Odroid n2 helpful information (I hope)
Hey folks. I am a long time Manjaro user, primarily on x86 laptops, and have used manjaro arm on my raspberry pis and the odroid n2 as well. Recently I dusted off my odroid n2 and decided to jump right into bleeding edge mainline linux on arch. I had some good success, and solved a few problems that probably also impact manjaro given the arch lineage. I plan to give manjaro another go on all of my arm devices in the future but figured I would post my arch findings on the n2 up here in case it helps anyone solve problems with their n2 or perhaps helps the devs with any answers/issues they had not solved yet.
Hi,
Thanks a lot for your contribution.
:+1:
Thanks
Following your guide, I added panfrost into the modules section of /etc/mkinitcpio.conf
Still I’m unable to get vulkan support
I installed manjaro, switched to the unstable branch and updated the system.
