OBS crashes when selecting a screen / window to capture
During the last or second-to-last snapshot of Manjaro, OBS Studio seems to have been broken and no longer usable for recording and streaming. When I attempt to add a screen capture device (pipewire) OBS crashes once I select either my screen or a window to capture. I tried a fresh OBS config, the moment I add a new screen capture device it crashes again. The only information I get in the console is zsh: trace trap (core dumped) obs. I use KDE / Plasma (Wayland).
Is the issue already known? When is a fix projected if so? Do I need to provide more information at this time?
Output of sudo inxi --verbosity=8 --filter --width as requested:
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=eabe1a99-1671-4b1c-9817-d5855ba9cea3 rw quiet apparmor=1
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: PRIME X370-PRO v: Rev X.0x
    serial: <filter> part-nu: SKU uuid: 37dc1fc0-b07a-11e9-bc64-04d4c44d034d
    UEFI: American Megatrends v: 6232 date: 09/29/2024
  System RAM: total: 32 GiB available: 31.25 GiB used: 11.04 GiB (35.3%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
    data: 64 total: 64 manufacturer: Kingston part-no: KHX3200C16D4/8GX
    serial: <filter>
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
    serial: <filter>
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
    serial: <filter>
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
    serial: <filter>
  Slot: 0 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:03.1
    children: 1: 0a:00.0 class-ID: 0300 type: display 2: 0a:00.1 class-ID: 0403
    type: audio
  Slot: 1 type: PCIe status: available length: long volts: 3.3
    bus-ID: 00:1f.7
  Slot: 2 type: PCIe status: available length: long volts: 3.3
    bus-ID: 00:1f.7
  Slot: 3 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Slot: 4 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Slot: 5 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Info: model: AMD Ryzen 7 3700X socket: AM4 bits: 64 type: MT MCP arch: Zen 2
    gen: 2 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
    desc: 8x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 3758 min/max: 550/4426 boost: enabled
    base/boost: 3600/4400 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 3758 2: 3758 3: 3758 4: 3758
    5: 3758 6: 3758 7: 3758 8: 3758 9: 3758 10: 3758 11: 3758 12: 3758 13: 3758
    14: 3758 15: 3758 16: 3758 bogomips: 115252
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: ASUSTeK driver: amdgpu v: kernel
    arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1
    empty: DP-1,DVI-D-1,DVI-D-2 bus-ID: 0a:00.0 chip-ID: 1002:67df
    class-ID: 0300 temp: 49.0 C
  Device-2: Asuscom Network REDRAGON Live Camera
    driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 5-1:2 chip-ID: 0735:0269 class-ID: 0102 serial: <filter>
  Display: unspecified server: X.Org v: 24.1.4 with: Xwayland v: 24.1.4
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95")
  Monitor-1: HDMI-A-1 model: Samsung LC24RG50 serial: <filter> built: 2021
    res: 1920x1080 hz: 144 dpi: 92 gamma: 1.2 chroma: red: x: 0.643 y: 0.329
    green: x: 0.278 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.278 y: 0.290
    size: 532x304mm (20.94x11.97") diag: 613mm (24.1") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480, 640x480,
    720x400
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 570 Series (radeonsi
    polaris10 LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:67df
    memory: 3.91 GiB unified: no
  API: Vulkan v: 1.4.303 layers: N/A device: 0 type: discrete-gpu name: AMD
    Radeon RX 570 Series (RADV POLARIS10) driver: N/A device-ID: 1002:67df
    surfaces: xcb,xlib
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: ASUSTeK driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:aaf0
    class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Asuscom Network REDRAGON Live Camera
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: n/a (root, process)
    with: pipewire-media-session status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active (root, process) with:
    tools: pacat,pactl
  Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
  IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-13:2 chip-ID: 0b05:190e
  Report: rfkill ID: hci0 rfk-id: 10 state: down bt-service: enabled,running
  Local Storage: total: 5 TiB used: 2.57 TiB (51.4%)
    model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 1B2QEXM7 temp: 43.9 C scheme: GPT
  SMART: yes health: PASSED on: 162d 10h cycles: 2,868
    read-units: 18,098,887 [9.26 TB] written-units: 33,980,022 [17.3 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000VN008-2DR166
    family: IronWolf size: 3.64 TiB block-size: physical: 4096 B logical: 512 B
    sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5980 serial: <filter> fw-rev: SC60
    temp: 25 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 2y 313d 14h cycles: 2664
    read: 21.03 TiB written: 27.65 TiB Pre-Fail: attribute: Spin_Retry_Count
    value: 100 worst: 100 threshold: 97
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
    family: based SSDs size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 4B6Q temp: 29 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 3y 183d 21h cycles: 2807
    written: 55.91 TiB
  ID-1: / raw-size: 461.76 GiB size: 453.44 GiB (98.20%)
    used: 151.85 GiB (33.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: Manjaro uuid: eabe1a99-1671-4b1c-9817-d5855ba9cea3
  ID-2: /archive raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
    used: 2.32 TiB (64.9%) fs: ext4 block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1 label: Archive uuid: e7fc4aee-f26a-4880-8e6a-628abcd50514
  ID-3: /boot/efi raw-size: 4 GiB size: 3.99 GiB (99.80%)
    used: 296 KiB (0.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: 17A0-DD48
  ID-4: /home raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 101.72 GiB (11.1%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
