There seem to be issues with mirrors.manjaro.org and mirrors2.manjaro.org today. You can see this if your mirrors are set to mirrors.manjaro.org and mirrors2.manjaro.org (can be set with sudo pacman-mirrors --country Global --interactive) and then running a quick test of sudo pacman -Syy. Today, this seems to result in databases failing to download.
Here is output from a couple of my attempts. I tried at least 4 times before switching mirrors.
core 144.7 KiB 81.5 KiB/s 00:02 [######################] 100%
extra 8.6 MiB 862 KiB/s 00:10 [######################] 100%
multilib 144.3 KiB 115 KiB/s 00:01 [######################] 100%
error: failed retrieving file 'core.db' from mirrors.manjaro.org : Failed to connect to mirrors.manjaro.org port 443 after 10000 ms: Timeout was reached
error: failed retrieving file 'multilib.db' from mirrors.manjaro.org : Failed to connect to mirrors.manjaro.org port 443 after 10000 ms: Timeout was reached
core.db failed to download
extra 8.6 MiB 6.28 MiB/s 00:01 [################################################################] 100%
multilib 144.3 KiB 1443 KiB/s 00:00 [################################################################] 100%
error: failed retrieving file 'core.db' from mirrors.manjaro.org : Failed to connect to mirrors.manjaro.org port 443 after 10001 ms: Timeout was reached
error: failed retrieving file 'core.db' from mirrors2.manjaro.org : Failed to connect to mirrors2.manjaro.org port 443 after 10001 ms: Timeout was reached
error: failed to synchronize all databases (download library error)
I ended up switching mirrors with sudo pacman-mirrors --country Canada --interactive and picking something else in there with a relatively recent sync, even though the global mirrors at mirrors.manjaro.org and mirrors2.manjaro.org have usually worked consistently with very low sync latency.
In case this matters for edge server location, I’m located in New Westminster, Canada, which is very close to Vancouver, Canada.
I’m just reporting this so that anyone looking after these mirrors is aware of the issue. If there is a better place to report issues like this, please let me know.
