On Fresh Install - Spell Checking Not Working On KDE Plasma?
Hi,
On a fresh install of KDE Plasma version of Manjaro,
spell checking is not working?
In settings: “Spell Check”, “Default language” is empty and can’t be configured?
“Preferred Languages” is also empty?
How can I fix spell checking on KDE Plasma?
inxi --admin --verbosity=8 --filter --no-host --width                                     ✔
[sudo] password for jlp:
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=e6904fb9-88c7-445f-92eb-bd71124dfe33 rw quiet
    cryptdevice=UUID=ea95b186-2441-4a26-bc26-1445436021f6:luks-ea95b186-2441-4a26-bc26-1445436021f6
    root=/dev/mapper/luks-ea95b186-2441-4a26-bc26-1445436021f6 splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
    serial: <filter> part-nu: SKU uuid: 1dc43fb0-791e-09e2-5630-50ebf6cf13b4
    UEFI: American Megatrends v: 5003 date: 10/07/2023
  System RAM: total: 64 GiB available: 62.71 GiB used: 8.79 GiB (14.0%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
    width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK32GX4M2E3200C16 serial: N/A
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Slot: 0 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:03.1
    children: 1: 0a:00.0 class-ID: 0300 type: display 2: 0a:00.1 class-ID: 0403
    type: audio
  Slot: 1 type: PCIe status: available length: long volts: 3.3
    bus-ID: 00:1f.7
  Slot: 2 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Slot: 3 type: PCIe status: in use length: short volts: 3.3 bus-ID: 02:03.0
  Info: model: AMD Ryzen 7 5800X socket: AM4 bits: 64 type: MT MCP arch: Zen 3+
    gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 1752 min/max: 550/4851 boost: enabled
    base/boost: 3800/4850 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 1752 2: 1752 3: 1752 4: 1752
    5: 1752 6: 1752 7: 1752 8: 1752 9: 1752 10: 1752 11: 1752 12: 1752 13: 1752
    14: 1752 15: 1752 16: 1752 bogomips: 121424
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    affected
  Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
    vendor: Micro-Star MSI driver: nvidia v: 550.144.03
    alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as of
    2025-01; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
    built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0a:00.0 chip-ID: 10de:2504
    class-ID: 0300
  Display: unspecified server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 162 s-size: 602x341mm (23.70x13.43")
    s-diag: 692mm (27.24")
  Monitor-1: HDMI-0 res: mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 163
    size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: gbm,wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.144.03
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
    memory: 11.72 GiB
  API: Vulkan v: 1.4.303 layers: 1 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3060 driver: N/A device-ID: 10de:2504
    surfaces: xcb,xlib
  Device-1: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 0a:00.1 chip-ID: 10de:228e class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
    bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
    chip-ID: 8086:2526 class-ID: 0280
  IF: wlp5s0 state: down mac: <filter>
  Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp6s0 state: down mac: <filter>
  IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> scope: global
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2
    chip-ID: 8087:0025 class-ID: e001
  Device-1: luks-ea95b186-2441-4a26-bc26-1445436021f6 maj-min: 254:0
    type: LUKS dm: dm-0 size: 1.82 TiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 1.82 TiB
  Local Storage: total: 1.82 TiB used: 226.48 GiB (12.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 38.9 C
    scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 226.48 GiB (12.4%)
    fs: ext4 block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-ea95b186-2441-4a26-bc26-1445436021f6 label: N/A
    uuid: e6904fb9-88c7-445f-92eb-bd71124dfe33
    used: 448 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 7687-2945
  Hub-2: 1-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 045b:0209 class-ID: 0900
  Hub-3: 1-2.1:4 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
  Hub-4: 1-2.3:5 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
  Hub-5: 1-2.3.1:7 info: Hitachi ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 045b:0209
  Device-1: 1-2.3.4:8 info: Brother Industries DCP-L2550DW series
    type: printer driver: usblp interfaces: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
    chip-ID: 04f9:0424 class-ID: 0701 serial: <filter>
  Hub-6: 1-5:3 info: Terminus Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-5.4:6 info: Realtek Mass Storage Device (Multicard Reader)
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    chip-ID: 0bda:0151 class-ID: 0806 serial: <filter>
  Hub-7: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-8: 2-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210 class-ID: 0900
  Hub-9: 2-2.1:3 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
  Hub-10: 2-2.3:4 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
  Hub-11: 2-2.3.1:5 info: Hitachi ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210
  Hub-12: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-5:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Device-2: 3-6:3 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
    serial: <filter>
  Hub-13: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-14: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: USB Optical Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:0400 class-ID: 0301
  Device-2: 5-2:3 info: China Resource Semico USB Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 500mA chip-ID: 1a2c:4094 class-ID: 0300
  Hub-15: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 46.9 C mobo: N/A gpu: nvidia temp: 58 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Packages: 1527 pm: pacman pkgs: 1500 libs: 502 tools: pamac pm: rpm pkgs: 0
    pm: flatpak pkgs: 27
    1: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 421
  1: cpu: 41.0% command: nxplayer.bin pid: 4332 mem: 546.0 MiB (0.8%)
  2: cpu: 9.8% command: Xorg pid: 980 mem: 283.1 MiB (0.4%)
  3: cpu: 3.2% command: firefox pid: 2506 mem: 1042.2 MiB (1.6%)
  4: cpu: 1.7% command: konsole pid: 475162 mem: 276.4 MiB (0.4%)
  5: cpu: 1.5% command: firefox pid: 2663 mem: 611.7 MiB (0.9%)
  Memory top: 5 of 421
  1: mem: 1057.1 MiB (1.6%) command: soffice.bin pid: 2461 cpu: 0.0%
  2: mem: 1042.2 MiB (1.6%) command: firefox pid: 2506 cpu: 3.2%
  3: mem: 868.0 MiB (1.3%) command: plasmashell pid: 1397 cpu: 0.9%
  4: mem: 852.2 MiB (1.3%) command: firefox pid: 2744 cpu: 1.1%
  5: mem: 645.1 MiB (1.0%) command: firefox pid: 2639 cpu: 0.4%
  Processes: 421 Power: uptime: 1d 11h 32m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 25.05 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
    default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
Open up Manjaro Settings Manager and install your language pack.
That worked, thanks!
(required a reboot)
Great.
The MSM functions correlate to a handful of packages, depending on what is installed.
In my case thats mainly hunspell and the hunspell-* spell checking packages.
This could additionally include gimp help, libreoffice, firefox, and various other application-specific packs.
(Note that sonnet, plasma’s spell checking framework, can utilize any number of spellchecker backends like hunspell, aspell, hspell for hebrew, and so on.)
Maybe just an end of session (log out), but why not go for the full thing.
