Brand new with Manjaro KDE version, long time linux user, I have a little issue with Manjaro regarding my printer. I have an OKI B411D (Laser printer with only USB). I have setup on it since a long time a Raspberry PI running Linux and CUPS so my printer is on network.
With Ubuntu, Mint or Pop OS, printer automatically shows up on these systems. On Manjaro nothing shows up so no problem I add it through the wizard of printer manager in KDE. Unhappy at end I’m unable to print properly, it rasters the file, send it at spooler and then get an error about not being able to receive such files and for sure nothing happens on cups spooler neither on printer !
I have even installed the official PPD from Oki but exactly same issue
An idea what’s wrong there ?
Sorry for late answer, just so bored of all that damn IT that never works properly even with Linux
For journal on local cups on my desktop here is what I have found (not sure it’s usable for debug)
W [31/Jul/2022:14:35:59 +0200] CreateProfile failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files
W [31/Jul/2022:14:35:59 +0200] CreateDevice failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files
E [31/Jul/2022:14:58:18 +0200] [Job 16] Print job canceled at printer.
W [31/Jul/2022:14:58:18 +0200] [Job 16] Backend returned status 5 (cancel job)
W [31/Jul/2022:15:00:36 +0200] CreateProfile failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files
W [31/Jul/2022:15:00:36 +0200] CreateDevice failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files
W [31/Jul/2022:15:09:00 +0200] CreateProfile failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files
W [31/Jul/2022:15:09:00 +0200] CreateDevice failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files
E [31/Jul/2022:15:09:09 +0200] [Job 19] The printer configuration is incorrect or the printer no longer exists.
W [31/Jul/2022:15:09:09 +0200] [Job 19] Backend returned status 4 (stop printer)
W [31/Jul/2022:15:10:28 +0200] CreateProfile failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files
W [31/Jul/2022:15:10:28 +0200] CreateDevice failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files
Journal on cups server physically connected at printer:
E [31/Jul/2022:00:00:08 +0200] Missing value on line 125 of /var/cache/cups/job.cache.
E [31/Jul/2022:14:37:10 +0200] [Job 290] Can\'t detect file type
E [31/Jul/2022:14:37:18 +0200] [Job 290] Job stopped due to filter errors; please consult the /var/log/cups/error_log file for details.
D [31/Jul/2022:14:37:18 +0200] [Job 290] The following messages were recorded from 14:37:04 to 14:37:18
D [31/Jul/2022:14:37:18 +0200] [Job 290] Applying default options...
D [31/Jul/2022:14:37:18 +0200] [Job 290] Adding start banner page "none".
D [31/Jul/2022:14:37:18 +0200] [Job 290] Queued on "Oki_B411D" by "vincen".
D [31/Jul/2022:14:37:18 +0200] [Job 290] File of type application/vnd.cups-postscript queued by "vincen".
D [31/Jul/2022:14:37:18 +0200] [Job 290] Adding end banner page "none".
D [31/Jul/2022:14:37:18 +0200] [Job 290] time-at-processing=1659271028
D [31/Jul/2022:14:37:18 +0200] [Job 290] 2 filters for job:
D [31/Jul/2022:14:37:18 +0200] [Job 290] gstoraster (application/vnd.cups-postscript to application/vnd.cups-raster, cost 175)
D [31/Jul/2022:14:37:18 +0200] [Job 290] rastertogutenprint.5.3 (application/vnd.cups-raster to printer/Oki_B411D, cost 100)
D [31/Jul/2022:14:37:18 +0200] [Job 290] job-sheets=none,none
D [31/Jul/2022:14:37:18 +0200] [Job 290] argv[0]="Oki_B411D"
D [31/Jul/2022:14:37:18 +0200] [Job 290] argv[1]="290"
D [31/Jul/2022:14:37:18 +0200] [Job 290] argv[2]="vincen"
D [31/Jul/2022:14:37:18 +0200] [Job 290] argv[3]="formulaire-contrat-de-sous-location-dappartement.pdf"
D [31/Jul/2022:14:37:18 +0200] [Job 290] argv[4]="1"
D [31/Jul/2022:14:37:18 +0200] [Job 290] argv[5]="job-uuid=urn:uuid:d98db37f-421d-3db8-66d1-06f7cc89bca6 job-originating-host-name=192.168.1.202 date-time-at-creation= date-time-at-processing= time-at-creation=1659271024 time-at-processing=1659271028"
