Hi!
OBS-Studio show the window “failed to start streaming” when I try to start recording on X11 session:
Starting the output failed. Please check the log for details.
Note: If you are using the NVENC or AMD encoders, make sure your video drivers are up to date.
Here is the output of LC_ALL=C obs:
Detected locale "C" with character encoding "ANSI_X3.4-1968", which is not UTF-8.
Qt depends on a UTF-8 locale, and has switched to "C.UTF-8" instead.
If this causes problems, reconfigure your locale. See the locale(1) manual
for more information.
debug: Found portal inhibitor
debug: Attempted path: /usr/bin/../share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: /usr/bin/../share/obs/obs-studio/themes
debug: Attempted path: /usr/bin/../share/obs/obs-studio/themes/
warning: ReadOne on org.freedesktop.portal.Settings returned an invalid reply
info: Using EGL/X11
info: CPU Name: Intel(R) Core(TM) i5-10300H CPU @ 2.50GHz
info: CPU Speed: 4359.821MHz
info: Physical Cores: 4, Logical Cores: 8
info: Physical Memory: 15636MB Total, 9574MB Free
info: Kernel Version: Linux 6.12.4-1-MANJARO
info: Distribution: "Manjaro Linux" Unknown
info: Desktop Environment: KDE (KDE)
info: Session Type: x11
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
info: Qt Version: 6.8.1 (runtime), 6.8.1 (compiled)
info: Portable mode: false
info: OBS 31.0.0-1 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 48000
speakers: 2
max buffering: 960 milliseconds
buffering type: dynamically increasing
info: Initializing OpenGL...
info: Loading up OpenGL on adapter Intel Mesa Intel(R) UHD Graphics (CML GT2)
info: OpenGL loaded successfully, version 4.6 (Core Profile) Mesa 24.2.8-arch1.1, shading language 4.60
info: video settings reset:
base resolution: 1920x1080
output resolution: 1920x1080
downscale filter: Bicubic
fps: 60/1
format: NV12
YUV mode: Rec. 709/Partial
info: NV12 texture support enabled
info: P010 texture support not available
info: Audio monitoring device:
name: По умолчанию
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
warning: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
warning: Failed to initialize module 'decklink.so'
info: [pipewire] Available capture sources:
info: [pipewire] - Monitor source
info: [pipewire] - Window source
warning: v4l2loopback not installed, virtual camera not registered
info: VAAPI: API version 1.22
info: FFmpeg VAAPI H264 encoding supported
info: FFmpeg VAAPI AV1 encoding not supported
info: FFmpeg VAAPI HEVC encoding supported
info: [obs-nvenc] NVENC version: 12.1 (compiled) / 12.2 (driver), CUDA driver version: 12.40, AV1 supported: false
error: X Error: BadAccess (attempt to access private resource denied), Major opcode: 152, Minor opcode: BadAtom (invalid Atom parameter), Serial: 32
libvdpau-va-gl: Device::Resource::Resource(): gl error 1282
info: Loaded Modules:
info: text-freetype2.so
info: rtmp-services.so
info: obs-x264.so
info: obs-webrtc.so
info: obs-vst.so
info: obs-transitions.so
info: obs-qsv11.so
info: obs-outputs.so
info: obs-nvenc.so
info: obs-libfdk.so
info: obs-filters.so
