action: upgraded obs-studio-git (30.0.0.rc1.r9.gc41633d-1 → 30.0.0.rc1.r12.g44f3f79-1)
result: obs-studio Cannot launch
terminal command obs
obs: /usr/lib/libQt6Core.so.6: version `Qt_6.6' not found (required by obs)
This log message is clear. It informs you how to easily fix a problem. → Install qt6-base
I recommend you to install obs-studio
from Manjaro stable branch when you are in the stable branch. Uninstall obs-studio-git
from the AUR. It is useless because you do not know how to fix it on your own.
I couldn’t launch when I installed 29.1.3-1 before, but it can be started after installation today. I don’t know why