D [31/Jul/2022:14:37:18 +0200] [Job 290] argv[6]="/var/spool/cups/d00290-001"
D [31/Jul/2022:14:37:18 +0200] [Job 290] envp[0]="CUPS_CACHEDIR=/var/cache/cups"
D [31/Jul/2022:14:37:18 +0200] [Job 290] envp[1]="CUPS_DATADIR=/usr/share/cups"
D [31/Jul/2022:14:37:18 +0200] [Job 290] envp[2]="CUPS_DOCROOT=/usr/share/cups/doc-root"
D [31/Jul/2022:14:37:18 +0200] [Job 290] envp[3]="CUPS_FONTPATH=/usr/share/cups/fonts"
D [31/Jul/2022:14:37:18 +0200] [Job 290] envp[4]="CUPS_REQUESTROOT=/var/spool/cups"
D [31/Jul/2022:14:37:18 +0200] [Job 290] envp[5]="CUPS_SERVERBIN=/usr/lib/cups"
D [31/Jul/2022:14:37:18 +0200] [Job 290] envp[6]="CUPS_SERVERROOT=/etc/cups"
D [31/Jul/2022:14:37:18 +0200] [Job 290] envp[7]="CUPS_STATEDIR=/run/cups"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[8]="HOME=/var/spool/cups/tmp"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[9]="PATH=/usr/lib/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[10]="SERVER_ADMIN=root@oki-b411d"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[11]="SOFTWARE=CUPS/2.2.10"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[12]="TMPDIR=/var/spool/cups/tmp"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[13]="USER=root"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[14]="CUPS_MAX_MESSAGE=2047"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[15]="CUPS_SERVER=/run/cups/cups.sock"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[16]="CUPS_ENCRYPTION=IfRequested"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[17]="IPP_PORT=631"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[18]="CHARSET=utf-8"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[19]="LANG=fr_FR.UTF-8"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[20]="PPD=/etc/cups/ppd/Oki_B411D.ppd"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[21]="RIP_MAX_CACHE=128m"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[22]="CONTENT_TYPE=application/vnd.cups-postscript"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[23]="DEVICE_URI=usb://OKI%20DATA%20CORP/B411?serial=AK24015524"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[24]="PRINTER_INFO=OKI DATA CORP B411"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[25]="PRINTER_LOCATION=Espezel"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[26]="PRINTER=Oki_B411D"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[27]="PRINTER_STATE_REASONS=none"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[28]="CUPS_FILETYPE=document"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[29]="FINAL_CONTENT_TYPE=application/vnd.cups-raster"
D [31/Jul/2022:14:37:19 +0200] [Job 290] envp[30]="AUTH_I****"
D [31/Jul/2022:14:37:19 +0200] [Job 290] Started filter /usr/lib/cups/filter/gstoraster (PID 22029)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Started filter /usr/lib/cups/filter/rastertogutenprint.5.3 (PID 22030)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Started backend /usr/lib/cups/backend/usb (PID 22031)
D [31/Jul/2022:14:37:19 +0200] [Job 290] OUTFORMAT=\"(null)\", so output format will be CUPS/PWG Raster
D [31/Jul/2022:14:37:19 +0200] [Job 290] Loading USB quirks from \"/usr/share/cups/usb\".
D [31/Jul/2022:14:37:19 +0200] [Job 290] Loaded 172 quirks.
D [31/Jul/2022:14:37:19 +0200] [Job 290] Printing on printer with URI: usb://OKI%20DATA%20CORP/B411?serial=AK24015524
D [31/Jul/2022:14:37:19 +0200] [Job 290] libusb_get_device_list=2
D [31/Jul/2022:14:37:19 +0200] [Job 290] STATE: +connecting-to-device
D [31/Jul/2022:14:37:19 +0200] [Job 290] STATE: -connecting-to-device
D [31/Jul/2022:14:37:19 +0200] [Job 290] Printer found with device ID: MANUFACTURER:OKI DATA CORP;COMMAND SET:PJL,PCL,IBMPPR,EPSONFX,PCLXL;MODEL:B411;CLASS:PRINTER;DESCRIPTION:OKI B411; Device URI: usb://OKI%20DATA%20CORP/B411?serial=AK24015524
D [31/Jul/2022:14:37:19 +0200] [Job 290] Device protocol: 2
D [31/Jul/2022:14:37:19 +0200] [Job 290] Sending data to printer.
