OBS Studio flickering using newer kernels?
Hi,
I reinstalled Manjaro yesterday and my OBS Studio flickers pretty badly as soon as something is moving on the screen that’s being recorded.
Trying different Compositor Vsync settings didn’t do anything. Changing from OpenGL to XRender solved it, but causes bad screen tearing (when moving windows etc.) on the other hand. And I’m pretty sure I didn’t use XRender before.
Someone on reddit suggested uninstalling video-linux driver. Didn’t try this yet because I just set up the system and barely changed any settings, so I am a bit suspicious.
The problem doesn’t occur when I’m using kernel 5.4.135-1, though. Tried 5.10.53-1 and 5.13.5-1 (which I was using on the old installation) but it’s only working with the older one.
Anyone have a clue?
Thanks a lot and have a great weekend!
  Kernel: 5.13.5-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=309797db-be17-466d-98be-174aa1629301 rw quiet apparmor=1
  security=apparmor resume=UUID=0901642f-6782-43b8-bce1-ea689d504d5c
  udev.log_priority=3
  Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: plank wm: kwin_x11 vt: 1
  dm: LightDM 1.30.0, SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: Dell product: XPS 15 7590 v: N/A serial: <filter>
  Chassis: type: 10 serial: <filter>
  Mobo: Dell model: 0VYV0G v: A00 serial: <filter> UEFI: Dell v: 1.9.1
  date: 12/14/2020
  ID-1: BAT0 charge: 84.5 Wh (100.0%) condition: 84.5/97.0 Wh (87.1%)
  volts: 13.0 min: 11.4 model: SMP DELL GPM0365 type: Li-ion serial: <filter>
  status: Full
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360
  serial: <filter> charge: 100% (should be ignored) rechargeable: yes
  status: Discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
  charge: 55% (should be ignored) rechargeable: yes status: Discharging
  RAM: total: 15.24 GiB used: 3.77 GiB (24.8%)
  Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
  microcode: EA cache: L2: 12 MiB bogomips: 62431
  Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse sse2
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
  vendor: Hewlett-Packard driver: nvidia v: 470.57.02
  alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91
  class-ID: 0302
  Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 1-12:5 chip-ID: 0c45:6723 class-ID: 0e02
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: intel,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
  display-ID: :0 screens: 1
  Screen-1: 0 s-res: 7040x1440 s-dpi: 96 s-size: 1857x380mm (73.1x15.0")
  s-diag: 1895mm (74.6")
  Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  Monitor-2: DP1 res: 2560x1440 hz: 60 dpi: 108 size: 600x340mm (23.6x13.4")
  diag: 690mm (27.2")
  Monitor-3: DP3 res: 2560x1440 hz: 60 dpi: 108 size: 600x340mm (23.6x13.4")
  diag: 690mm (27.2")
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.5
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.13.5-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.32 running: yes
  Device-1: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
  driver: iwlwifi v: kernel port: 3000 bus-ID: 3b:00.0 chip-ID: 8086:2723
  class-ID: 0280
  IF: wlp59s0 state: up mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 208.12 GiB (43.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
  model: KXG60ZNV512G NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
  rev: 10604107 temp: 33.9 C scheme: GPT
  ID-1: / raw-size: 459.86 GiB size: 451.57 GiB (98.20%)
  used: 208.12 GiB (46.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  label: N/A uuid: 309797db-be17-466d-98be-174aa1629301
  label: NO_LABEL uuid: 9434-0220
  ID-1: swap-1 type: partition size: 16.78 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
  uuid: 0901642f-6782-43b8-bce1-ea689d504d5c
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 1-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
  class-ID: e001
  Device-3: 1-7:4 info: Shenzhen Goodix Fingerprint Reader
  type: Abstract (modem),CDC-Data driver: N/A interfaces: 2 rev: 2.0
  speed: 12 Mb/s power: 100mA chip-ID: 27c6:5395 class-ID: 0a00
  serial: <filter>
  Device-4: 1-12:5 info: Microdia Integrated_Webcam_HD type: Video
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
  speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 52.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2378 fan-2: 2394
  Processes: 307 Uptime: 3h 29m wakeups: 48 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1402 lib: 429
  flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
xrandr
Screen 0: minimum 8 x 8, current 7040 x 1440, maximum 32767 x 32767
eDP1 connected 1920x1080+5120+180 (normal left inverted right x axis y axis) 340mm x 190mm
   1920x1080     60.00*+  59.93
   1680x1050     59.88
   1400x1050     59.98
   1600x900      60.00    59.95    59.82
   1280x1024     60.02
   1400x900      59.96    59.88
   1280x960      60.00
   1368x768      60.00    59.88    59.85
   1280x800      59.81    59.91
   1280x720      59.86    60.00    59.74
   1024x768      60.00
   1024x576      60.00    59.90    59.82
   960x540       60.00    59.63    59.82
   800x600       60.32    56.25
   864x486       60.00    59.92    59.57
   640x480       59.94
   720x405       59.51    60.00    58.99
   640x360       59.84    59.32    60.00
DP1 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 600mm x 340mm
   2560x1440     59.95*+  74.78
   1920x1200     59.95
   1920x1080     60.00    60.00    50.00    59.94
   1920x1080i    60.00    50.00    59.94
   1680x1050     59.88
   1280x1024     75.02    60.02
   1440x900      59.90
   1152x864      75.00
   1280x720      60.00    50.00    59.94
   1024x768      75.03    70.07    60.00
   832x624       74.55
   800x600       72.19    75.00    60.32
   720x576       50.00
   720x480       60.00    59.94
   640x480       75.00    72.81    66.67    60.00    59.94
   720x400       70.08
DP2 disconnected (normal left inverted right x axis y axis)
DP3 connected 2560x1440+2560+0 (normal left inverted right x axis y axis) 600mm x 340mm
   1920x1200     59.95
   1680x1050     59.88
   1440x900      59.90
   1152x864      75.00
   832x624       74.55
   720x576       50.00
   720x480       60.00    59.94
   720x400       70.08
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
mhwd -li
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
video-hybrid-intel-nvidia-prime            2020.11.30               false            PCI
When using a rolling distro like Manjaro, kernel management becomes a thing, so if it works on 5.4, then keep that kernel and if you definitely need 5.10, get the latest one from Kernel.org, compile it yourself and file a bug upstream if you still run into an issue.
If that would seem arse-backwards to you, please read this:
especially the “Upstream” / “Downstream” section and then it will make more sense…
:grin:
Thanks for your advice.
I’d prefer using Kernel 5.13 because everything (but OBS) works perfectly. Strangely enough, I have problems with both LTS kernels. 5.14 does some weird things on my dual monitor setup and 5.10 destroys my SDDM.
Since I also used the latest kernel on the old installation and OBS was working flawlessly, I thought it must be a setting.
I can’t help you any further then and refer to my previous post and advise you to report a :bug:
:sob:
