OBS Seg Fault - Crashes In Normal and Safe Mode
Can anyone else test to see if OBS works for you…I’m getting the following:
info: ---------------------------------
info: Initializing OpenGL...
info: Loading up OpenGL on adapter Intel Mesa Intel(R) Iris(R) Xe Graphics (RPL-P)
info: OpenGL loaded successfully, version 4.6 (Core Profile) Mesa 24.3.4-arch1.1, shading language 4.60
info: video settings reset:
        base resolution:   1920x1080
        output resolution: 1280x720
        downscale filter:  Bicubic
        fps:               30/1
        format:            NV12
        YUV mode:          Rec. 709/Partial
info: NV12 texture support enabled
info: P010 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
warning: A DeckLink iterator could not be created.  The DeckLink drivers may not be installed
warning: Failed to initialize module 'decklink.so'
info: [pipewire] Available capture sources:
info: [pipewire]     - Monitor source
info: [pipewire]     - Window source
warning: v4l2loopback not installed, virtual camera not registered
info: VAAPI: API version 1.22
info: FFmpeg VAAPI H264 encoding supported
zsh: segmentation fault (core dumped)  obs
I dont use obs-studio so I had to install it.
But it worked as expected and opened without error.
( Plasma - Unstable Branch )
Thanks for checking. So it’s a system specific issue. That’s a bummer. I’ll try to figure out what’s going on.
I forgot to mention I am on amdgpu and Wayland … did not check X11.
You might do the quick test of creating and logging into a new user account.
If it works there then it is something unique to the original $HOME (not system-wide).
Good idea. I tried, no luck. Also tried in Wayland, no luck…huge bummer. It’s a great piece of software.
Lets get some info;
System
inxi -Farz
mhwd
mhwd -li -d
Double check the obs package
pacman -Qs obs-studio
  Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=29221945-aeb0-4217-8b21-a05dc798e023 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
  Type: Laptop System: Dell product: XPS 15 9530 v: N/A
  Mobo: Dell model: 0GY0F9 v: A00 serial: <superuser required> part-nu: 0BEB
    uuid: <superuser required> UEFI: Dell v: 1.15.0 date: 07/08/2024
  ID-1: BAT0 charge: 71.0 Wh (100.0%) condition: 71.0/84.3 Wh (84.2%)
    volts: 12.6 min: 11.4 model: BYD DELL M59JH39 type: Li-poly serial: <filter>
    status: not charging cycles: 111
  Info: model: 13th Gen Intel Core i9-13900H bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
    microcode: 0x4123
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
    st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
    KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
    desc: 1x24 MiB
  Speed (MHz): avg: 400 min/max: 400/5200:5400:4100 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
    15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 119840
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Dell driver: i915
    v: kernel alternate: xe arch: Xe process: Intel 7 (10nm) built: 2022+ ports:
    active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:a7a0 class-ID: 0300
  Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: Dell
    driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:28a0 class-ID: 0302
  Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 0c45:6748
  Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3456x2160 s-dpi: 96 s-size: 914x571mm (35.98x22.48")
    s-diag: 1078mm (42.43")
  Monitor-1: eDP-1 model: Samsung 0x414d built: 2020 res: mode: 3456x2160
    hz: 60 scale: 100% (1) dpi: 261 gamma: 1.2 size: 336x210mm (13.23x8.27")
    diag: 396mm (15.6") ratio: 16:10 modes: 3456x2160
    drv: nvidia device: 1 drv: iris gbm: drv: iris surfaceless: drv: nvidia x11:
    drv: iris inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (RPL-P)
    device-ID: 8086:a7a0 memory: 15.15 GiB unified: yes
  API: Vulkan v: 1.4.303 layers: 12 device: 0 type: integrated-gpu
    name: Intel Iris Xe Graphics (RPL-P) driver: N/A device-ID: 8086:a7a0
    surfaces: xcb,xlib device: 1 type: discrete-gpu name: NVIDIA GeForce RTX
    4060 Laptop GPU driver: N/A device-ID: 10de:28a0 surfaces: xcb,xlib
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Dell
    driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
    snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0401
  API: ALSA v: k6.12.11-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 953.87 GiB used: 646.77 GiB (67.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC801 NVMe 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 51003141 temp: 36.9 C
    scheme: GPT
  ID-1: / raw-size: 29.3 GiB size: 28.67 GiB (97.86%) used: 23.25 GiB (81.1%)
    fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
    used: 336 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
  ID-3: /home raw-size: 29.3 GiB size: 28.67 GiB (97.86%)
    used: 25.3 GiB (88.3%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
  ID-1: swap-1 type: partition size: 7.91 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p11 maj-min: 259:11
  System Temperatures: cpu: 44.0 C mobo: 34.0 C sodimm: SODIMM C
  Fan Speeds (rpm): cpu: 1200 fan-2: 1090
  Packages: pm: pacman pkgs: 1659 libs: 489 tools: pamac pm: flatpak pkgs: 0
    1: https://mirror.23m.com/manjaro/stable/$repo/$arch
