I previously posted an issue in the OBS studio GitHub here: https://github.com/obsproject/obs-studio/issues/3368
When I follow the steps provided in that link, the UI ends up getting garbled.
One of the contributors in OBS’s GitHub closed the issue, replying that Manjaro is not officially supported by the software and that I should bring this to the attention of Manjaro’s package manager.
I can’t embed media in posts yet in this forum, so I will have to refer you to the link above for a screen shot.
I downloaded OBS using Pamac.
Hello,
Right, but you can include
inxi -Fxza --no-host
I can notice you are using XFCE and the default theme of OBS, have you tried with System Theme?
Do you have any custom scaling settings?
I just tried it with the system theme and the same issue occurs.
Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=78fce5c0-25d2-4c26-805d-42d8abde9dfe rw quiet apparmor=1
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: HP product: HP Laptop 15-dy1xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 86C9 v: 56.21 serial: <filter> UEFI: AMI v: F.07
date: 10/18/2019
ID-1: BAT0 charge: 38.2 Wh condition: 37.9/37.9 Wh (100%) volts: 12.8/11.6
model: HP Primary type: Li-ion serial: N/A status: Unknown
Topology: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: 78
L2 cache: 8192 KiB
bogomips: 23968
Speed: 1144 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1098 2: 1199
3: 988 4: 1159 5: 1195 6: 1154 7: 1119 8: 1135
Device-1: Intel Iris Plus Graphics G7 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:8a52
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus ID: 1-3:3 chip ID: 0408:5365
Display: x11 server: X Org 1.20.8 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2)
v: 4.6 Mesa 20.1.6 direct render: Yes
Device-1: Intel Smart Sound Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:34c8
Sound Server: ALSA v: k5.8.3-2-MANJARO
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8821ce v: N/A modules: 8821ce
port: 3000 bus ID: 01:00.0 chip ID: 10ec:c821
Device-2: ASIX AX88772B type: USB driver: asix bus ID: 1-1:2
chip ID: 0b95:772b serial: <filter>
IF: enp0s20f0u1 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 953.87 GiB used: 64.01 GiB (6.7%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 002C scheme: GPT
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus ID: 00:17.0 chip ID: 8086.282a rev: 30
ID-1: / raw size: 951.07 GiB size: 935.64 GiB (98.38%)
used: 63.96 GiB (6.8%) fs: ext4 dev: /dev/nvme0n1p4
ID-1: swap-1 type: partition size: 2.00 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p5
System Temperatures: cpu: 50.0 C mobo: N/A
Processes: 250 Uptime: 2d 14h 38m Memory: 23.25 GiB used: 3.56 GiB (15.3%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: apt: 0 pacman: 1263
lib: 379 flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal
inxi: 3.1.05
Remove any other drivers from MHWD UI, and keep just video-modestetting
You might need this lines in /etc/X11/xorg.conf.d/20-intel.conf
Section "Device"
Identifier "Intel Graphics"
Driver "intel"
Option "TearFree" "true"
EndSection
That might add a fluctuating brightness thing, so you have to add to /usr/share/X11/xorg.conf.d/10-quirks.conf this lines at the end:
Section "InputClass"
Identifier "Spooky Ghosts"
MatchProduct "Video Bus"
Option "Ignore" "on"
EndSection
Edited the INXI for proper formatting
If I remove video-linux, lightdm fails to start.
I ended up having to boot from the live usb and running:
manjaro-chroot /path/to/my/ssd
mhwd -i pci video-linux
to reinstall it.
Now it boots again. I also added the lines to the files you mentioned above and that did not fix the issue either.
But did you installed video-modesetting
and added the files before rebooting ?
