[HowTo] Post command output and file content as preformatted text - #10 by kata55
Is it my impression or is it rather poor on mobile devices?
Don’t know what you mean exactly but i find some of the features of discourse hardly usable on mobile. Like try to select text and use the toolbar to inser code tag…between all the discouse popup menu and android popup (now on 2 rows)…
But that is not something we can change.
Precisely
There are certainly some annoyances with the Android version of Firefox.
Apart from that sodding on-screen keyboard getting in the bloody way all the time, the inability to (easily and precisely) select the text you intend to edit (and no cursor navigation “keys”) …
… and the fact that if you accidentally hit a “like”, you can not remove it. Touch it again, it flashes OFF, ON, OFF and then back ON. (You can change it, but by the time I get home it’s too late to remove it).
Not to mention the browser’s habit of sweeping frequently used tabs into its “Inactive Tabs” list, which you have to scroll through from the top EVERY time, to try and find the now-hidden tab one used just last night.