D [31/Jul/2022:14:37:19 +0200] [Job 290] Set job-printer-state-message to "Sending data to printer.", current level=INFO
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: ============================================================
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: 5.3.1 Starting
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: command line: Oki_B411D \'290\' \'vincen\' \'formulaire-contrat-de-sous-location-dappartement.pdf\' \'1\' <args>
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: using PPD file /etc/cups/ppd/Oki_B411D.ppd
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: CUPS option count is 6 (200 bytes)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: CUPS option 0 date-time-at-creation =
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: CUPS option 1 date-time-at-processing =
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: CUPS option 2 job-originating-host-name = 192.168.1.202
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: CUPS option 3 job-uuid = urn:uuid:d98db37f-421d-3db8-66d1-06f7cc89bca6
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: CUPS option 4 time-at-creation = 1659271024
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: CUPS option 5 time-at-processing = 1659271028
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Driver Oki B401d
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Using fd 0
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Set options:
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Set string DitherAlgorithm to None
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Set special string DitherAlgorithm to None
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting PageSize to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting MediaType to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting InputSlot to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Set string Quality to Standard
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Set special string Quality to Standard
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting Resolution to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting InkType to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting InkChannels to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting PrintingMode to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting Duplex to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting Orientation to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting LabelSeparator to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting Darkness to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting NativeCopies to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Set string ColorCorrection to None
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Set special string ColorCorrection to None
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting ChannelBitDepth to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting InputImageType to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting STPIOutputType to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting STPIRawChannels to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting SimpleGamma to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Set bool LinearContrast to False (0)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting LUTDumpFile to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CyanCurve to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting MagentaCurve to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting YellowCurve to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting BlackCurve to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting RedCurve to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting GreenCurve to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting BlueCurve to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting WhiteCurve to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting HueMap to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting SatMap to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting LumMap to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting GCRCurve to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh0 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh1 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh2 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh3 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh4 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh5 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh6 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh7 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh8 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh9 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh10 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh11 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh12 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh13 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh14 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh15 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh16 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh17 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh18 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh19 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh20 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh21 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh22 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh23 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh24 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh25 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh26 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh27 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh28 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh29 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh30 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh31 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh32 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh33 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh34 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh35 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh36 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh37 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh38 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh39 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh40 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh41 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh42 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh43 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh44 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh45 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh46 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh47 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh48 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh49 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh50 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh51 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh52 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh53 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh54 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh55 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh56 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh57 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh58 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh59 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh60 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh61 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh62 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting CurveCh63 to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Set string ImageType to TextGraphics
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Set special string ImageType to TextGraphics
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting JobMode to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting PageNumber to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting NumCopies to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: Not setting Collate to (null)
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: End options
D [31/Jul/2022:14:37:19 +0200] [Job 290] Set job-printer-state-message to "Can\'t detect file type", current level=ERROR
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: About to start printing loop.
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: stats 0B, 0,750u, 0,040s, 2,001el
D [31/Jul/2022:14:37:19 +0200] [Job 290] Gutenprint: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
D [31/Jul/2022:14:37:19 +0200] [Job 290] PID 22029 (/usr/lib/cups/filter/gstoraster) stopped with status 1.
D [31/Jul/2022:14:37:19 +0200] [Job 290] Hint: Try setting the LogLevel to "debug" to find out more.
D [31/Jul/2022:14:37:19 +0200] [Job 290] Sent 0 bytes...
D [31/Jul/2022:14:37:19 +0200] [Job 290] Waiting for read thread to exit...
D [31/Jul/2022:14:37:19 +0200] [Job 290] PID 22030 (/usr/lib/cups/filter/rastertogutenprint.5.3) exited with no errors.
D [31/Jul/2022:14:37:19 +0200] [Job 290] Read thread still active, aborting the pending read...
D [31/Jul/2022:14:37:19 +0200] [Job 290] PID 22031 (/usr/lib/cups/backend/usb) exited with no errors.
D [31/Jul/2022:14:37:19 +0200] [Job 290] End of messages
D [31/Jul/2022:14:37:19 +0200] [Job 290] printer-state=3(idle)
D [31/Jul/2022:14:37:19 +0200] [Job 290] printer-state-message="Can't detect file type"
D [31/Jul/2022:14:37:19 +0200] [Job 290] printer-state-reasons=none
No idea what to do to fix a problem that never existed with other Linux distros I used before
If it works on another distro, you could try with a live USB of such distro.
In the live environment, you set up the printer and test it. If it works to your liking, look very closely at the printer settings and write down everything. Maybe it’s a misconfiguration.
(I don’t know where cups and KDE store the settings, so I don’t know which files you could copy.)
yep tried that already but for example with Debian I have nothing to setup ! I boot with a live image and once booted my printer is already there and working straight It was same with Pop OS I was using before !
KDE is not involved so far as I know, only cups and for that you get all settings in an easy way using cups webserver avalaible at localhost:631 !
On debian I just tried the printer appears as implicitclass Will have to do some investigations to know what it means exactly and why I don’t have same behaviour with Manjaro that is using also CUPS !
