I have this odd issue which MAY be a driver/mesa problem but I can’t quite understand it,.
The problem occurs normally after I leave the desktop idle for a while, or if the screen goes to lock-screen. I’ve since turned off energy saving on screen because when that triggers it also.
The way to resolve the bug is to set 30hz, then back to 60hz again. I have tearfree and variable refresh toggled on in the xorg conf.
Seems there is a driver or kwin bug happening. I am using kwin-lowlatency btw.
If anyone else gets this sort of issue with amdgpu please do tell. I may only affect NAVI2 cards, or perhaps it happens to navi1 also? I do not know.
Can confirm this seems to be a freesync issue, I’ve see variations of this happening on my nvidia 1080ti but it was not consistent and didn’t happen too often.
It seems AMDGPU freesync however will cause this issue to happen all the time if you turn off the display for long enough and then re-enable it.
Could probably be fixed, but perhaps its unique to my particular display which is a QNIX 40" 4k@60hz curved display (no longer sold).
Hey there, I have exactly the same issue with my new screen when FreeSync is turned on. I’m using an Asus VG249Q1R and a 5600XT on Kubuntu 20.04 so it does not seem to be screen or environment related, rather a driver/OS bug. I already activated VRR and Tearfree in the 10-amdgpu.conf.
To which mesa and kernel version did you update @theriddick?
