Hi people,
I formatted my laptop and reinstalled Manjaro.
I was personalized my KDE desktop, installing latte, icons, typical stuff. All works OK, except the plasmashell.
When I init my laptop and login, my desktop is black, plasmashell, don’t load (sometimes yes, but the most part NO). I can see my cursor and always I execute kstart plasmashell
to reload again and works!. (I can execute apps with krunner using the shortcut)
Someone knows how can I solved? The “bad” solution that I thought was write this command on init my laptop, but I want to solved in the correct way and not like this.
No one? I thought it would be something easy to fix…
