OBS (Open Broadcaster Software) Not Working On Manjaro Linux 2024
Hey!
OBS-Studio is not working on my Manjaro GNOME, and I have tried all sorts of installations: flatpak, pacman, yay, and everything I was able to find online.
But OBS is not starting.
I know it runs because my laptop fans are taking off, but nothing happens on screen.
If OBS is not working on Manjaro, can you please recommend me a similar software? (I really do need it for work)
Hi!
If you are unable to solve this and need it for work and I assume there is a deadline:
If nothing pops up in a search on the forum (I found a few so you can to)
Thank you!
I managed to get it to work by running it in the terminal. (I feel like a complete idiot now :slight_smile: )
I thought I could just click the icon and it will work.
If anybody comes here with the same problem, here’s the solution:
Install OBS
flatpak install flathub com.obsproject.Studio
Run OBS (whenever you want to open it, you must run this in the terminal)
flatpak run com.obsproject.Studio
I’m glad you found a workaround, however, installing OBS from the official Manjaro repositories is likely to be less troublesome. You might even be surprised with a launcher to click.
sudo pacman -S obs-studio
(Remove the flatpak version beforehand)
Cheers.
I have tried that before and it is not opening :frowning:
OBS fom the official repositories works without issue here. Your issue is then specific to your setup/configuration; with what precisely, all I can offer is… :person_shrugging: as I don’t have a :crystal_ball:. Good luck with that :four_leaf_clover:.
Flatpak packages (by design) are isolated from any messed up system configurations, so they can sometimes work as expected; at least you have that.
Cheers. :wink:
There was a sale on emoji this week.
:four_leaf_clover: you!
