inxi -zv8 ✔
Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=46cd7c27-c44c-4f3e-b31f-c78a397024d8 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
Type: Desktop Mobo: ASRock model: B450M Pro4 R2.0
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: P5.70 date: 10/20/2022
System RAM: total: 32 GiB available: 31.27 GiB used: 9.86 GiB (31.5%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 16 GiB speed: 3134 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK32GX4M2D3600C18 serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4099 min/max: 550/4793 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4099 2: 4099 3: 4099
4: 4099 5: 4099 6: 4099 7: 4099 8: 4099 9: 4099 10: 4099 11: 4099 12: 4099
bogomips: 98446
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
xtopology
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] vendor: ZOTAC
driver: nvidia v: 580.82.09 alternate: nouveau,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-08; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: none off: DP-1,DP-2,HDMI-A-1 empty: DP-3 bus-ID: 07:00.0
chip-ID: 10de:2489 class-ID: 0300
Device-2: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2
chip-ID: 0c45:6536 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 4890x1680 s-dpi: 88 s-size: 1409x484mm (55.47x19.06")
s-diag: 1490mm (58.65")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,bottom-c
model: Samsung LS27AG30x serial: <filter> built: 2022 res: mode: 1920x1080
hz: 144 scale: 100% (1) dpi: 82 gamma: 1.2 chroma: red: x: 0.682 y: 0.310
green: x: 0.275 y: 0.651 blue: x: 0.149 y: 0.067 white: x: 0.314 y: 0.329
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
Monitor-2: DP-2 mapped: DP-3 note: disabled pos: middle-l model: HP LP2465
serial: <filter> built: 2006 res: mode: 1920x1200 hz: 60 scale: 100% (1)
dpi: 94 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.608
blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 519x324mm (20.43x12.76") diag: 616mm (24.2") ratio: 16:10
modes: 1920x1200, 1600x1200, 1680x1050, 1600x1000, 1280x1024, 1280x960,
1152x720, 1024x768, 800x600, 640x480
Monitor-3: HDMI-A-1 mapped: HDMI-0 note: disabled pos: top-right
model: Samsung SMS22A450 serial: <filter> built: 2012 res: mode: 1680x1050
hz: 60 scale: 160% (0.625) to: 1050x1680 dpi: 93 gamma: 1.2 chroma: red:
x: 0.643 y: 0.333 green: x: 0.298 y: 0.608 blue: x: 0.145 y: 0.055 white:
x: 0.329 y: 0.329 size: 459x296mm (18.07x11.65") diag: 558mm (22")
ratio: 16:10, 3:2 modes: 1680x1050, 1280x1024, 1440x900, 1280x960,
1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.82.09
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.4.321 layers: 9 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 580.82.09 device-ID: 10de:2489
surfaces: N/A
Device-1: NVIDIA GA104 High Definition Audio vendor: ZOTAC
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 10de:228b
class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Medeli KRUX EDIS 1000 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3
chip-ID: 0a67:d064 class-ID: 0300 serial: <filter>
Device-4: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
Device-5: Corsair VOID ELITE Wireless Gaming Dongle
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 1b1c:0a51 class-ID: 0300
API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 2.07 TiB used: 482.68 GiB (22.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 42.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: GOODRAM model: SSDPR-CX400-01T-G2
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 546 scheme: GPT
ID-1: / raw-size: 638.01 GiB size: 626.92 GiB (98.26%)
used: 482.68 GiB (77.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 46cd7c27-c44c-4f3e-b31f-c78a397024d8
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: N/A
uuid: 6238-E3A0
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 292.66 GiB fs: ntfs label: N/A
uuid: 3C047D8F047D4CC0
ID-3: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: 72E2-E0D6
ID-4: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sda3 maj-min: 8:3 size: 199.66 GiB fs: ntfs label: N/A
uuid: 583CE5073CE4E14C
ID-6: /dev/sda4 maj-min: 8:4 size: 519 MiB fs: ntfs label: N/A
uuid: 3A8471A484716375
ID-7: /dev/sda5 maj-min: 8:5 size: 32.6 GiB fs: ntfs label: N/A
uuid: 2E7EF8657EF8276D
ID-8: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-9: /dev/sdb2 maj-min: 8:18 size: 953.85 GiB fs: ntfs label: New Volume
uuid: 180ED5440ED51B96
Device-1: 1-4:2 info: Micro Star MSI GK50 ELITE Gaming Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 0db0:0b5b class-ID: 0300
Device-2: 1-5:3 info: Medeli KRUX EDIS 1000 type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Device-1: 3-1:2 info: Microdia USB Live camera type: video,audio
driver: snd-usb-audio,uvcvideo interfaces: 5 rev: 2.0
Device-2: 3-2:3 info: Corsair VOID ELITE Wireless Gaming Dongle
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Device-3: 3-3:4 info: Endgame Gear WE Series Gaming Receiver
type: mouse,keyboard driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 3367:1961 class-ID: 0301
System Temperatures: cpu: 62.8 C mobo: N/A gpu: nvidia temp: 67 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 74%
Packages: 2003 pm: pacman pkgs: 1979 libs: 428 tools: pamac,yay pm: flatpak
pkgs: 24
1: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
2: https://mirror.koddos.net/manjaro/stable/$repo/$arch
3: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
4: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
5: https://manjaro.grena.ge/stable/$repo/$arch
6: https://mirror.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
8: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 420
1: cpu: 412%
command: Z:\home\layla\Games\Heroic\Satisfactory\Engine\Binaries\Win64\FactoryGameEGS-Win64-Shipping.exe
pid: 15491 mem: 3041.8 MiB (9.4%)
2: cpu: 46.6% command: Proton pid: 15283 mem: 17.3 MiB (0.0%)
3: cpu: 22.7% command: firefox pid: 14532 mem: 861.7 MiB (2.6%)
4: cpu: 17.3% command: Xorg pid: 802 mem: 156.5 MiB (0.4%)
5: cpu: 13.3% command: Discord pid: 1479 mem: 288.4 MiB (0.9%)
Memory top: 5 of 420
1: mem: 3041.8 MiB (9.4%)
pid: 15491 cpu: 412%
2: mem: 861.7 MiB (2.6%) command: firefox pid: 14532 cpu: 22.7%
3: mem: 828.3 MiB (2.5%) command: plasmashell pid: 1105 cpu: 0.3%
4: mem: 683.6 MiB (2.1%) command: exe pid: 1608 cpu: 9.9%
5: mem: 568.7 MiB (1.7%) command: baloo_file_extractor pid: 1282 cpu: 0.6%
Processes: 420 Power: uptime: 2h 59m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 20.1.8 gcc: 15.2.1 alt: 13/14 Shell: Zsh v: 5.9
default: Bash v: 5.3.3 running-in: konsole inxi: 3.3.39
Thanks, here is the extra info, I have plenty of free space so I doubt it’s that.
