Obs studio and vlc-luajit
I can’t install software package for obs-studio because multiple packages are outdated and not in the Stable branch of repositories for Manjaro.
obs-studio depends on the following packages that cannot be updated;
vlc-luajit
python>=3.13
Python version 3.13.1-1 is not yet in the Stable branch, but is available in Testing and Unstable branches, can’t install vlc-luajit because it depends on protobuf>=29.2 which also isn’t available in the Stable branch. Which when you check Branch compare for Manjaro version 29.2 only exists in the Unstable branch currently.
My only possible options of being able to install obs-studio is to;
A - Switch repository branches and update those packages specifically, risking breaking other system packages in the process.
B - Wait forever for those packages to make their way into Stable branch.
My options are more leaning to Option A because I don’t want to wait forever at playing the guessing game when they will become available in Stable branch just to be able to install one bit of software I need.
I just don’t understand how some packages are so delayed that they don’t make their way into the Stable Branch all at the same time as other packages. yet every other one seems to be available before others.
Your original title: Manjaro Packages are outdatred
Mod edit:- I’m unsure about the actual colour of Manjaro packages. Nonetheless, I’ve edited your topic title to promote better search listing and results.
OBS-Studio v31.0.0 is currently available in all branches
As you have found yourself, the options are clear; you could either switch branches, or wait.
If I understand correctly @Yochanan , Python 3.13 isn’t that far away from Stable.
Branch Version
stable 3.12.7-1
testing 3.13.1-1
unstable 3.13.1-1
No, I suppose you don’t.
Did you login just to make a yearly whine, or is there some constructive purpose to this that hasn’t yet revealed itself?
OBS Studio is available in Flatpak.
You can consider using Flatpak version, where you won’t be bugged by dependency conflict.
As it has been mentioned a thousand times, if you use AUR packages there is no official Manjaro support. Unstable branch is very close to Arch stable branch and therefore more compatible if AUR packages shall be used. :wink:
obs-studio 31.0.0-4
Description     : Free, open source software for live streaming and recording
Architecture    : x86_64
URL             : https://obsproject.com
Licenses        : GPL2
Groups          : None
Provides        : None
Depends On      : ffmpeg  jansson  libxinerama  libxkbcommon-x11  mbedtls  rnnoise
                  pciutils  qt6-svg  curl  jack  gtk-update-icon-cache  pipewire
                  libxcomposite  libdatachannel  uthash
Optional Deps   : libfdk-aac: FDK AAC codec support [installed]
                  libva-intel-driver: hardware encoding [installed]
                  libva-mesa-driver: hardware encoding [installed]
                  luajit: scripting support [installed]
                  python: scripting support [installed]
                  sndio: Sndio input client [installed]
                  v4l2loopback-dkms: virtual camera support [installed]
Required By     : None
Optional For    : None
Conflicts With  : None
Replaces        : None
Installed Size  : 22.05 MiB
Packager        : Sven-Hendrik Haase <svenstaro@archlinux.org>
Build Date      : Wed 18 Dec 2024 21:19:02 +07
Install Date    : Tue 24 Dec 2024 08:01:42 +07
Install Reason  : Explicitly installed
Install Script  : No
Validated By    : Signature
I have obs-studio installed, but I run Plasma (Testing) branch… however, I just booted up a VM, with Stable Manjaro.
`pamac upgrade` Then: `pamac install obs-studio`
 pamac install obs-studio                                                               ✔  29s 
Preparing...
Choose optional dependencies for obs-studio:
1:  luajit: scripting support
2:  sndio: Sndio input client
3:  v4l2loopback-dkms: virtual camera support
Enter a selection (default=none):
Resolving dependencies...
Checking inter-conflicts...
