl.cc(21)] GLSurfaceEGL::InitializeOneOff failed.
[23686:23686:0618/165846.244158:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
libva error: /usr/lib/dri/i965_drv_video.so init failed
[23641:7:0618/165846.400446:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[23573:23573:0618/165847.164776:ERROR:CONSOLE(1)] "syncDetachedTabInformation: The message port closed before a response was received.", source: chrome-extension://mpo
gnobbkildjkofajifpdfhcoklimli/bundle.js (1)
[23573:23573:0618/165847.164961:ERROR:CONSOLE(1)] "syncDetachedTabInformation: The message port closed before a response was received.", source: chrome-extension://mpo
[23573:23573:0618/165847.165071:ERROR:CONSOLE(1)] "syncDetachedTabInformation: The message port closed before a response was received.", source: chrome-extension://mpo
[23573:23573:0618/165847.165174:ERROR:CONSOLE(1)] "syncDetachedTabInformation: The message port closed before a response was received.", source: chrome-extension://mpo
[23573:23573:0618/165847.165300:ERROR:CONSOLE(1)] "syncDetachedTabInformation: The message port closed before a response was received.", source: chrome-extension://mpo
[23573:23573:0618/165848.313176:ERROR:sharing_service.cc(222)] Device registration failed with fatal error
[23573:23573:0618/165849.166884:ERROR:CONSOLE(0)] "Uncaught (in promise) Error: A listener indicated an asynchronous response by returning true, but the message channe
l closed before a response was received", source: chrome-extension://mpognobbkildjkofajifpdfhcoklimli/browser.html (0)
[23573:23573:0618/165849.166952:ERROR:CONSOLE(0)] "Uncaught (in promise) Error: A listener indicated an asynchronous response by returning true, but the message channe
[23708:23708:0618/165849.369722:ERROR:gl_utils.cc(319)] [.WebGL-0xf9c05f37100]GL Driver Message (OpenGL, Performance, GL_CLOSE_PATH_NV, High): GPU stall due to ReadPix
els
[23708:23708:0618/165849.684902:ERROR:gl_utils.cc(319)] [.WebGL-0xf9c05f37100]GL Driver Message (OpenGL, Performance, GL_CLOSE_PATH_NV, High): GPU stall due to ReadPix
els
[23708:23708:0618/165849.759496:ERROR:gl_utils.cc(319)] [.WebGL-0xf9c05f37100]GL Driver Message (OpenGL, Performance, GL_CLOSE_PATH_NV, High): GPU stall due to ReadPix
els
[23708:23708:0618/165849.828209:ERROR:gl_utils.cc(319)] [.WebGL-0xf9c05f37100]GL Driver Message (OpenGL, Performance, GL_CLOSE_PATH_NV, High): GPU stall due to ReadPix
els (this message will no longer repeat)
Any help or idea to troubleshoot more is welcome.
Thanks