info: obs-ffmpeg.so
info: linux-v4l2.so
info: linux-pulseaudio.so
info: linux-pipewire.so
info: linux-jack.so
info: linux-capture.so
info: linux-alsa.so
info: image-source.so
info: frontend-tools.so
info: decklink-output-ui.so
info: decklink-captions.so
info: Available Encoders:
info: Video Encoders:
info: - ffmpeg_svt_av1 (SVT-AV1)
info: - ffmpeg_aom_av1 (AOM AV1)
info: - ffmpeg_vaapi_tex (FFmpeg VAAPI H.264)
info: - hevc_ffmpeg_vaapi_tex (FFmpeg VAAPI HEVC)
info: - obs_nvenc_h264_tex (NVIDIA NVENC H.264)
info: - obs_nvenc_hevc_tex (NVIDIA NVENC HEVC)
info: - obs_qsv11_v2 (QuickSync H.264)
info: - obs_qsv11_hevc (QuickSync HEVC)
info: - obs_x264 (x264)
info: Audio Encoders:
info: - ffmpeg_aac (FFmpeg AAC)
info: - ffmpeg_opus (FFmpeg Opus)
info: - ffmpeg_pcm_s16le (FFmpeg PCM (16-bit))
info: - ffmpeg_pcm_s24le (FFmpeg PCM (24-bit))
info: - ffmpeg_pcm_f32le (FFmpeg PCM (32-bit float))
info: - ffmpeg_alac (FFmpeg ALAC (24-bit))
info: - ffmpeg_flac (FFmpeg FLAC (16-bit))
info: - libfdk_aac (libfdk AAC)
info: ==== Startup complete ===============================================
info: All scene data cleared
info: ------------------------------------------------
info: pulse-input: Server name: 'PulseAudio (on PipeWire 1.2.7) 15.0.0'
info: pulse-input: Audio format: s16le, 48000 Hz, 2 channels
info: pulse-input: Started recording from 'bluez_output.74_45_CE_B3_36_DF.1.monitor' (default)
info: [Loaded global audio device]: 'Рабочий стол'
info: pulse-input: Audio format: float32le, 48000 Hz, 1 channels
info: pulse-input: Started recording from 'bluez_input.74:45:CE:B3:36:DF' (default)
info: [Loaded global audio device]: 'Микр/доп'
info: PipeWire initialized
info: Switched to scene 'Сцена'
info: Loaded scenes:
info: - scene 'Сцена':
info: - source: 'Захват экрана (PipeWire)' (pipewire-screen-capture-source)
warning: [pipewire] Failed to create session, denied or cancelled by user
info: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Микр/доп)
info: Starting stream due to hotkey
warning: Stream output type 'rtmp_output' failed to start!
Log file:
00:49:58.170: Using EGL/X11
00:49:58.170: CPU Name: Intel(R) Core(TM) i5-10300H CPU @ 2.50GHz
00:49:58.170: CPU Speed: 4390.131MHz
00:49:58.170: Physical Cores: 4, Logical Cores: 8
00:49:58.170: Physical Memory: 15636MB Total, 6573MB Free
00:49:58.170: Kernel Version: Linux 6.12.4-1-MANJARO
00:49:58.170: Distribution: "Manjaro Linux" Unknown
00:49:58.170: Desktop Environment: KDE (KDE)
00:49:58.170: Session Type: x11
00:49:58.170: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
00:49:58.171: Qt Version: 6.8.1 (runtime), 6.8.1 (compiled)
00:49:58.171: Portable mode: false
00:49:58.214: OBS 31.0.0-1 (linux)
00:49:58.214: ---------------------------------
00:49:58.223: ---------------------------------
00:49:58.223: audio settings reset:
00:49:58.223: samples per sec: 48000
00:49:58.223: speakers: 2
00:49:58.223: max buffering: 960 milliseconds
00:49:58.223: buffering type: dynamically increasing
00:49:58.224: ---------------------------------
00:49:58.224: Initializing OpenGL...