    maj-min: 8:17 label: Home uuid: bf55ce0e-d6cc-49fd-ba02-d14886a418bd
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
  Device-1: 1-13:2 info: ASUSTek ASUS USB-BT500 type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: Asuscom Network REDRAGON Live Camera
    type: video,audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
  Hub-6: 5-2:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2813
  Device-1: 5-2.3:8 info: Razer USA Cobra type: mouse,keyboard
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:00a3 class-ID: 0300
  Device-2: 5-2.4:5 info: Razer USA Ornata V3 X type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0294 class-ID: 0300
  Hub-7: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 50.8 C mobo: N/A gpu: amdgpu temp: 49.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 1124
  Packages: pm: pacman pkgs: 1910 libs: 482 tools: pamac pm: flatpak pkgs: 0
    1: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    2: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    3: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    4: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    7: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    8: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    10: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    12: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    13: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    15: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    18: https://mirror.init7.net/manjaro/stable/$repo/$arch
    19: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    20: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    21: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    22: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    24: https://mirrors2.manjaro.org/stable/$repo/$arch
    25: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    26: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    27: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    28: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    29: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    30: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    31: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    32: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    33: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    34: https://mirrors.manjaro.org/repo/stable/$repo/$arch
Processes:
  CPU top: 5 of 431
  1: cpu: 3.5% command: firefox pid: 271600 mem: 257.7 MiB (0.8%)
  2: cpu: 2.5% command: Discord pid: 86799 mem: 700.2 MiB (2.1%)
  3: cpu: 2.2% command: kwin_wayland pid: 1797 mem: 579.8 MiB (1.8%)
  4: cpu: 1.9% command: plasmashell pid: 2100 mem: 712.1 MiB (2.2%)
  5: cpu: 1.8% command: firefox pid: 261592 mem: 822.5 MiB (2.5%)
  Memory top: 5 of 431
  1: mem: 1466.3 MiB (4.5%) command: telegram-desktop pid: 5667 cpu: 0.2%
  2: mem: 849.8 MiB (2.6%) command: thunderbird pid: 3374 cpu: 0.2%
  3: mem: 822.5 MiB (2.5%) command: firefox pid: 261592 cpu: 1.8%
  4: mem: 756.5 MiB (2.3%) command: dolphin pid: 2863 cpu: 0.0%
  5: mem: 744.3 MiB (2.3%) command: electron pid: 255275 cpu: 1.2%
  Processes: 431 Power: uptime: 4d 7h 7m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 10 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
    default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
Have you already tried different kernels ?
:footprints:
I usually don’t play with those just run the latest stable kernel with LTS / Recommended as a failsafe. If you think it helps I could try booting up kernel 6.6.65-1, as opposed to 6.12.4-1 which I’m running now?
It’s likely related to Pipewire or Wayland I imagine, though without more output I can’t know. I don’t compile OBS myself to debug, everything is from the Manjaro system packages. If anyone else wants to confirm this, it should thus be easy to reproduce and hopefully gather more info than I have the knowledge to, though I’d be surprised if it was something unique to my setup.
You know how it works: Maybe some inxi helps :wink:
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the 3 dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
  1. Or we can try to play hide and seek :wink:
    Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
Google ist dein Freund und übersetzt dir das.
Google est votre ami et le traduira pour vous.
We won’t know if it makes a difference unless you try it. :slight_smile:
You could also try an X11 session to see if the same occurs; this might help determine whether or not it might be strictly Wayland related.
And of course, creating a new User account to test can help determine whether it might be local configuration related.
Thanks: Updated the main post with the output from that command. If that doesn’t help I can try the LTS kernel and an X11 session when I do my next restart and see which if any resolves it.
Booted kernel 6.6.65-1 and the issue persists, I know a kernel after that still worked so it’s likely unrelated. Even on 6.12.4-1 I no longer get the crash on the X11 session of Plasma: Unlike Wayland I need to use a different display capture input, I added one as a test and that records the screen just fine although I can’t even select any specific windows. So the crash is specific to Wayland and using the Pipewire input in OBS.
I tested OBS on various KDE and GNOME distributions on my machine with the following results:
  • When running on X11, the display selector does not open at all.
  • When running on Wayland, selecting a display or window causes the application to crash.
However, It worked fine on a SwayFX-based desktop environment by installing the wlroots OBS plugin.
Thanks for confirming. Can anyone find a bug report for this already open, so I know if I should poke them about it? Sadly I don’t have more data, and likely can’t compile OBS and its plugins myself just to do a GDB trace.
