Hello from Argentina!. I have a problem. I am not being able to print documents on an OKI B431 printer that is connected to the network. Can someone give me a hand to find the solution? Thank you in advance.
Hug
Hug
Hello from Germany!
If you have installed CUPS, then go to a webbrowser (firefox, chromium etc) and launch this address: http://localhost:631/admin
There you can add the network printer and even search for it
Or install system-config-printer
which is a GUI for CUPS.
Thank you very much for your help.
I will try to implement this solution.
Regards
