info: CPU Name: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
info: CPU Speed: 2321.955MHz
info: Physical Cores: 4, Logical Cores: 8
info: Physical Memory: 5885MB Total, 2138MB Free
info: Kernel Version: Linux 5.4.89-1-MANJARO
info: Distribution: "Manjaro Linux" Unknown
info: Session Type: x11
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.20.10
info: Portable mode: false
Attempted path: share/obs/obs-studio/themes/Dark/no_sources.svg
Attempted path: /usr/share/obs/obs-studio/themes/Dark/no_sources.svg
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_clicked()
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_destroyed()
QMetaObject::connectSlotsByName: No matching signal for on_actionGridMode_triggered()
QMetaObject::connectSlotsByName: No matching signal for on_program_customContextMenuRequested(QPoint)
QMetaObject::connectSlotsByName: No matching signal for on_transitionRemove_clicked()
info: OBS 26.1.0-2 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 48000
speakers: 2
info: Initializing OpenGL...
info: Loading up OpenGL on adapter AMD AMD Radeon(TM) Vega 8 Graphics (RAVEN, DRM 3.35.0, 5.4.89-1-MANJARO, LLVM 11.0.1)
info: OpenGL loaded successfully, version 4.6 (Core Profile) Mesa 20.3.3, shading language 4.60
info: video settings reset:
base resolution: 1920x1080
output resolution: 1280x720
downscale filter: Bicubic
fps: 10/1
format: NV12
YUV mode: 709/Partial
info: NV12 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-ouput-ui.so'
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
warning: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
info: No blackmagic support
warning: v4l2loopback not installed, virtual camera disabled
info: NVENC supported
info: FFMPEG VAAPI supported
info: VLC found, VLC video source enabled
info: Loaded Modules:
info: vlc-video.so
info: text-freetype2.so
info: rtmp-services.so
info: obs-x264.so
info: obs-transitions.so
info: obs-outputs.so
info: obs-libfdk.so
info: obs-filters.so
info: obs-ffmpeg.so
info: linux-v4l2.so
info: linux-pulseaudio.so
info: linux-jack.so
info: linux-decklink.so
info: linux-capture.so
info: linux-alsa.so
info: image-source.so
info: frontend-tools.so
info: decklink-ouput-ui.so
info: decklink-captions.so
info: ==== Startup complete ===============================================
info: All scene data cleared
info: ------------------------------------------------
info: pulse-input: Server name: 'pulseaudio 14.2'
info: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
info: pulse-input: Started recording from 'bluez_sink.F0_A9_68_05_3E_4F.a2dp_sink.monitor'
info: pulse-am: Prevented feedback-loop in 'default'
info: [Loaded global audio device]: 'Desktop Audio'
info: - monitoring: monitor and output
info: pulse-am: Prevented feedback-loop in 'bluez_sink.F0_A9_68_05_3E_4F.a2dp_sink.monitor'
info: [Loaded global audio device]: 'Desktop Audio 2'
info: pulse-input: Started recording from 'alsa_input.pci-0000_05_00.6.analog-stereo'
info: pulse-am: Server name: 'pulseaudio 14.2'
info: pulse-am: Audio format: s16le, 44100 Hz, 2 channels
info: pulse-am: Started Monitoring in 'bluez_sink.F0_A9_68_05_3E_4F.a2dp_sink.monitor'
info: [Loaded global audio device]: 'Mic/Aux'
info: xshm-input: Geometry 1920x1080 @ 0,0
info: Switched to scene 'Scene'
info: Loaded scenes:
info: - scene 'Scene':
info: - source: 'Screen Capture (XSHM)' (xshm_input)
info: - source: 'Zoom meeting' (xcomposite_input)
Attempted path: share/obs/obs-studio/images/overflow.png
Attempted path: /usr/share/obs/obs-studio/images/overflow.png
info: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Desktop Audio)
QObject::connect: No such signal QLineEdit::editingFinished(const QString &)
QObject::connect: (sender name: 'customServer')
QObject::connect: (receiver name: 'OBSBasicSettings')
Attempted path: share/obs/obs-studio/locale.ini
Attempted path: /usr/share/obs/obs-studio/locale.ini
info: [NVENC encoder: 'simple_h264_recording'] settings:
rate_control: CQP
bitrate: 0
cqp: 21
keyint: 250
preset: hq
profile: high
width: 1280
height: 720
2-pass: false
b-frames: 2
GPU: 0
[h264_nvenc @ 0x559b8736f8c0] dl_fn->cuda_dl->cuInit(0) failed -> CUDA_ERROR_UNKNOWN: unknown error
warning: [NVENC encoder: 'simple_h264_recording'] Failed to open NVENC codec: Unknown error occurred
How do I get OBS working ?
thanks in advance
