OBS-Studio not working after last update
This is what I did to fix the OBS open and close issue after the Jan 25, 2023 patching issue.
I think the main concept is reinstalling the Nvidia drivers and reboot. That is, strip the Nvidia drivers, reboot, install video-linux driver, reboot, re-install Nvidia drivers, reboot, remove the video-linux driver, reboot. Then OBS works with Nvidia drivers with the Jan 25, 2023 patches.
Notes:
I did wiped my Manjaro OS and re-install it with the open source drivers initally, but you can skip this step because OBS still broke after a post wipe full patching reboot. I am not sure if this huge step made a difference.
And I used the mhwd auto propietery Nvidia GPU drivers and open source video-Linux drivers via the Manjaro Setting HW GUI install tool (not the Nvidia drivers by downloading from Nvidia’s site CLI ā€œmakeā€ methods).
Hope this helps.
This, actually, what I did last night and it magically fixed the issue.
Before doing anything, is there an explanation why it broke and why would some reinstall fix it?
I don’t want to worry about losing settings.
this is about to be the reason my distro hop again
Hey, I have the same problem. Can you list the commands for this fix? :grinning:
how does one do this without breaking cuda and nvidia-prime the mhwd gui and commandline don’t have a way to do it or at least not in a way that isn’t going to break everything else
open manjaro settings, then double-click the hardware configuration icon. Then:
  • Right-click video-linux → install
  • Right-click video-nvidia (or whatever specific version is installed) → remove
Reboot, log back in, then manjaro settings → hw config again and do the opposite:
  • Right click video-nvidia → install
  • Right click video-linux → remove
Reboot.
You can do everything from the command line:
sudo mhwd -i pci video-linux
sudo mhwd -r pci video-nvidia
sudo reboot
sudo mhwd -i pci video-nvidia
sudo mhwd -r pci video-linux
sudo reboot
Also, it was too late when I thought about it, but one might just want to try and reinstall the nvidia drivers instead of doing a full switch to the nouveau driver and reboot twice… That would be nice to let the others know if this works or not.
Anyhow, cycling the drivers worked for me. First time I see this on linux lol. I there hadn’t been a few people already saying that this fixed the issue, I wouldn’t have even tried.
I tried this with sudo mhwd -r pci video-nvidia -f but it made no difference. I had to uninstall and reinstall with two reboots to get it to work.
This worked for me, thanks!
The solution given does not work for me. I tried multiple times. When I remove video-nvidia driver and install video-linux, then my system will not load and I have to do a CTRL-ALT-F2, log in, and reinstall the nvidia driver. Then my system loads normally but OBS seg faults, exactly as others have described.
I need to use OBS later and so my only solution was to use Timeshift and return my system to a 2023-01-17 snapshot.
Also, VLC wasn’t working either and now it works again after going back.
I’m not sure if its necessary but here’s my current info (After restoring the 2023-01-17 snapshot):
$ inxi -v7azy
  Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=7f43684f-af68-4b29-a9b3-e5b81a7ddf9d rw quiet intel_iommu=on
  Desktop: Xfce v: 4.18.0 tk: Gtk v: 3.24.35 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: 1: GDM v: 43.0 note: stopped 2: LightDM v: 1.32.0
  Type: Desktop Mobo: ASUSTeK model: ROG MAXIMUS XI HERO (WI-FI) v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 0602
    date: 10/19/2018
  Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
    Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  RAM: total: 62.72 GiB used: 2.18 GiB (3.5%)
  Info: model: Intel Core i9-9900KF bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xF0
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 799 high: 800 min/max: 800/5000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 800 8: 800 9: 799 10: 800 11: 800 12: 800 13: 800 14: 800
    15: 800 16: 800 bogomips: 115232
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    prctl and seccomp
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: eVga.com. driver: nvidia
    v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
    status: current (as of 2022-12) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f02
    class-ID: 0300
  Device-2: Logitech C920 PRO HD Webcam type: USB
    driver: snd-usb-audio,uvcvideo bus-ID: 1-10.1:7 chip-ID: 046d:08e5
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
    compositor: xfwm v: 4.18.0 driver: N/A display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
    s-diag: 777mm (30.58")
  Monitor-1: DP-0 res: 2560x1440 hz: 60 dpi: 109
    size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 1-10.1:7 alternate: snd_soc_skl,snd_sof_pci_intel_cnl
    chip-ID: 046d:08e5 class-ID: 0102 bus-ID: 00:1f.3 chip-ID: 8086:a348
    serial: <filter> class-ID: 0403
  Device-2: NVIDIA TU106 High Definition Audio vendor: eVga.com.
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
    class-ID: 0403
  Device-3: Logitech C920 PRO HD Webcam type: USB
  Device-4: Logitech Yeti X type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-8:4 chip-ID: 046d:0aaf
    class-ID: 0300 serial: <filter>
  Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
  Sound Interface: sndio v: N/A running: no
  Sound Server-3: PipeWire v: 0.3.63 running: yes
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
    all]
  IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
    all]
  Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: 4020
    bus-ID: 00:17.0 chip-ID: 8086:2822 rev: N/A class-ID: 0104
  Local Storage: total: 5.46 TiB used: 1.44 TiB (26.3%)
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    rev: 1B2QEXM7 temp: 34.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
    type: SSD serial: <filter> rev: 1B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD40EFRX-68N32N0 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: 0A82 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE WH16NS40 rev: 1.03
    dev-links: cdrom
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 648.49 GiB (70.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 7f43684f-af68-4b29-a9b3-e5b81a7ddf9d
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 0739-7E33
  ID-3: /run/media/design215/data2 raw-size: 931.51 GiB
    size: 915.82 GiB (98.32%) used: 821.41 GiB (89.7%) fs: ext4 dev: /dev/sda1
    maj-min: 8:1 label: data2 uuid: 9bc0c66f-4f38-4e10-a50c-052478c7331e
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-1:2 info: ASUSTek AURA MOTHERBOARD type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 0b05:18a3 class-ID: 0300 serial: <filter>
  Device-2: 1-3:3 info: Microdia Backlit Gaming Keyboard type: Keyboard,Mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 400mA
    chip-ID: 0c45:652f class-ID: 0301
  Device-3: 1-8:4 info: Logitech Yeti X type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 046d:0aaf class-ID: 0300
    serial: <filter>
  Hub-2: 1-10:5 info: Hitachi ports: 4 rev: 2.0 speed: 480 Mb/s
    chip-ID: 045b:0209 class-ID: 0900
  Device-1: 1-10.1:7 info: Logitech C920 PRO HD Webcam type: Video,Audio
    power: 500mA chip-ID: 046d:08e5 class-ID: 0102 serial: <filter>
  Device-2: 1-10.4:9 info: Logitech USB Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c53f class-ID: 0300
  Hub-3: 1-13:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-13.1:8 info: American Power Conversion Uninterruptible Supply
    type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 2mA chip-ID: 051d:0002 class-ID: 0300 serial: <filter>
  Hub-4: 2-0:1 info: Super-speed hub ports: 10 rev: 3.1 speed: 10 Gb/s
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 30.0 C mobo: N/A gpu: nvidia temp: 33 C
  Processes: 369 Uptime: 1m wakeups: 4 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 alt: 10/11 clang: 14.0.6
  Packages: 1935 pm: pacman pkgs: 1931 libs: 509 tools: pamac pm: flatpak
  pkgs: 4 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.24
[design215@pc2019 ~]$
Hello,
I’ve the same issue, OBS not starting at all, VLC not working neither.
So far, everything else that i run daily seems to be working, but OBS and VLC.
I tried to reinstall nvidia drivers as suggested, no change.
Same here on my system, OBS won’t start and VLC crashes when playing a video file. VLC started working again after changing video output preferences to X11 (XCB). Here is the terminal output for OBS:
$ obs
debug: Found portal inhibitor
debug: Attempted path: share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: share/obs/obs-studio/locale/pt-PT.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/pt-PT.ini
debug: Attempted path: share/obs/obs-studio/themes/Yami.qss
debug: Attempted path: /usr/share/obs/obs-studio/themes/Yami.qss
info: Using EGL/X11
info: CPU Name: Intel(R) Core(TM) i7-9700F CPU @ 3.00GHz
info: CPU Speed: 3000.000MHz
info: Physical Cores: 8, Logical Cores: 8
info: Physical Memory: 32039MB Total, 24387MB Free
info: Kernel Version: Linux 5.15.89-1-MANJARO
info: Distribution: "Manjaro Linux" Unknown
info: Session Type: x11
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
info: Qt Version: 6.4.2 (runtime), 6.4.2 (compiled)
info: Portable mode: false
info: OBS 29.0.0-1 (linux)
info: ---------------------------------
info: audio settings reset:
	samples per sec: 48000
	speakers:        2
	max buffering:   960 milliseconds
	buffering type:  dynamically increasing
info: Initializing OpenGL...
info: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2
info: OpenGL loaded successfully, version 3.3.0 NVIDIA 525.85.05, shading language 3.30 NVIDIA via Cg compiler
info: video settings reset:
	base resolution:   1920x1080
	output resolution: 1280x720
	downscale filter:  Lanczos
	fps:               30/1
	format:            NV12
	YUV mode:          Rec. 709/Partial
info: NV12 texture support not available
info: P010 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
warning: A DeckLink iterator could not be created.  The DeckLink drivers may not be installed
warning: Failed to initialize module 'decklink.so'
info: [pipewire] Available captures:
info: [pipewire]     - Desktop capture
info: [pipewire]     - Window capture
info: NVENC supported
qt.core.qmetaobject.connectslotsbyname: QMetaObject::connectSlotsByName: No matching signal for on_tbar_position_valueChanged(int)
libDeckLinkAPI.so: impossĆ­vel abrir ficheiro-objecto partilhado: Ficheiro ou pasta inexistente
zsh: segmentation fault (core dumped)
Same here, completley broken…
debug: Attempted path: share/obs/obs-studio/locale.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale.ini
debug: Attempted path: share/obs/obs-studio/locale/en-GB.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-GB.ini
info: Using preferred locale 'en-GB'
info: Using EGL/X11
info: CPU Name: 11th Gen Intel(R) Core(TM) i7-11850H @ 2.50GHz
info: CPU Speed: 2500.000MHz
info: Physical Cores: 8, Logical Cores: 16
info: Physical Memory: 31769MB Total, 24503MB Free
info: Kernel Version: Linux 5.15.91-1-MANJARO
        speakers:        2
info: Loading up OpenGL on adapter Intel Mesa Intel(R) UHD Graphics (TGL GT1)
info: OpenGL loaded successfully, version 4.6 (Core Profile) Mesa 22.3.4, shading language 4.60
        downscale filter:  Bicubic
        fps:               30/1
        format:            NV12
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
warning: Failed to load 'en-GB' text for module: 'frontend-tools.so'
warning: Failed to load 'en-GB' text for module: 'linux-alsa.so'
warning: Failed to load 'en-GB' text for module: 'linux-capture.so'
warning: Failed to load 'en-GB' text for module: 'linux-jack.so'
warning: Failed to load 'en-GB' text for module: 'linux-pipewire.so'
warning: Failed to load 'en-GB' text for module: 'linux-pulseaudio.so'
warning: v4l2loopback not installed, virtual camera disabled
warning: LIBVA_DRIVER_NAME variable is set, this could prevent FFmpeg VAAPI from working correctly
zsh: segmentation fault (core dumped)  LIBVA_DRIVER_NAME=nvidia obs
Found something interesting. If I set the env variable LIBVA_DRIVER_NAME to any of the NVIDIA values, e.g.:
LIBVA_DRIVER_NAME=nouveau
LIBVA_DRIVER_NAME=vdpau
I get the same segmentation fault that we’re all getting.
If I set LIBVA_DRIVER_NAME to literally anything else, OBS starts without a segfault. Not sure what affect it has, but it’s interesting.
Same issue here - OBS does not start, VLC and everything else seems to work normally (I use the Cinnamon Edition). When I click on the OBS link the cursor spins for about 10 seconds but nothing happens!
I been lurking on this tread waiting for a proven solution. I have been holding off using the solution of installing/uninstalling driver as it does not seem to work for everyone. What I’m actually waiting for is for Manjaro developers to push out an update to fix the issue… Today I got a bunch of updates, but I seen nothing related to OBS or NVIDIA? I haven’t applied those updates yet - I wait a few days and return to this tread frequently to see if there is some new solution.
I’m just a user with no technical know-how, so I can not contribute - sorry
I currently have all of the updates installed again, EXCEPT for OBS. I’m back to using OBS 28.0.1 and it works. However…
  • VLC does not work and crashes when trying to play any video file
  • My XBox controller no longer works because Bluetooth is apparently not seeing any devices.
This is my main PC and is the only PC I have that is powerful enough to get all of my client work done, play steam games, and stick to my streaming schedule using OBS. I love Manjaro but it’s really painful when I do a bunch of updates and half the stuff on my PC stops working.