    2: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    3: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    5: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    6: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirrors2.manjaro.org/stable/$repo/$arch
    8: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    9: https://manjaro.ynh.ovh/stable/$repo/$arch
    10: https://mirror.init7.net/manjaro/stable/$repo/$arch
    11: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    12: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    13: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    14: https://manjaro.kurdy.org/stable/$repo/$arch
    15: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    16: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    17: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    18: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    19: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    20: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    22: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    24: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    25: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    26: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    27: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    28: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    29: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    30: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    31: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    32: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    33: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    34: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    35: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    36: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    37: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    38: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    39: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    40: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    41: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    42: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    43: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    44: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    45: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    46: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    47: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    48: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    49: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    50: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    51: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    52: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    53: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    54: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    55: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    56: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    57: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    58: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    59: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    60: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    61: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    62: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
  Memory: total: 32 GiB note: est. available: 31.02 GiB used: 4.39 GiB (14.2%)
  Processes: 369 Power: uptime: 14m states: freeze,mem,disk suspend: s2idle
    image: 12.38 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 257 default: graphical tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
mhwd -li -d         ✔  5s 
   ATTACHED:    PCI
   VERSION:     2020.01.13
   INFO:        X.org modesetting video driver.
   PRIORITY:    1
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
   ATTACHED:    PCI
   VERSION:     2023.03.23
   INFO:        Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
   PRIORITY:    8
   FREEDRIVER:  false
   DEPENDS:     video-modesetting
   CONFLICTS:   video*nvidia*
   CLASSIDS:    0300 0302 0300
   VENDORIDS:   10de 8086
\pacman -Qs obs-studio         SEGV ✘  3s 
local/obs-studio 31.0.1-2
    Free, open source software for live streaming and recording
I also tried:
prime-run obs
same result
Oh and we should also look at the coredump.
Everything up til
was also present on my start from terminal (aside from some hardware differences).
To list coredumps
coredumpctl list
Then you can print one by specifying the PID like so (replacing with the actual PID number)
coredump info PID
coredumpctl info 6797         127 ✘
           PID: 6797 (obs)
           UID: 1000 (joel)
           GID: 1000 (joel)
        Signal: 11 (SEGV)
     Timestamp: Sun 2025-02-09 19:49:29 PST (16min ago)
  Command Line: obs
    Executable: /usr/bin/obs
 Control Group: /user.slice/user-1000.slice/user@1000.service/app.slice/app-org.kde.konsole-6433.scope/tab(6453).scope
          Unit: user@1000.service
     User Unit: app-org.kde.konsole-6433.scope
         Slice: user-1000.slice
     Owner UID: 1000 (joel)
       Boot ID: 611936c2a6194ff29ff6bc0e00742ba5
    Machine ID: 21e709ca67bf43d3ab235a366a2bb059
      Hostname: joel-xps159530
       Storage: /var/lib/systemd/coredump/core.obs.1000.611936c2a6194ff29ff6bc0e00742ba5.6797.1739159369000000.zst (present)
  Size on Disk: 13.5M
       Message: Process 6797 (obs) of user 1000 dumped core.
