Hello,
I have recently made the full dive and installed Manjaro as my daily driver OS and have been quite pleased with the change so far. Manjaro is installed on its own SSD in my desktop with a dual-boot option for Windows on another drive. I have an odd issue with the bluetooth adapter in my system not being detected or enabled correctly on a cold boot or normal restart from Linux. However if I boot into my old Windows install the bluetooth is working / detected. If I then restart from Windows and boot directly into Manjaro the bluetooth adapter will magically work… until I shutdown/reboot the system again.
I have a Gigabyte GA-Z370X-Gaming 5 motherboard that has an integrated Wifi and bluetooth combo card. If my google-fu was correct this is an “Intel Dual Band Wireless-AC 3165” card. I read a post with a very similar sounding issue that was resolved by a driver/firmware update. I tried installing the latest drivers directly from Intel on Windows (to hopefully update the cards firmware) but no changes for me. My systems BIOS is up to date.
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=ccc24a42-826a-44c9-8c68-b785d760dd90 rw quiet
resume=UUID=364f8a8c-f233-48d0-94c7-a71959bc5d1e udev.log_priority=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: Z370 AORUS Gaming 5 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z370 AORUS Gaming 5-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F15a
date: 11/28/2019
RAM: total: 15.56 GiB used: 4.01 GiB (25.8%)
Info: 6-Core model: Intel Core i7-8700K bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB bogomips: 88824
Speed: 4318 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 4318 2: 4436
3: 4405 4: 4396 5: 4406 6: 4423 7: 4371 8: 4366 9: 4400 10: 4401 11: 4400
12: 4400
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nvidia
v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1b81
class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 3840x1200 s-dpi: 93 s-size: 1049x321mm (41.3x12.6")
s-diag: 1097mm (43.2")
Monitor-1: DP-3 res: 1920x1200 hz: 60 dpi: 94 size: 518x324mm (20.4x12.8")
diag: 611mm (24.1")
Monitor-2: DP-5 res: 1920x1200 hz: 60 dpi: 94 size: 518x324mm (20.4x12.8")
diag: 611mm (24.1")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44
direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f0
class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel bus-ID: 09:00.0
chip-ID: 8086:3165 class-ID: 0280
IF: wlp9s0 state: down mac: <filter>
bus-ID: 1-2:2 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 2.48 TiB used: 143.73 GiB (5.7%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Samsung model: SSD 960 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7 temp: 36.9 C scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Intel model: SSDPEKKW512G7
lanes: 4 type: SSD serial: <filter> rev: PSF100C temp: 40.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2KB960G8
size: 894.25 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0110 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NS95 rev: RN01
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
Optical-2: /dev/sr1 vendor: HL-DT-ST model: BD-RE WH14NS40 rev: 1.00
dev-links: N/A
ID-1: / raw-size: 223.79 GiB size: 219.22 GiB (97.96%)
used: 19.99 GiB (9.1%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: ccc24a42-826a-44c9-8c68-b785d760dd90
used: 292 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: B8BD-FE58
ID-3: /run/media/nimrod/Games raw-size: 931.51 GiB size: 915.81 GiB (98.31%)
used: 123.7 GiB (13.5%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:7
label: Games uuid: 81d26fa7-87aa-4c43-86ec-a7ccc6eee8c8
ID-1: swap-1 type: partition size: 8.8 GiB used: 46.8 MiB (0.5%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: swap
uuid: 364f8a8c-f233-48d0-94c7-a71959bc5d1e
ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 499 MiB fs: ntfs label: N/A
uuid: F834E51C34E4DE9E
ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 99 MiB fs: vfat label: N/A
uuid: 086E-A4B4
ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 475.8 GiB fs: ntfs label: N/A
uuid: C8A673E6A673D382
ID-5: /dev/nvme1n1p5 maj-min: 259:5 size: 553 MiB fs: ntfs label: N/A
uuid: 66CA6596CA656373
ID-6: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-7: /dev/sda2 maj-min: 8:2 size: 894.24 GiB fs: exfat label: Data
uuid: D0C2-1E84
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-2:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-13:3 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Device-3: 1-14:4 info: Corsair CORSAIR K68 RGB Mechanical Gaming Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b4f class-ID: 0300
serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
systemctl status bluetooth shows the service is running normally:
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Sun 2021-11-28 15:45:36 MST; 3h 24min ago
Docs: man:bluetoothd(8)
Main PID: 874 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 19102)
Memory: 2.1M
CPU: 10ms
CGroup: /system.slice/bluetooth.service
└─874 /usr/lib/bluetooth/bluetoothd
The bluetooth menu shows “No adapters available” and bluetoothctl commands give the error “No default controller available”. The wifi connection works normally, although I am not using it. There are no rfkill blocks on the bluetooth.
Not sure what could cause this or what to try next. Thanks alot for your time and help!
