I am trying to record my screen with OBS using the NVENC encoder. If I do any big motions (eg. dragging a window around the screen), I get a ton of “skipped frames due to encoding lag”. When recording my desktop, about 25-50% of the frames are skipped, but if I try to record a game, then 99% of frames are skipped.
I think it’s worth noting that I have a 4k 144hz monitor and I’m recording a 4k 60hz video. I know recording 4k 60hz is rather intensive, but NVENC shouldn’t have a problem with it. I am also recording to a PCIe4 SSD, so disk IO should not be a bottleneck. Everything on my system is up to date with the stable branch and I restarted after updating. My BIOS is also up to date.
What I’ve tried
- Disabling G-SYNC
- Different sources in OBS
- Window Capture (Xcomposite)
- Screen Capture (XSHM)
- Using the “Indistinguishable Quality, Large File Size” recording quality
- Setting “Output (Scaled) Resolution” to 1080p while keeping the “Base (Canvas) Resolution” at 4k
- Different OBS versions/packages
- obs-studio-27.2.4-1
- obs-studio-git-27.2.0.177-1
- obs-studio snap package
- This one actually caused my screen to go black and then return me to the login screen every couple of minutes. Uninstalling it fixed it.
I previously had single GPU VM passthrough set up, so I figured that could be causing this issue. I reset my BIOS settings to default (other than my memory’s XMP profile). When I setup the VM, I had updated the grub config (/etc/default/grub) to use:
GRUB_CMDLINE_LINUX_DEFAULT="efi=runtime quiet apparmor=1 security=apparmor udev.log_priority=3 amd_iommu=on iommu=pt video:vesafb=off video=efifb:on"
I tried changing this to the following, but it didn’t help:
GRUB_CMDLINE_LINUX_DEFAULT="efi=runtime quiet apparmor=1 security=apparmor udev.log_priority=3"
I also tried renaming the config file and then reinstalling grub with pamac reinstall grub to get the default grub config. However that didn’t fix it either.
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3"
I ran sudo grub-mkconfig -o /boot/grub/grub.cfg and restarted after every edit.
Specs
- OS: Manjaro Linux x86_64
- Kernel: 5.15.49-1-MANJARO
- DE: Plasma 5.24.5
- WM: KWin
- CPU: AMD Ryzen 7 3800X (16) @ 3.9 GHz
- GPU: NVIDIA RTX 3090
- Memory: 32gb dual-channel DDR4-3600
Graphics driver
$ inxi -G
Device-1: NVIDIA GA102 [GeForce RTX 3090] driver: nvidia v: 515.48.07
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2 driver: X:
loaded: nvidia gpu: nvidia resolution: 3840x2160
OpenGL: renderer: NVIDIA GeForce RTX 3090/PCIe/SSE2
v: 4.6.0 NVIDIA 515.48.07
I can’t post screenshots since I just made my account, but here is what I see in nvidia-settings:
- System Information
- Operating System: Linux-x86_64
- NVIDIA Driver Version: 515.48.07
- NVML Version: 11.515.48.07
- X Server Information
- Display Name: elias-desktop-manjaro:0
- Server Version Number: 11.0
- Server Vendor String:
The X.Org Foundation - Server Vendor Version: 1.21.1.3 (12101003)
- NV-CONTROL Version: 1.29
- Screens: 1
- X Server Display Configuration
- Selection: GBT AORUS FI32U (DP-2 on GPU-0)
- Configuration: X screen 0
- Resolution: 3840x2160 144 Hz
- Mode Name: 3840x2160_144
- Orientation: No Rotation, No Reflection
- ViewPortIn: 3840x2160
- ViewPortOut: 3840x2160+0+0
- Panning: 3840x2160
- Force Composition Pipeline: No
- Force Full Composition Pipeline: No
- Allows G-SYNC on monitor not validated as G-SYNC Compatible: Yes
I exported my nvidia-settings config to a temporary place (so it doesn’t overwrite the normal config):