00:49:58.280: Loading up OpenGL on adapter Intel Mesa Intel(R) UHD Graphics (CML GT2)
00:49:58.280: OpenGL loaded successfully, version 4.6 (Core Profile) Mesa 24.2.8-arch1.1, shading language 4.60
00:49:58.308: ---------------------------------
00:49:58.308: video settings reset:
00:49:58.308: base resolution: 1920x1080
00:49:58.308: output resolution: 1920x1080
00:49:58.308: downscale filter: Bicubic
00:49:58.308: fps: 60/1
00:49:58.308: format: NV12
00:49:58.308: YUV mode: Rec. 709/Partial
00:49:58.308: NV12 texture support enabled
00:49:58.308: P010 texture support not available
00:49:58.313: Audio monitoring device:
00:49:58.313: name: По умолчанию
00:49:58.313: id: default
00:49:58.313: ---------------------------------
00:49:58.320: Failed to load 'en-US' text for module: 'decklink-captions.so'
00:49:58.326: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
00:49:58.331: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
00:49:58.331: Failed to initialize module 'decklink.so'
00:49:58.455: [pipewire] Available capture sources:
00:49:58.455: [pipewire] - Monitor source
00:49:58.455: [pipewire] - Window source
00:49:58.470: v4l2loopback not installed, virtual camera not registered
00:49:58.525: VAAPI: API version 1.22
00:49:58.525: FFmpeg VAAPI H264 encoding supported
00:49:58.565: FFmpeg VAAPI AV1 encoding not supported
00:49:58.566: FFmpeg VAAPI HEVC encoding supported
00:50:00.537: [obs-nvenc] NVENC version: 12.1 (compiled) / 12.2 (driver), CUDA driver version: 12.40, AV1 supported: false
00:50:00.599: X Error: BadAccess (attempt to access private resource denied), Major opcode: 152, Minor opcode: BadAtom (invalid Atom parameter), Serial: 32
00:50:00.601: X Error: BadAccess (attempt to access private resource denied), Major opcode: 152, Minor opcode: BadAtom (invalid Atom parameter), Serial: 32
00:50:00.641: X Error: BadAccess (attempt to access private resource denied), Major opcode: 152, Minor opcode: BadAtom (invalid Atom parameter), Serial: 32
00:50:00.642: X Error: BadAccess (attempt to access private resource denied), Major opcode: 152, Minor opcode: BadAtom (invalid Atom parameter), Serial: 32
00:50:00.702: ---------------------------------
00:50:00.702: Loaded Modules:
00:50:00.702: text-freetype2.so
00:50:00.702: rtmp-services.so
00:50:00.702: obs-x264.so
00:50:00.702: obs-webrtc.so
00:50:00.702: obs-vst.so
00:50:00.702: obs-transitions.so
00:50:00.702: obs-qsv11.so
00:50:00.702: obs-outputs.so
00:50:00.702: obs-nvenc.so
00:50:00.702: obs-libfdk.so
00:50:00.702: obs-filters.so
00:50:00.702: obs-ffmpeg.so
00:50:00.702: linux-v4l2.so
00:50:00.702: linux-pulseaudio.so
00:50:00.702: linux-pipewire.so
00:50:00.702: linux-jack.so
00:50:00.702: linux-capture.so
00:50:00.702: linux-alsa.so
00:50:00.702: image-source.so
00:50:00.702: frontend-tools.so
00:50:00.702: decklink-output-ui.so
00:50:00.702: decklink-captions.so
00:50:00.702: Available Encoders:
00:50:00.702: Video Encoders:
00:50:00.702: - ffmpeg_svt_av1 (SVT-AV1)
00:50:00.702: - ffmpeg_aom_av1 (AOM AV1)
00:50:00.702: - ffmpeg_vaapi_tex (FFmpeg VAAPI H.264)
00:50:00.702: - hevc_ffmpeg_vaapi_tex (FFmpeg VAAPI HEVC)
00:50:00.702: - obs_nvenc_h264_tex (NVIDIA NVENC H.264)
00:50:00.702: - obs_nvenc_hevc_tex (NVIDIA NVENC HEVC)
00:50:00.702: - obs_qsv11_v2 (QuickSync H.264)
00:50:00.702: - obs_qsv11_hevc (QuickSync HEVC)
00:50:00.702: - obs_x264 (x264)
00:50:00.702: Audio Encoders:
00:50:00.702: - ffmpeg_aac (FFmpeg AAC)
00:50:00.702: - ffmpeg_opus (FFmpeg Opus)
00:50:00.702: - ffmpeg_pcm_s16le (FFmpeg PCM (16-bit))
00:50:00.702: - ffmpeg_pcm_s24le (FFmpeg PCM (24-bit))
00:50:00.702: - ffmpeg_pcm_f32le (FFmpeg PCM (32-bit float))
00:50:00.702: - ffmpeg_alac (FFmpeg ALAC (24-bit))
00:50:00.702: - ffmpeg_flac (FFmpeg FLAC (16-bit))
00:50:00.702: - libfdk_aac (libfdk AAC)
00:50:00.702: ==== Startup complete ===============================================
00:50:00.741: All scene data cleared
00:50:00.741: ------------------------------------------------
00:50:00.745: pulse-input: Server name: 'PulseAudio (on PipeWire 1.2.7) 15.0.0'
00:50:00.745: pulse-input: Audio format: s32le, 48000 Hz, 2 channels
00:50:00.745: pulse-input: Started recording from 'alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Speaker__sink.monitor' (default)
00:50:00.745: [Loaded global audio device]: 'Рабочий стол'
00:50:00.745: pulse-input: Started recording from 'alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Mic1__source' (default)
00:50:00.745: [Loaded global audio device]: 'Микр/доп'
00:50:00.746: PipeWire initialized
00:50:00.752: Switched to scene 'Сцена'
00:50:00.752: ------------------------------------------------
00:50:00.752: Loaded scenes:
00:50:00.752: - scene 'Сцена':
00:50:00.752: - source: 'Захват экрана (PipeWire)' (pipewire-screen-capture-source)
00:50:01.111: [pipewire] Failed to create session, denied or cancelled by user
00:50:01.402: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Рабочий стол)
00:50:01.402:
00:50:03.990: Starting stream due to hotkey
00:50:03.991: Stream output type 'rtmp_output' failed to start!
