OBS Crash at Start Recording with NVENC
I get preview using XSHM as source.
I click start and OBS crashes every time.
Started OBS in terminal to see log of OBS activity.
See dl_fn->cuda_dl->cuInit(0) failed → CUDA_ERROR_UNKNOWN: unknown error
I comb internet for hours looking for resolution for this error, but since its a general error I get tons of resolutions that dont work.
Seeming unrelated post to this actual error but click out of desperation
Tried the resolution:
sudo rmmod nvidia_uvm && sudo modprobe nvidia_uvm
Immediately solved the problem.
If someone could explain why I would appreciate it.
Even though my problem was solved I wanted to post it here in case someone else might need it.
You unloaded and loaded again the module.
Which would indicate there was a problem with it in the first place.
If this is required all the time … then there is some issue with the module or it is not starting correctly.
If it is not … then there was simply a problem with that running instance at that time.
Without logs or further information its impossible to know any deeper ‘how’, ‘why’, etc.
What kind of logs are we looking or so I can provide them?
The logs from OBS dont say much. They just end as though it stopped in the middle of normal operation.
