Hi
Okular 21.08.1
Manjaro XFCE 21.1.3
I want to try to read aloud a document with Okular, that’s the console output:
$ okular
Error loading text-to-speech plug-in "speechd"
I do see that qt5-speech 5.15.2-1 is installed
From Text to Speech on GNU/Linux Part 2: Okular to Speech
I deduct the problem lies in the LOADING.
any help?
Thanks
Hello,
But that doesn’t mean the speechd
is present/installed as i part of libspeechd
+ speech-dispatcher
… but you can for example use flite
instead …
It can’t load what is not installed. Once you install one that you prefer, and set it in Okular Preferences, you should have no error.
In Okular>Configuration>Configure Okular>Accessibility
I can indeed choose the test to speech engine
If I installed: sayit, espeak, flite; I only see flite or speechd in Okular
If I select speechd that’s the console output:
$ okular
Found no modules in speech-dispatcher. No text to speech possible.
https://code.woboq.org/qt5/qtspeech/src/plugins/tts/speechdispatcher/qtexttospeech_speechd.cpp.html
