OBS Studio crash
When install obs and try to run it crashed.
Do I need to install or config anything else?
erchache2000@pbp  ~  obs
Attempted path: share/obs/obs-studio/locale/en-US.ini
Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
Attempted path: share/obs/obs-studio/locale.ini
Attempted path: /usr/share/obs/obs-studio/locale.ini
Attempted path: share/obs/obs-studio/locale/es-ES.ini
Attempted path: /usr/share/obs/obs-studio/locale/es-ES.ini
info: Using preferred locale 'es-ES'
Attempted path: share/obs/obs-studio/themes/Dark.qss
Attempted path: /usr/share/obs/obs-studio/themes/Dark.qss
info: Physical Cores: 6, Logical Cores: 6
info: Physical Memory: 3795MB Total, 2715MB Free
info: Kernel Version: Linux 5.9.9-2-MANJARO-ARM
info: Distribution: "Manjaro-ARM" Unknown
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.20.9
info: Portable mode: false
Attempted path: share/obs/obs-studio/themes/Dark/no_sources.svg
Attempted path: /usr/share/obs/obs-studio/themes/Dark/no_sources.svg
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_clicked()
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_destroyed()
QMetaObject::connectSlotsByName: No matching signal for on_actionGridMode_triggered()
QMetaObject::connectSlotsByName: No matching signal for on_program_customContextMenuRequested(QPoint)
QMetaObject::connectSlotsByName: No matching signal for on_transitionRemove_clicked()
info: OBS 26.0.2-2 (linux)
info: ---------------------------------
info: audio settings reset:
	samples per sec: 48000
	speakers:        2
info: Initializing OpenGL...
error: X Error: GLXBadFBConfig, Major opcode: 152, Minor opcode: 34, Serial: 29
error: Failed to create OpenGL context.
error: Failed to create context!
error: device_create (GL) failed
error: Failed to initialize video.  Your GPU may not be supported, or your graphics drivers may need to be updated.
info: Freeing OBS context data
info: == Profiler Results =============================
info: run_program_init: 7088,82 ms
info:  ┣OBSApp::AppInit: 7,629 ms
info:  ┃ ┗OBSApp::InitLocale: 4,326 ms
info:  ┗OBSApp::OBSInit: 659,76 ms
info:    ┣obs_startup: 12,671 ms
info:    ┗OBSBasic::OBSInit: 398,686 ms
info:      ┣OBSBasic::InitBasicConfig: 0,396 ms
info:      ┣OBSBasic::ResetAudio: 0,613 ms
info:      ┗OBSBasic::ResetVideo: 397,531 ms
info: obs_hotkey_thread(25 ms): min=0,822 ms, median=1,24 ms, max=279,314 ms, 99th percentile=65,529 ms, 90,5941% below 25 ms
info: audio_thread(Audio): min=0,001 ms, median=0,107 ms, max=0,204 ms, 99th percentile=0,197 ms
info: =================================================
info: == Profiler Time Between Calls ==================
info: obs_hotkey_thread(25 ms): min=25,964 ms, median=26,568 ms, max=304,42 ms, 0% within ±2% of 25 ms (0% lower, 100% higher)
info: Number of memory leaks: 178
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