Here’s my UPDATED info from just now:
$ inxi -v7azy
  Kernel: 5.15.91-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    date: 10/19/2018
    status: discharging
  RAM: total: 62.72 GiB used: 2.12 GiB (3.4%)
    desc: 1x16 MiB
  Speed (MHz): avg: 800 high: 801 min/max: 800/5000 scaling:
    5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
    15: 801 16: 800 bogomips: 115232
    prctl and seccomp
    v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
    class-ID: 0300
    bus-ID: 1-10.1:7 v: kernel chip-ID: 046d:08e5
    alternate: snd_soc_skl,snd_sof_pci_intel_cnl class-ID: 0102 bus-ID: 00:1f.3
    chip-ID: 8086:a348 serial: <filter> class-ID: 0403
    class-ID: 0403
  Sound API: ALSA v: k5.15.91-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.65 running: yes
    all]
    all]
  Local Storage: total: 5.46 TiB used: 1.45 TiB (26.5%)
    rev: 1B2QEXM7 temp: 37.9 C scheme: GPT
    dev-links: cdrom
    used: 649.24 GiB (70.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    uuid: 0739-7E33
    size: 915.82 GiB (98.32%) used: 832.91 GiB (90.9%) fs: ext4 dev: /dev/sda1
    serial: <filter>
  System Temperatures: cpu: 29.0 C mobo: N/A gpu: nvidia temp: 34 C
  Processes: 345 Uptime: 10m wakeups: 3 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 alt: 10/11 clang: 15.0.7
  Packages: 1941 pm: pacman pkgs: 1937 libs: 510 tools: pamac pm: flatpak
and here’s my OBS info from the previous version, which is currently working (in case anyone needs a reference):
$ obs
qt.gui.icc: fromIccProfile: failed size sanity 2
Attempted path: share/obs/obs-studio/themes/Dark.qss
Attempted path: /usr/share/obs/obs-studio/themes/Dark.qss
info: Using EGL/X11
info: CPU Name: Intel(R) Core(TM) i9-9900KF CPU @ 3.60GHz
info: CPU Speed: 3600.000MHz
info: Physical Memory: 64221MB Total, 61189MB Free
info: Qt Version: 6.4.2 (runtime), 6.4.0 (compiled)
Attempted path: share/obs/obs-studio/themes/Dark/no_sources.svg
Attempted path: /usr/share/obs/obs-studio/themes/Dark/no_sources.svg
qt.core.qmetaobject.connectslotsbyname: QMetaObject::connectSlotsByName: No matching signal for on_actionShowTransitionProperties_triggered()
qt.core.qmetaobject.connectslotsbyname: QMetaObject::connectSlotsByName: No matching signal for on_actionHideTransitionProperties_triggered()
info: OBS 28.1.0-beta1-39-g6f50aac94-modified (linux)
	speakers:        2
info: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce RTX 2070/PCIe/SSE2
	fps:               30/1
	format:            NV12
warning: No AJA devices found, skipping loading AJA UI plugin
warning: Failed to initialize module 'aja-output-ui.so'
warning: No AJA devices found, skipping loading AJA plugin
warning: Failed to initialize module 'aja.so'
info: [Downstream Keyer] loaded version 0.2.6
info: [pipewire] No captures available
info: [obs-browser]: Version 2.18.5
info: [obs-browser]: CEF Version 103.0.5060.134 (runtime), 103.0.0-5060-shared-textures_143.2591+g4204d54+chromium-103.0.5060.134 (compiled)
info: FFMPEG VAAPI supported
info: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.0.1 | RPC Version: 1)
info: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.4.0 | Qt version (run-time): 6.4.2
info: [obs-websocket] [obs_module_load] Linked ASIO Version: 101201
info: [obs-websocket] [obs_module_load] Module loaded.
info: [vlc-video]: VLC 3.0.18 Vetinari found, VLC video source enabled
info:   Loaded Modules:
info:     vlc-video.so
info:     text-freetype2.so
info:     rtmp-services.so
info:     obs-x264.so
info:     obs-websocket.so
info:     obs-vst.so
info:     obs-transitions.so
info:     obs-outputs.so
info:     obs-filters.so
info:     obs-ffmpeg.so
info:     obs-browser.so
info:     linux-v4l2.so
info:     linux-pulseaudio.so
info:     linux-pipewire.so
info:     linux-capture.so
info:     linux-alsa.so
info:     image-source.so
info:     frontend-tools.so
info:     downstream-keyer.so
info:     decklink-output-ui.so
info:     decklink-captions.so
QLayout: Attempting to add QLayout "" to OBSBasic "OBSBasic", which already has a layout
QWidget::setTabOrder: 'first' and 'second' must be in the same window
info: ==== Startup complete ===============================================
warning: signal_handler_connect: signal 'file_changed' not found
info: Switched to Preview/Program mode
info: ------------------------------------------------
info: All scene data cleared
... I stopped here because I don't think anything further is relevant
So, in summary, with all updates INSTALLED, the previous version of OBS still works, except I can’t use VLC functions because VLC is broken. Version 29 of OBS does not run EVEN after reinstalling NVidia drivers MULTIPLE times. I have no Bluetooth devices, but my XBox controller works fine with a USB cable.
I’ve ā€œfixedā€ OBS installing the last flatpak version. I had to redo all the settings but at least i can use it without visible issue so far. I use the same shortcut from the menu, and it works.
Would be nice to have a real fix or explaination for us, poor users without much ā€œtechā€ knowledge.
I solved this by removing the libva-vdpau-driver and installing the libva-nvidia-driver.
Edit: This also solved the issue with VLC crashing when playing a video.
this worked for me
Seems Arch / OBS has a solution. I’d post in the relevant thread here, but it is already closed.
