I just had another OBS segmentation fault after installing the recent 2023-03-31 batch of updates. I used @jondyowens solution and installed the libva-nvidia-driver.
I also had to remove the libva-vdpau-driver, and it seems that everything is working just fine after the remove. I did not install libva-nvidia-driver.
From a simple test with mpv it seems that HW Decoding is working well:
Does this means that this package is obsolete now, and no longer needed?
I also tried to followed the links from the libva-vdpau-driver package details to the wiki and the git repo, but those are no longer valid.
I am having a issue with OBS on both the manjaro package and the flatpak package but I am using a Radeon RX6700XT card and mesa graphics.
the repo package fails to even run and this is a fresh install of OBS
obs ξ² β
qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: offscreen, xcb, minimal, linuxfb, eglfs, vkkhrdisplay, vnc, minimalegl.
zsh: IOT instruction (core dumped) obs
and the flatpak package works but I canβt see the preview of Windows or screens, I made a issue report for that.
