Hi,
After a recent update, I started running into issues with my laptop’s (Razer Blade Pro 17 '19 Model) keyboard.
Whenever I stop typing for more than ~5s, it will lag for about 1-2s and then register the last input as a double click.
For example, if I start writing a word it would look something like “MManjaro”, with the first “M” appearing on-screen with 1-2s delay.
I tried looking through the journal but could not find anything. However, I noticed that when I connect to the external monitor the issue disappears. Because of this, I suspect there is an issue with either X11 setup or some Nvidia driver settings.
I’m not sure if this will be useful or not, but from what I understand the built-in display is connected to integrated intel graphics, while all display port/hdmi connections are run through discrete nvidia gpu. Again, not sure if this might be the cause of the issue, but since there is weird behavior with connecting external display I thought it might be important.
inxi -Fazy
Kernel: 5.10.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=6e95cc28-0294-481f-b4d7-5957bfcfddb3 rw quiet apparmor=1
security=apparmor resume=UUID=8c65b7ac-c936-4668-a90c-996aa1d919a8
udev.log_priority=3 button.lid_init_state=open acpi=on usbhid.kbpoll=1
usbhid.mousepoll=1
Desktop: GNOME 3.38.3 tk: GTK 3.24.26 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Laptop System: Razer product: Blade Pro 17 (Fall 2019) v: 3.04
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Razer model: DA730 serial: <filter> UEFI: Razer v: 1.02
date: 08/22/2019
ID-1: BAT0 charge: 67.5 Wh condition: 70.3/70.6 Wh (100%) volts: 17.6/15.4
model: Razer Blade type: Unknown serial: <filter> status: Charging
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE L2 cache: 12 MiB
bogomips: 62431
Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Razer USA driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b class ID: 0300
Device-2: NVIDIA TU104M [GeForce RTX 2080 Mobile] vendor: Razer USA
driver: nvidia v: 460.56 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1e90 class ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus ID: 1-7:3 chip ID: 13d3:56d5 class ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: modesetting,nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: GeForce RTX 2080 with Max-Q Design/PCIe/SSE2
v: 4.6.0 NVIDIA 460.56 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Razer USA driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348 class ID: 0403
Sound Server: ALSA v: k5.10.19-1-MANJARO
Device-1: Realtek RTL8125 2.5GbE vendor: Razer USA driver: r8169 v: kernel
port: 3000 bus ID: 3d:00.0 chip ID: 10ec:8125 class ID: 0200
IF: enp61s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 3000
bus ID: 3f:00.0 chip ID: 8086:2723 class ID: 0280
IF: wlp63s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus ID: 1-14:5 chip ID: 8087:0029 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 1.4 TiB used: 127.45 GiB (8.9%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: MZVLB512HAJQ-00000
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: EXA7301Q temp: 46.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: N/A
size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: ECFM12.3 temp: 27.9 C
scheme: GPT
ID-1: / raw size: 944.77 GiB size: 928.94 GiB (98.32%)
used: 127.45 GiB (13.7%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:3
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
dev: /dev/nvme1n1p3 maj-min: 259:4
System Temperatures: cpu: 61.0 C mobo: N/A gpu: nvidia temp: 51 C
Processes: 354 Uptime: 24m wakeups: 3 Memory: 15.54 GiB
used: 4.14 GiB (26.7%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.1.0 Packages: 1483 pacman: 1471 lib: 458 flatpak: 0 snap: 12
Shell: Zsh v: 5.8 running in: tilix inxi: 3.3.01
I’m also attaching X11 xorg conf file: /etc/X11/xorg.conf
Section "ServerLayout"
Identifier "layout"
Screen 0 "intel"
Inactive "nvidia"
Option "AllowNVIDIAGPUScreens"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
EndSection
Section "Device"
Identifier "intel"
Driver "modesetting"
BusID "<BusID for Intel device here>"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
