I am a new user of Manjaro KDE. I used to use OBS studio for recording purposes, but on manjaro its "windows capture " feature is not working
I’ve attached some screenshots
OBS studio version: 26.0.2-2
Pls help
Looks like it works just fine. It’s capturing the window as far as I can see.
It only captures the OBS main window and properties window.
IN windows setting you can see an unknown name.
Do you have other windows open?
Are you running under wayland?
Is OBS from the repo, Flathub, Snap or AppImage?
Yes I do have terminal and telegram open but they are not showing up in windows menu.
How to check if I am running under wayland.
I installed OBS from official repo
I tried installing OBS from flatpak and snap but the issue still persists.
Run inxi -Gazy.
I ran inxi -Gazy
Following is the output:
Device-1: NVIDIA GP107M [GeForce GTX 1050 3 GB Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 455.45.01
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1c91
Device-2: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel
bus ID: 05:00.0 chip ID: 1002:15d8
Device-3: IMC Networks HP TrueVision HD Camera type: USB driver: uvcvideo
bus ID: 3-1:2 chip ID: 13d3:56c9 serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
driver: amdgpu,ati,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
M onitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.35.0
5.4.80-2-MANJARO LLVM 11.0.0)
v : 4.6 Mesa 20.2.3 direct render: Yes
Its X11
Is your problem solved, because I have the exact same issue and havent found any workaround for this. Also I cannot stream a particular window in Discord, so maybe its not a bug from OBS’s side. Might be something else.