On Wayland session everything is OK:
info: Platform: Wayland
info: CPU Speed: 4219.444MHz
info: Physical Memory: 15636MB Total, 10560MB Free
info: Session Type: wayland
speakers: 2
info: Using EGL/Wayland
info: Initialized EGL 1.5
fps: 60/1
format: NV12
name: По умолчанию
info: obs-x264.so
info: obs-webrtc.so
info: obs-vst.so
info: obs-qsv11.so
info: obs-nvenc.so
info: obs-libfdk.so
info: obs-ffmpeg.so
info: linux-v4l2.so
info: linux-jack.so
info: linux-alsa.so
info: pulse-input: Audio format: s32le, 48000 Hz, 2 channels
info: pulse-input: Started recording from 'alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Speaker__sink.monitor' (default)
info: pulse-input: Started recording from 'alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Mic1__source' (default)
info: [pipewire] Screencast session created
info: [pipewire] Asking for monitor and window
info: [pipewire] source selected, setting up screencast
info: [pipewire] Server version: 1.2.7
info: [pipewire] Library version: 1.2.7
info: [pipewire] Header version: 1.2.7
info: [pipewire] Created stream 0x61ba77dbacb0
info: [pipewire] Stream 0x61ba77dbacb0 state: "connecting" (error: none)
info: [pipewire] Playing stream 0x61ba77dbacb0
info: [pipewire] Stream 0x61ba77dbacb0 state: "paused" (error: none)
info: [pipewire] Negotiated format:
info: [pipewire] Format: 12 (Spa:Enum:VideoFormat:BGRA)
info: [pipewire] Modifier: 0x0
info: [pipewire] Size: 1920x1036
info: [pipewire] Framerate: 0/1
info: [pipewire] Modifier: 0x100000000000004
info: [pipewire] Stream 0x61ba77dbacb0 state: "streaming" (error: none)
info: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Рабочий стол)
info: adding 21 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Микр/доп)
info: [obs-nvenc: 'simple_video_recording'] Not running on NVIDIA GPU, falling back to non-texture encoder
info: [obs-nvenc: 'simple_video_recording'] settings:
codec: H264
rate_control: CQP
cqp: 23
keyint: 250
preset: p5
tuning: hq
multipass: qres
profile: high
width: 1920
height: 1080
b-frames: 2
b-ref-mode: 0
lookahead: true (8 frames)
aq: true
info: libfdk_aac encoder created
info: libfdk_aac bitrate: 192, channels: 2
info: ==== Recording Start ===============================================
info: [ffmpeg muxer: 'simple_file_output'] Writing file '/home/boris/2025-01-06 00-20-53.mkv'...
