Heya folks. The freezes started when I upgraded from my good ol’ 960 to a 3080, and updated to 5.10, now on 5.12. I’ve got Nvidia’s 465.31 drivers, and the issue is less frequent than it was on 5.10, but still happens.
Somehow interacting with chromium apps such as Discord, Chrome, Spotify, etc, seems to increase the frequency of the freezes and accelerate total driver freeze.
I’ve been searching far and wide for a solution. Based on some other similar threads on this forum, I’ve tried swapping from three screens with DisplayPort, to a single screen using HDMI, but that did not change the outcome.
Any help would be most appreciated!
Kernel: 5.12.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=a8c4d25e-f525-4e3d-9432-4051aab8705c rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
serial: <filter>
Mobo: Gigabyte model: X570 AORUS ELITE serial: <filter>
UEFI: American Megatrends v: F31o date: 12/03/2020
RAM: total: 31.36 GiB used: 2.88 GiB (9.2%)
Info: 12-Core model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache:
L2: 6 MiB bogomips: 177339
Speed: 2821 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
1: 2821 2: 1999 3: 3479 4: 2784 5: 2191 6: 2527 7: 2801 8: 2759 9: 2401
10: 2049 11: 2025 12: 2061 13: 2761 14: 2110 15: 2108 16: 2486 17: 2633
18: 2511 19: 2805 20: 2817 21: 2868 22: 2502 23: 3119 24: 2371
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: Micro-Star MSI
driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 0a:00.0
chip-ID: 10de:2206 class-ID: 0300
Device-2: Microdia Webcam Vitade AF type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 5-3.2:4 chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 7680x1440 s-dpi: 96 s-size: 2032x381mm (80.0x15.0")
s-diag: 2067mm (81.4")
Monitor-1: DP-0 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-2: DP-2 res: 2560x1440 hz: 120 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-3: DP-4 res: 2560x1440 hz: 120 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31
direct render: Yes
Device-1: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 0a:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Logitech Blue Microphones type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-3.1:3 chip-ID: 046d:0ab7
class-ID: 0300 serial: <filter>
Device-4: Microdia Webcam Vitade AF type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.12.8-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.27 running: no
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: f000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: f000
bus-ID: 06:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
IF-ID-1: br-7c89ed6305cf state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Local Storage: total: 2.96 TiB used: 34.49 GiB (1.1%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 2B2QEXM7 scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
rev: 2B2QEXM7 scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-00BN5A0
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 34.49 GiB (3.8%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:6
label: N/A uuid: a8c4d25e-f525-4e3d-9432-4051aab8705c
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
label: NO_LABEL uuid: C4F4-5019
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 50 MiB fs: ntfs
label: System Reserved uuid: CAD09282D0927483
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 930.97 GiB fs: ntfs label: N/A
uuid: 664493C344939481
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 499 MiB fs: ntfs label: N/A
uuid: FC14EE2014EDDDA0
ID-4: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: ntfs label: Recovery
uuid: 4AEC9605EC95EC07
ID-5: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: 8A97-6886
ID-6: /dev/sda3 maj-min: 8:3 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-7: /dev/sda4 maj-min: 8:4 size: 43.86 GiB fs: ext4 label: N/A
uuid: ed2cb823-a9d1-4473-b726-7dcbdcfc0c68
ID-8: /dev/sda5 maj-min: 8:5 size: 543 MiB fs: ntfs label: N/A
uuid: 3E9EB7DB9EB78A43
ID-9: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
ID-10: /dev/sdb2 maj-min: 8:18 size: 931 GiB fs: ntfs label: MATERIAL PLANE
uuid: C602C0D502C0CC1D
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-4:3 info: Integrated Express IT8297 RGB LED Controller
type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-5: 3-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-8: 5-3:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 5-3.1:3 info: Logitech Blue Microphones type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 046d:0ab7 class-ID: 0300
serial: <filter>
Device-2: 5-3.2:4 info: Microdia Webcam Vitade AF type: Video,Audio
power: 500mA chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
Device-3: 5-3.3:5 info: Razer USA DeathAdder Elite type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:005c class-ID: 0300
Device-4: 5-3.4:6 info: Kingston HyperX Alloy FPS Mechanical Gaming Keyboard
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0951:16b7 class-ID: 0301
Hub-9: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-10: 6-3:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
System Temperatures: cpu: 44.1 C mobo: 16.8 C gpu: nvidia temp: 53 C
Processes: 411 Uptime: 34m wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 1235 lib: 330 flatpak: 0 Shell: Zsh
v: 5.8 running-in: xfce4-terminal inxi: 3.3.04