                Stack trace of thread 6797:
                #0  0x000077772b6e6514 XDisplayString (libX11.so.6 + 0x27514)
                #1  0x00007776d20fbd00 __vaDriverInit_1_21 (nvidia_drv_video.so + 0xdd00)
                #2  0x00007777361d2064 vaInitialize (libva.so.2 + 0x8064)
                #3  0x00007776d21ae45e n/a (obs-ffmpeg.so + 0x1b45e)
                #4  0x00007776d219c3ba n/a (obs-ffmpeg.so + 0x93ba)
                #5  0x00007776d21a5838 n/a (obs-ffmpeg.so + 0x12838)
                #6  0x00007776d21ad757 obs_module_load (obs-ffmpeg.so + 0x1a757)
                #7  0x000077773ad4367e obs_init_module (libobs.so.30 + 0x4767e)
                #8  0x000077773ad44fe7 n/a (libobs.so.30 + 0x48fe7)
                #9  0x000077773ad456a0 obs_find_modules2 (libobs.so.30 + 0x496a0)
                #10 0x000077773ad45d3f obs_load_all_modules2 (libobs.so.30 + 0x49d3f)
                #11 0x0000623efa7634e5 n/a (n/a + 0x0)
                #12 0x0000623efa6ba545 n/a (n/a + 0x0)
                #13 0x0000777738434e08 n/a (libc.so.6 + 0x25e08)
                #14 0x0000777738434ecc __libc_start_main (libc.so.6 + 0x25ecc)
                #15 0x0000623efa6bc855 n/a (n/a + 0x0)
Ok … can you also report on these packages;
pacman -Qsq vdpau
pacman -Qsq libva
pacman -Qsq vdpau
lib32-libva-vdpau-driver
lib32-libvdpau
lib32-mesa
libva-vdpau-driver
libvdpau
mesa
pacman -Qsq libva         ✔
lib32-libva
lib32-libva-intel-driver
lib32-mesa
libva
libva-intel-driver
libva-vdpau-driver
mesa
Ahah.
Those should not exist.
Please remove them.
sudo pacman -Rns libva-vdpau-driver lib32-libva-vdpau-driver
Then give it a try again. :slight_smile:
Note: Modern nvidia cards can have NVDEC backend for VAAPI through libva-nvidia-driver, but I am unsure if this is desirable in your dual-gfx system.
Out of an abundance of caution we may also be interested in foreign packages in general … as it is already shown some packages that no longer exist in the repos or the AUR have been retained.
pacman -Qmq
pacman -Qmq         ✔  4s 
google-chrome
kdelibs4support
kdesignerplugin
kemoticons
kfilemetadata5
khotkeys
khtml
kjs
kpeople5
kpeoplevcard
kquickcharts5
krunner5
ksanecore5
libkcddb5
libksane5
manjaro-hotfixes
manjaro-settings-manager-kcm
modemmanager-qt5
opera
p7zip-gui
plasma-simplemenu
pulseaudio-ctl
python-manjaro-sdk
qgpgme-qt5
shairplay
simplescreenrecorder
spectre-meltdown-checker
systemd-kcm
teamviewer
unetbootin
v86d
web-installer-url-handler
zulu-23-bin
These all do not exist in the repos or the AUR and should be removed.
But the majority of that list is made up of deprecated plasma5 packages that likely should be removed as well, even if they technically continue to exist in the AUR (for now).
On top of those there are a few that are highly questionable such as v86d and pulseaudio-ctl (on what appears to be a system using pipewire) that very likely should not be present.
Of course a handful are legitimate current AUR packages that only you know if you want ( unetbootin, opera, specre-meltdown-checker, etc ).
Aside from that - was obs-studio able to be launched after removing the *libva-vdpau* packages ?
Indeed. Got it resolved removing vdpau - thank you! I’ll look at removing the other packages as well.
A bit off topic now but since it was recommended, I am getting a dependency error with one of those packages when I start removing it.
sudo pacman -Rns web-installer-url-handler         ✔
checking dependencies...
:: clang optionally requires llvm: referenced by some clang headers
:: kcoreaddons optionally requires pyside6: Python bindings
:: kguiaddons optionally requires pyside6: Python bindings
:: knotifications optionally requires pyside6: Python bindings
:: kunitconversion optionally requires pyside6: Python bindings
:: kwidgetsaddons optionally requires pyside6: Python bindings
:: kxmlgui optionally requires pyside6: Python bindings
:: python-matplotlib optionally requires pyside6: alternative for Qt6{Agg,Cairo} backends
Packages (6) llvm-19.1.7-1  pyside6-6.8.1.1-3  python-manjaro-sdk-1:0.1.1-1  python-systemd-235-4  shiboken6-6.8.1.1-3  web-installer-url-handler-2.3-1
Total Removed Size:  171.35 MiB
:: Do you want to remove these packages? [Y/n]
Not really an error - just a notice.
Inputting y would allow the operation to continue.
llvm and pyside6 are being removed along with the other dependencies not required by any other package … but they do fulfill optional dependencies for some other packages.
You can mark those packages as ‘explicitly installed’ if you would like to keep them.
sudo pacman -D --asexplicit llvm pyside6
After which they will not be included with the removal.
Of course they arent actually requirements so if you have no reason for them then you might just let them be removed.