info: [ffmpeg muxer: 'simple_file_output'] Output of file '/home/boris/2025-01-06 00-20-53.mkv' stopped
info: Output 'simple_file_output': stopping
info: Output 'simple_file_output': Total frames output: 171
info: Output 'simple_file_output': Total drawn frames: 186
info: ==== Recording Stop ================================================
info: libfdk_aac encoder destroyed
Output of sudo inxi --verbosity=8 --filter --width:
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=7fb0dd4d-7227-42fb-9866-a3d3ad15b246 rw quiet splash
udev.log_priority=3 fsck.mode=force fsck.repair=yes
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 16-a0xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 87AE v: 32.32 serial: <filter> part-nu: 316G9EA#ACB
uuid: 31444335-3031-584c-504e-6c02e09965de UEFI: AMI v: F.30 date: 07/22/2024
ID-1: BAT0 charge: 35.8 Wh (88.6%) condition: 40.4/40.4 Wh (100.0%)
volts: 12.8 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: charging cycles: 51
System RAM: total: 16 GiB available: 15.27 GiB used: 4.85 GiB (31.8%)
igpu: 64 MiB
Device-1: Bottom - Slot 1 (Up) type: DDR4 detail: synchronous size: 8 GiB
speed: spec: 3200 MT/s actual: 2933 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: A-Data
part-no: AO1P32NC8T1-BBVS serial: <filter>
Device-2: Bottom - Slot 2 (down) type: DDR4 detail: synchronous size: 8 GiB
Slot: 0 type: PCIe status: in use info: J6B2 length: long volts: 3.3
bus-ID: 00:01.0 children: 1: 01:00.0 class-ID: 0300 type: display 2: 01:00.1
class-ID: 0403 type: audio
Info: model: Intel Core i5-10300H socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 2
microcode: 0xFC
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4203 min/max: 800/4500 base/boost: 2475/8300 scaling:
driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
cores: 1: 4203 2: 4203 3: 4203 4: 4203 5: 4203 6: 4203 7: 4203 8: 4203
bogomips: 40009
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed
rdtscp rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Hewlett-Packard
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile]
vendor: Hewlett-Packard driver: nvidia v: 550.135
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
Device-3: Quanta HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 0408:5365
class-ID: 0e02
Display: unspecified server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: BOE Display 0x08f6 built: 2019 res: 1920x1080
dpi: 137 gamma: 1.2 chroma: red: x: 0.584 y: 0.345 green: x: 0.333 y: 0.553
blue: x: 0.161 y: 0.129 white: x: 0.314 y: 0.329
size: 355x200mm (13.98x7.87") diag: 407mm (16") ratio: 16:9
modes: 1920x1080
EDID-Warnings: 1: parse_edid: unknown flag 2
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9bc4 memory: 7.46 GiB unified: yes
API: Vulkan v: 1.4.303 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1650 Ti driver: N/A device-ID: 10de:1f95 surfaces: xcb,xlib
device: 1 type: integrated-gpu name: Intel UHD Graphics (CML GT2)
driver: N/A device-ID: 8086:9bc4 surfaces: xcb,xlib
Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0401
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.7 status: n/a (root, process) with:
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
chip-ID: 10ec:c822 class-ID: 0280
IF: wlan0 state: down mac: <filter>
IF-ID-1: enp0s20f0u1 state: unknown speed: -1 duplex: half mac: <filter>
Info: services: iwd, NetworkManager, systemd-networkd, systemd-timesyncd,
wpa_supplicant
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 0bda:b00c
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c010c
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
Local Storage: total: 1.38 TiB used: 309.94 GiB (22.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Ardor Gaming
model: m.2 NVME 512Gb AL1284 size: 476.94 GiB block-size: physical: 512 B
fw-rev: H231106a temp: 39.9 C scheme: GPT
SMART: yes health: PASSED on: 6d 1h cycles: 65
read-units: 19,372,581 [9.91 TB] written-units: 9,916,884 [5.07 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
family: Barracuda 2.5 5400 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5400
serial: <filter> fw-rev: 0001 temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 44d 20h cycles: 3927
read: 2 TiB written: 1.75 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-1: / raw-size: 68.36 GiB size: 66.74 GiB (97.63%) used: 27.16 GiB (40.7%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p4 maj-min: 259:4
label: root_newSSD uuid: 7fb0dd4d-7227-42fb-9866-a3d3ad15b246
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 27.3 MiB (2.7%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 0522-8ED9
ID-3: /home raw-size: 322.63 GiB size: 316.49 GiB (98.10%)
used: 282.75 GiB (89.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6 label: home_newSSD
uuid: 22dc86a4-1861-4c94-beaf-1fef9f1c134d
ID-1: swap-1 type: partition size: 16.6 GiB used: 2.1 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:5 label: swap_newSSD
uuid: d27f4d1a-f0c0-4a72-a9a9-43eb696a66d4
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 68.36 GiB fs: ntfs label: N/A
uuid: 8C36C77636C75FB6
ID-3: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-4: /dev/sda2 maj-min: 8:2 size: 831.5 GiB fs: ntfs label: N/A
uuid: 1E52533052530BC1
ID-5: /dev/sda3 maj-min: 8:3 size: 100 GiB fs: ext4 label: N/A
uuid: 13e91fac-2d52-4c27-9969-a3c2b9bd322c
Device-1: 1-1:5 info: Xiaomi Mi/Redmi series (RNDIS) type: CDC-data
driver: rndis_host interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 2717:ff80 class-ID: 0a00
serial: <filter>
Device-2: 1-6:2 info: Quanta HP TrueVision HD Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0408:5365 class-ID: 0e02
Device-3: 1-7:3 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
System Temperatures: cpu: 41.0 C pch: 48.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Packages: pm: pacman pkgs: 1598 libs: 375 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
2: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
3: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
4: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
5: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
6: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
7: https://mirror.koddos.net/manjaro/stable/$repo/$arch
8: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
9: https://mirrors2.manjaro.org/stable/$repo/$arch
10: https://mirror.easyname.at/manjaro/stable/$repo/$arch
11: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
12: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
13: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
14: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
15: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
16: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
