Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=40809886-d17c-433b-876f-89a03d053b64 rw quiet splash apparmor=1
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
base: Arch Linux
Type: Desktop System: Gigabyte product: AB350-Gaming v: N/A
serial: <superuser required>
Mobo: Gigabyte model: AB350-Gaming-CF v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F21 date: 02/08/2018
System RAM: total: 16 GiB available: 15.57 GiB used: 3.59 GiB (23.1%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
part-no: UD4-3000 serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001129
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 2486 high: 3393 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3257 2: 3337
3: 2706 4: 1550 5: 1357 6: 1357 7: 1357 8: 1356 9: 3387 10: 3392 11: 3393
12: 3393 bogomips: 76671
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm
lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit
smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 08:00.0 chip-ID: 10de:1c02
class-ID: 0300
Device-2: Logitech CrystalCam driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 046d:0894
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.12 with: Xwayland v: 23.2.6
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
screens: 1
Screen-1: 0 s-res: 3840x1215 s-dpi: 96 s-size: 1016x321mm (40.00x12.64")
s-diag: 1066mm (41.95")
Monitor-1: DVI-D-0 pos: primary,top-left res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-2: HDMI-0 pos: bottom-r res: 1920x1080 hz: 75 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
memory: 2.93 GiB
API: Vulkan v: 1.3.279 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 3GB driver: nvidia v: 550.67 device-ID: 10de:1c02
surfaces: xcb,xlib
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 08:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
chip-ID: 1022:1457 class-ID: 0403
Device-3: Logitech CrystalCam driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off with: 1: a2jmidid status: off 2: nsmd
status: off tools: cadence,jack_control,jack_mixer,qjackctl
Server-3: PipeWire v: 1.0.3 status: active with: 1: pipewire-media-session
status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli
Server-4: PulseAudio v: 17.0 status: active with: pulseaudio-jack
type: module tools: pacat,pactl,pavucontrol
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter
driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 07:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0b05:190e
Report: hciconfig ID: hci0 rfk-id: 1 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Info: acl-mtu: 1021:6 sco-mtu: 255:12 link-policy: rswitch hold sniff park
link-mode: peripheral accept
Local Storage: total: 3.41 TiB used: 1.21 TiB (35.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZAZ-00L9GB0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3500312CS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5900 serial: <filter> fw-rev: CA12 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 EVO 1TB
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH30N rev: A201
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 178.51 GiB (78.3%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 40809886-d17c-433b-876f-89a03d053b64
used: 80.3 MiB (26.8%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: E832-7B45
ID-3: /run/media/nicholas/fourth-disk raw-size: 931.51 GiB
size: 915.82 GiB (98.31%) used: 778.12 GiB (85.0%) fs: ext4 dev: /dev/sdd
maj-min: 8:48 label: fourth-disk uuid: 1be4d25b-4ff6-40b0-a5c7-dfe6cc409b83
ID-4: /run/media/nicholas/second disk raw-size: 434.51 GiB
size: 426.62 GiB (98.18%) used: 266.57 GiB (62.5%) fs: ext4 dev: /dev/sdc2
maj-min: 8:34 label: second disk uuid: 1ec047b4-ec64-4d28-8893-f16ad7899256
ID-5: /run/media/nicholas/third-disk raw-size: 1.82 TiB
size: 1.79 TiB (98.37%) used: 17.72 GiB (1.0%) fs: ext4 dev: /dev/sda
maj-min: 8:0 label: third-disk uuid: 31f2d06a-293c-46c3-9216-27dc993cfb4e
ID-1: /dev/sdc1 maj-min: 8:33 size: 31.25 GiB fs: swap label: N/A
uuid: 14863704-322a-453c-b7a5-87bba34bb094
Device-1: 1-1:2 info: ASUSTek ASUS USB-BT500 type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
Device-2: 1-2:3 info: Logitech CrystalCam type: video,audio
chip-ID: 046d:0894 class-ID: 0102 serial: <filter>
Device-1: 3-3:2 info: Ducky One 3̠ type: HID,keyboard,mouse
driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:1011 class-ID: 0300
serial: <filter>
Device-2: 3-4:3 info: Logitech G502 Proteus Spectrum Optical Mouse
type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
chip-ID: 046d:c332 class-ID: 0300 serial: <filter>
Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 43.2 C mobo: 28.0 C
Fan Speeds (rpm): cpu: 0 fan-1: 0 fan-3: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.38 vbat: 3.27
Processes: 387 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.22 GiB services: gsd-power,
tool: systemctl
Packages: 2490 pm: pacman pkgs: 2476 libs: 617 tools: gnome-software,pamac
pm: flatpak pkgs: 5 pm: snap pkgs: 9 Compilers: clang: 16.0.6 gcc: 13.2.1
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.34
For the past week or so whenever pamac has an update it will display a bar that goes across the entirety of the top of my main monitor. It is about two inches from top to bottom and takes up a huge amount of space. I’ve recreated the look using gedit, I haven’t thought to screenshot it when it happens.
Today I booted up my computer and my backgrounds were gone and replaced with a white screen.
Why might this be happening?
