Octopi Cache Cleaner strange behavior
Plasma 6 Testing branch
I’m experiencing a strange behavior when I open Octopi Cache Cleaner
for example yesterday I’ve clean pacman cache and this morning I deed get an update of Vivaldi, after update I open OCC and looking inside I ca see this:
OCC1
this is only a part, totally there are 66 continuously repeating showing 4.96 GB
can you imagine when I keep 2 pkg how long and big is the list
but if I look in /var/cache/pacman/pkg I can see only 1 tar.zst an his signature for a total of 159 MB…
is there something strange from my side or I’m missing something?
Check the Keep number below each window.
uninstalled pkg 0
installed pkg 0
is sometime I’m experiencing this…
Hmm - then I have no ideas - the Keep was the obvious - especially after checking on my system.
I had 7.8G - they vanished completely.
maybe my problem related to pacman.conf?
It is very long, repeating many many times…
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
IgnorePkg =
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
#HookDir     = /etc/pacman.d/hooks/
HoldPkg      = pacman glibc manjaro-system
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta    = 0.7
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
ParallelDownloads = 4
ILoveCandy
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel    = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
IgnorePkg =
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
should I delet all except the first part?
In any case, regardless of octopi cache cleaner, your pacman.conf should not be like that and could cause any number of problems.
No.
Considering only the ‘final’ entry looks complete and includes the repositories.
Your pacman.conf does include duped content.
Default pacman.conf
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir     = /
#CacheDir    = /var/cache/pacman/pkg/
Architecture = auto
#IgnorePkg   =
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
DownloadUser = alpm
#DisableSandbox
# keyring can then be populated with the keys of all official Arch and Manjaro Linux
# REPOSITORIES
#       [repo-name]
[core]
[extra]
[multilib]
#[custom]
thanks, that solved also the octopi cache cleaner problem :smiley:
anyway I can’t figure out how pacman.conf became that way… :confused:
should I also insert
DownloadUser = alpm
#DisableSandbox
That is part of pacman 7 configuration - so yes.
Have you at some point been merging pacman.conf.pacnew? Because that may explain how your pacman.conf got messy - if it was not merged correct.
no I deed not merge
that time Philm told
 Manual intervention is only required for users with local repos
AFAIK I don’t have local repos… if I have understood well
I’ve anyway inserted your suggestion :smiley:
Nonetheless - you need the lines mentioned in pacman.conf.
Only if you have local repos - you would have needed to uncomment #DisableSandbos - that was the manual intervention you read.