17: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
18: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
19: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
20: https://mirror.init7.net/manjaro/stable/$repo/$arch
21: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
22: https://mirror.dc.uz/manjaro/stable/$repo/$arch
23: https://mirror.zetup.net/manjaro/stable/$repo/$arch
24: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
25: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
26: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
27: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
28: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
29: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
30: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
31: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
32: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
33: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
34: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
35: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
36: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
37: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
38: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
39: http://manjaro.grena.ge/stable/$repo/$arch
40: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
41: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
42: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
43: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
44: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
45: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
46: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
47: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
48: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
49: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
50: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
51: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
52: https://linorg.usp.br/manjaro/stable/$repo/$arch
53: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
54: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
55: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
56: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
57: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
58: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
59: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
60: https://muug.ca/mirror/manjaro/stable/$repo/$arch
61: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
62: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
63: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
64: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
65: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
66: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
67: http://mirror.fcix.net/manjaro/stable/$repo/$arch
68: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
69: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
70: https://mirror.23m.com/manjaro/stable/$repo/$arch
71: http://manjaro.mirror.ac.za/stable/$repo/$arch
72: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
73: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
74: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
75: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
76: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
77: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
78: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
79: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
80: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
81: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
82: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
83: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
84: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
85: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
86: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
87: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
88: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
89: https://manjaro.ynh.ovh/stable/$repo/$arch
90: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
91: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
92: https://mirrors.manjaro.org/repo/stable/$repo/$arch
93: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
94: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
95: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
96: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
97: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
98: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
99: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
100: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
101: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
102: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
103: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
104: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
105: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
106: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
107: https://mirror.funami.tech/manjaro/stable/$repo/$arch
108: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
109: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
110: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
111: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
112: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
113: https://manjaro.kurdy.org/stable/$repo/$arch
114: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
115: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
116: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
117: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
118: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
119: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
120: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
121: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 285
1: cpu: 26.6% command: firefox pid: 12394 mem: 621.3 MiB (3.9%)
2: cpu: 20.2% command: firefox pid: 12631 mem: 835.3 MiB (5.3%)
3: cpu: 4.9% command: firefox pid: 12533 mem: 217.2 MiB (1.3%)
4: cpu: 3.9% command: firefox pid: 12942 mem: 288.4 MiB (1.8%)
5: cpu: 3.6% command: firefox pid: 12638 mem: 234.0 MiB (1.4%)
Memory top: 5 of 285
1: mem: 835.3 MiB (5.3%) command: firefox pid: 12631 cpu: 20.2%
2: mem: 660.9 MiB (4.2%) command: thunderbird pid: 10186 cpu: 2.1%
3: mem: 621.3 MiB (3.9%) command: firefox pid: 12394 cpu: 26.6%
4: mem: 482.7 MiB (3.0%) command: plasmashell pid: 9832 cpu: 1.9%
5: mem: 292.0 MiB (1.8%) command: Xorg pid: 9569 cpu: 1.5%
Processes: 285 Power: uptime: 40m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.08 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
default: Bash v: 5.2.37 running-in: yakuake inxi: 3.3.36
