I want to create a clone of my existing NVME drive as a backup using Rescuezilla. I have another NVME drive of the same storage specs as my primary drive. I had a few questions before I begin.
As I understand the process, this should be as easy as choosing the “Clone” option and property specifying the “source” and “destination” drives. Is this correct?
When the cloning operation is complete, my understanding is that the “destination” drive should have the same partition layout and data content, including the same UUID. Is this correct?
If so, when I reboot, I should make sure the duplicated “destination” drive is fully disconnected so as not to cause any confusion when booting.
Finally, supposed my primary drive explodes and I need to use the backup drive. Can I simply remove the old drive and install the backup drive and proceed?
My current drive information is as follows (I use BTRFS as the file system):
My sudo fdisk -l output
Disk /dev/nvme0n1: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: WD_BLACK SN770 1TB
Disklabel type: gpt
Disk identifier: 15860E88-442C-4E12-A980-4554C2486B2F
Device Start End Sectors Size Type
/dev/nvme0n1p1 4096 618495 614400 300M EFI System
/dev/nvme0n1p2 618496 1953520064 1952901569 931.2G Linux filesystem
Disk /dev/mapper/luks-2a9099ad-5c2d-43f8-bd02-80c790d1cdfc: 931.21 GiB, 999883506176 bytes, 1952897473 sectors
Disk /dev/loop0: 4 KiB, 4096 bytes, 8 sectors
Disk /dev/loop1: 164.82 MiB, 172830720 bytes, 337560 sectors
Disk /dev/loop2: 55.36 MiB, 58052608 bytes, 113384 sectors
Disk /dev/loop3: 91.69 MiB, 96141312 bytes, 187776 sectors
Disk /dev/loop4: 44.3 MiB, 46448640 bytes, 90720 sectors
Disk /dev/loop5: 44.44 MiB, 46596096 bytes, 91008 sectors
My sudo blkid output:
/dev/loop1: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/nvme0n1p1: UUID="65C6-DD33" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="fe0fc278-7b72-46e2-bbcb-e139a9df2fd6"
/dev/nvme0n1p2: UUID="2a9099ad-5c2d-43f8-bd02-80c790d1cdfc" TYPE="crypto_LUKS" PARTLABEL="root" PARTUUID="cff11479-a38a-4ccb-9c1a-f0908bf38d89"
/dev/loop4: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/loop2: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/loop0: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/mapper/luks-2a9099ad-5c2d-43f8-bd02-80c790d1cdfc: UUID="4a0cc8d5-31af-455f-ae55-faadde0e3603" UUID_SUB="f30009e0-c7db-4725-a6c2-b1f4c9f8b200" BLOCK_SIZE="4096" TYPE="btrfs"
/dev/loop5: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/loop3: BLOCK_SIZE="131072" TYPE="squashfs"
