Hallo zusammen,
nach dem Update von Manjaro stürzt mein OBS Studi direkt nach dem Start ab.
Ich habe das ganze in einer VM zuätzlich getestet. Auch hier stützt das Toll sofort ab.
Hat ein anderer diese Probleme auch? und wie kann man das lösen. Habe OBS schon neu installiert , ohne Erfolg.
[stefan@manjaro ~]$ obs
Attempted path: share/obs/obs-studio/locale/en-US.ini
Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
Attempted path: share/obs/obs-studio/locale.ini
Attempted path: /usr/share/obs/obs-studio/locale.ini
Attempted path: share/obs/obs-studio/locale/de-DE.ini
Attempted path: /usr/share/obs/obs-studio/locale/de-DE.ini
info: Using preferred locale 'de-DE'
Attempted path: share/obs/obs-studio/themes/Dark.qss
Attempted path: /usr/share/obs/obs-studio/themes/Dark.qss
info: CPU Name: Intel(R) Core(TM) i5-3320M CPU @ 2.60GHz
info: CPU Speed: 2803.305MHz
info: Physical Cores: 2, Logical Cores: 4
info: Physical Memory: 7844MB Total, 263MB Free
info: Kernel Version: Linux 5.9.16-1-MANJARO
info: Distribution: "Manjaro Linux" Unknown
info: Session Type: x11
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.20.10
info: Portable mode: false
Attempted path: share/obs/obs-studio/themes/Dark/no_sources.svg
Attempted path: /usr/share/obs/obs-studio/themes/Dark/no_sources.svg
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_clicked()
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_destroyed()
QMetaObject::connectSlotsByName: No matching signal for on_actionGridMode_triggered()
QMetaObject::connectSlotsByName: No matching signal for on_program_customContextMenuRequested(QPoint)
QMetaObject::connectSlotsByName: No matching signal for on_transitionRemove_clicked()
info: OBS 26.1.2-1 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 48000
speakers: 2
info: Initializing OpenGL...
info: Loading up OpenGL on adapter Intel Open Source Technology Center Mesa DRI Intel(R) HD Graphics 4000 (IVB GT2)
info: OpenGL loaded successfully, version 4.2 (Core Profile) Mesa 20.3.4, shading language 4.20
info: video settings reset:
base resolution: 1920x1080
output resolution: 1280x720
downscale filter: Bicubic
fps: 30/1
format: NV12
YUV mode: 709/Partial
info: NV12 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-ouput-ui.so'
libDeckLinkAPI.so: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
warning: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
info: No blackmagic support
warning: v4l2loopback not installed, virtual camera disabled
error: os_dlopen(libnvidia-encode.so.1->libnvidia-encode.so.1): libnvidia-encode.so.1: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
info: FFMPEG VAAPI supported
info: VLC found, VLC video source enabled
info: Loaded Modules:
info: vlc-video.so
info: text-freetype2.so
info: rtmp-services.so
info: obs-x264.so
info: obs-transitions.so
info: obs-outputs.so
info: obs-libfdk.so
info: obs-filters.so
info: obs-ffmpeg.so
info: linux-v4l2.so
info: linux-pulseaudio.so
info: linux-jack.so
info: linux-decklink.so
info: linux-capture.so
info: linux-alsa.so
info: image-source.so
info: frontend-tools.so
info: decklink-ouput-ui.so
info: decklink-captions.so
info: ==== Startup complete ===============================================
info: All scene data cleared
info: ------------------------------------------------
info: pulse-input: Server name: 'pulseaudio 14.2'
info: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
info: pulse-input: Started recording from 'alsa_input.usb-RODE_Microphones_RODE_NT-USB-00.analog-stereo'
info: [Loaded global audio device]: 'Mikrofon/AUX‐Audio'
info: - filter: 'Noise Suppression' (noise_suppress_filter)
info: - filter: 'Noise Gate' (noise_gate_filter)
info: - filter: 'Gain' (gain_filter)
info: - filter: 'Kompressor' (compressor_filter)
info: - filter: 'Expander' (expander_filter)
info: - filter: 'Limiter' (limiter_filter)
info: [Media Source 'Medienquelle']: settings:
input:
input_format: (null)
speed: 100
is_looping: no
is_hw_decoding: no
is_clear_on_media_end: yes
restart_on_activate: yes
close_when_inactive: no
info: v4l2-input: Start capture from /dev/video2
info: v4l2-input: Input: 0
info: v4l2-input: Resolution: 1280x720
info: v4l2-input: Pixelformat: YUYV
info: v4l2-input: Linesize: 2560 Bytes
info: v4l2-input: Framerate: 10,00 fps
info: v4l2-input: Start capture from /dev/video5
error: v4l2-input: Unable to open device
error: v4l2-input: Initialization failed
info: [Media Source 'Videostarttimer']: settings:
input: /home/stefan/Bilder/RalfKöpke/HofgesrächeNr.3/timer_10_Minuten.mkv
speed: 100
is_looping: no
is_hw_decoding: no
info: Switched to scene 'Ralf 3'
info: Loaded scenes:
info: - scene 'Start':
info: - source: 'Bild' (image_source)
info: - source: 'Videostarttimer' (ffmpeg_source)
info: - scene 'Ralf 3':
info: - source: 'Camcorder' (v4l2_input)
info: - filter: 'Renderverzögerung' (gpu_delay)
info: - source: 'Webcam Weitwinkel' (v4l2_input)
info: - filter: 'Chroma Key' (chroma_key_filter)
info: - filter: 'Color Key' (color_key_filter)
info: - source: 'Sahra Wagenknecht' (image_source)
info: - source: 'Moderation' (image_source)
info: - source: 'Annelie Buntenbach' (image_source)
info: - source: 'Ralf Koepke' (image_source)
info: - source: 'Lauftexthintergrund' (image_source)
info: - source: 'Lauftext' (text_ft2_source_v2)
info: - filter: 'Bewegung' (scroll_filter)
info: - source: 'Logo' (image_source)
info: - source: 'begüßen' (image_source)
info: - source: 'Medienquelle' (ffmpeg_source)
info: - source: 'VLC-Videoquelle 2' (vlc_source)
info: - scene 'Stoerung':
info: - source: 'Störung' (image_source)
info: - scene 'Ende':
info: - source: 'Abspann' (image_source)
info: - scene 'webcamtest':
info: - source: 'hintergrund' (image_source)
info: - source: 'Logofahl' (image_source)
info: - source: 'VLC-Videoquelle' (vlc_source)
"/proc/6398/root"
qt.qpa.xcb: QXcbConnection: XCB error: 5 (BadAtom), sequence: 1191, resource id: 0, major code: 20 (GetProperty), minor code: 0
Attempted path: share/obs/obs-studio/images/overflow.png
Attempted path: /usr/share/obs/obs-studio/images/overflow.png
Speicherzugriffsfehler (Speicherabzug geschrieben)
ournalctl -p err -b
– Journal begins at Tue 2021-02-02 03:40:35 CET, ends at Thu 2021-02-11 08:32:35 CET. –
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:2 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:4 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:6 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:8 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:10 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:12 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:14 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:16 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:18 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:20 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:22 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:24 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:26 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:28 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:30 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:32 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:34 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:36 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:38 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:40 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:42 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:44 Invalid key/value pair, ignoring.
Feb 11 08:19:16 manjaro systemd-udevd[306]: /etc/udev/rules.d/99-android.rules:46 Invalid key/value pair, ignoring.