To install (6):
  mbedtls         3.6.1-1   (Required By: obs-studio)  extra  1.1 MB
  rnnoise         1:0.2-1   (Required By: obs-studio)  extra  1.2 MB
  libjuice        1.5.2-1   (Required By: obs-studio)  extra  74.0 kB
  libdatachannel  0.21.2-2  (Required By: obs-studio)  extra  824.3 kB
  uthash          2.3.0-2   (Required By: obs-studio)  extra  21.9 kB
  obs-studio      31.0.0-1                             extra  6.3 MB
Total download size: 9.5 MB
Total installed size: 33.9 MB
Apply transaction ? [y/N]
Apply transaction ? [y/N] y
Download of libdatachannel (0.21.2-2) started
Download of libdatachannel (0.21.2-2) finished
Download of mbedtls (3.6.1-1) finished
Download of rnnoise (1:0.2-1) finished
Download of libjuice (1.5.2-1) started
Download of uthash (2.3.0-2) started
Download of uthash (2.3.0-2) finished
Download of obs-studio (31.0.0-1) finished
Download of libjuice (1.5.2-1) finished
Checking keyring...        [6/6]
Checking integrity...        [6/6]
Loading packages files...        [6/6]
Checking file conflicts...        [6/6]
Checking available disk space...        [6/6]
Installing mbedtls (3.6.1-1)...        [1/6]
Installing rnnoise (1:0.2-1)...        [2/6]
Installing libjuice (1.5.2-1)...        [3/6]
Installing libdatachannel (0.21.2-2)...        [4/6]
Installing uthash (2.3.0-2)...        [5/6]
Installing obs-studio (31.0.0-1)...        [6/6]
Arming ConditionNeedsUpdate...        [1/3]
Updating icon theme caches...        [2/3]
Updating the desktop file MIME type cache...                                                             [3/3]
So perhaps we need to find out more about the state of your system BEFORE you try the installation.
We can begin with some system info;
inxi -Farz
A sort mirrors and sync and upgrade dance couldnt hurt;
sudo pacman-mirrors -f && sudo pacman -Syu
After this, you could get back into it:
pamac upgrade
You can then paste the output from pamac installing obs-studio to take the next step.
I moved thread to AUR - as this is were it rightfully belong.
You are gravely mistaken…
  • vlc-luajit is a custom AUR script and no repo packages depends on custom scripts.
You forgot
Option C
  • Don’t mix in custom AUR scripts on stable branch
  • If you do - despite the warning - your issue(s) are self inflicted
  • Remove vlc-luajit
    sudo pacman -Rns vlc-luajit
Heed the advise presented by
See for yourself …
 $ pamac info obs-studio
Version               : 31.0.0-4
                        and recording
Licenses              : GPL2
Repository            : extra
Installed Size        : 23,1 MB
Groups                : --
                        mbedtls rnnoise pciutils qt6-svg curl jack
                        gtk-update-icon-cache pipewire libxcomposite
Optional Dependencies : libfdk-aac: FDK AAC codec support [Installed]
                        libva-intel-driver: hardware encoding [Installed]
                        libva-mesa-driver: hardware encoding [Installed]
                        luajit: scripting support [Installed]
                        python: scripting support [Installed]
                        v4l2loopback-dkms: virtual camera support [Installed]
Provides              : --
Replaces              : --
Conflicts With        : --
Build Date            : ons 18 dec 2024 15:19:02 CET
Validated By          : MD5 Sum  SHA-256 Sum  Signature
For versions in the repos
 $ mbn info obs-studio -q | grep -e 'Branch' -e 'Version'
Branch         : archlinux
Version        : 31.0.0-4
Branch         : unstable
Version        : 31.0.0-4
Branch         : testing
Version        : 31.0.0-4
Branch         : stable
Version        : 31.0.0-1
By chance i’ve installed OBS on my Manjaro stable installation a couple of minutes ago with
And i wasn’t confronted with any dependency issues. Installed version is 31.0.0.1
Exactly - I even loaded a VM to test and prove this - the extra dependency simply shows that OP tried to install something OTHER than obs-studio - probably a git version or something else.
I also posted dependencies:
Optional Deps
All present in a Stable installation.
Anyway, unless OP comes back it seems this thread has said enough for now.
Unless there is some dire need, there’s no reason not to install with pamac…
Use pacman to install obs-studio.
(it doesn’t do and doesn’t care about anything AUR)
Only versions from the AUR depend hard on luajit
… only is an optional dependency for obs-studio from the repos
I don’t see a dependency on vlc-luajit with the version available from the repos.
Or perhaps disable AUR support when you use pamac or the GUI pamac-manager
Arch Linux - obs-studio 31.0.0-4 (x86_64)
vs:
AUR (en) - Packages
Watch out for whether what you select to install is from AUR or from the repos when you use pamac or pamac-manager with AUR support enabled.
With AUR support enabled it will present you all versions and you need to be careful and read carefully what you select.
I do have AUR enabled via pamac, but it did not give me alternative version suggestions during install. It selected the version from extra repo.