# /home/elias/Documents/.nvidia-settings-rc
# Configuration file for nvidia-settings - the NVIDIA Settings utility
# Generated on Sat Jul 2 14:08:53 2022
# ConfigProperties:
RcFileLocale = C
DisplayStatusBar = Yes
SliderTextEntries = Yes
IncludeDisplayNameInConfigFile = No
UpdateRulesOnProfileNameChange = Yes
Timer = PowerMizer_Monitor_(GPU_0),Yes,1000
Timer = Thermal_Monitor_(GPU_0),Yes,1000
Timer = Memory_Used_(GPU_0),Yes,3000
# Attributes:
0/SyncToVBlank=1
0/LogAniso=0
0/FSAA=0
0/TextureClamping=1
0/FXAA=0
0/AllowFlipping=1
0/FSAAAppControlled=1
0/LogAnisoAppControlled=1
0/OpenGLImageSettings=1
0/FSAAAppEnhanced=0
0/AllowGSYNC=1
0/AllowVRR=1
0/ShowGSYNCVisualIndicator=0
0/ShowVRRVisualIndicator=0
0/ShowGraphicsVisualIndicator=0
[DPY:DP-0]/Dithering=0
[DPY:DP-0]/DitheringMode=0
[DPY:DP-0]/DitheringDepth=0
[DPY:DP-0]/ColorSpace=0
[DPY:DP-0]/ColorRange=0
[DPY:DP-0]/SynchronousPaletteUpdates=0
[DPY:DP-1]/Dithering=0
[DPY:DP-1]/DitheringMode=0
[DPY:DP-1]/DitheringDepth=0
[DPY:DP-1]/ColorSpace=0
[DPY:DP-1]/ColorRange=0
[DPY:DP-1]/SynchronousPaletteUpdates=0
[DPY:HDMI-0]/Dithering=0
[DPY:HDMI-0]/DitheringMode=0
[DPY:HDMI-0]/DitheringDepth=0
[DPY:HDMI-0]/ColorSpace=0
[DPY:HDMI-0]/ColorRange=0
[DPY:HDMI-0]/SynchronousPaletteUpdates=0
[DPY:DP-2]/RedBrightness=0.000000
[DPY:DP-2]/GreenBrightness=0.000000
[DPY:DP-2]/BlueBrightness=0.000000
[DPY:DP-2]/RedContrast=0.000000
[DPY:DP-2]/GreenContrast=0.000000
[DPY:DP-2]/BlueContrast=0.000000
[DPY:DP-2]/RedGamma=1.000000
[DPY:DP-2]/GreenGamma=1.000000
[DPY:DP-2]/BlueGamma=1.000000
[DPY:DP-2]/Dithering=0
[DPY:DP-2]/DitheringMode=0
[DPY:DP-2]/DitheringDepth=0
[DPY:DP-2]/DigitalVibrance=0
[DPY:DP-2]/ColorSpace=0
[DPY:DP-2]/ColorRange=0
[DPY:DP-2]/SynchronousPaletteUpdates=0
[DPY:DP-3]/Dithering=0
[DPY:DP-3]/DitheringMode=0
[DPY:DP-3]/DitheringDepth=0
[DPY:DP-3]/ColorSpace=0
[DPY:DP-3]/ColorRange=0
[DPY:DP-3]/SynchronousPaletteUpdates=0
[DPY:HDMI-1]/Dithering=0
[DPY:HDMI-1]/DitheringMode=0
[DPY:HDMI-1]/DitheringDepth=0
[DPY:HDMI-1]/ColorSpace=0
[DPY:HDMI-1]/ColorRange=0
[DPY:HDMI-1]/SynchronousPaletteUpdates=0
[DPY:DP-4]/Dithering=0
[DPY:DP-4]/DitheringMode=0
[DPY:DP-4]/DitheringDepth=0
[DPY:DP-4]/ColorSpace=0
[DPY:DP-4]/ColorRange=0
[DPY:DP-4]/SynchronousPaletteUpdates=0
[DPY:DP-5]/Dithering=0
[DPY:DP-5]/DitheringMode=0
[DPY:DP-5]/DitheringDepth=0
[DPY:DP-5]/ColorSpace=0
[DPY:DP-5]/ColorRange=0
[DPY:DP-5]/SynchronousPaletteUpdates=0
Swap
In my search to fix this issue, I saw one person mention that using a swap file instead of a swap partition can cause issues with OBS. I haven’t yet tried this because I don’t really want to resize my partitions, but I am willing to try if anyone here thinks it’s worth a shot. I do not use hibernation, so I thought that using a swapfile would be fine.
$ swapon --show
NAME TYPE SIZE USED PRIO
/swapfile file 64G 0B -2
OBS
I made a new profile to reset the settings to default. The only things I changed are the recording path and “Output (Scaled) Resolution” from 1080p to 4k.
Version: 27.2.4-1 (64 bit)
Settings:
- Output
- Output Mode: Simple
- Streaming
- Video Bitrate: 2500 Kbps
- Encoder: Hardware (NVENC)
- Audio Bitrate: 160
- Enable Advanced Encoder Settings: No
- Recording
- Recording Path:
/home/elias/Videos - Generate File Name without Space: No
- Recording Quality: High Quality, Medium File Size
- Recording Format: mkv
- Custom Muxer Settings: (blank)
- Enable Replay Buffer: No
- Recording Path:
- Video
- Base (Canvas) Resolution: 3840x2160
- Output (Canvas) Resolution: 3840x2160
- Downscale Filter: Bicubic (Sharpened scaling, 16 samples)
- Common FPS Values: 60
Scene:
- Screen: Screen DP-2 (3840x2160 @ 0,0)
- Capture Cursor: Yes
- Advanced Settings: No
