Trying to record on OBS with hardware encoding H264 gives me the error :
An encoder error occurred while recording.
or when i try it with HEVC:
Failed to open NVENC codec: Generic error in an external library
Try installing the latest NVIDIA driver and closing other recording software that might be using NVENC such as NVIDIA ShadowPlay or Windows Game DVR.
However nothing else is recording at the same time. Spectacle’s screen recording doesnt seem to save the file anywhere, even though it does not give me an error. GPU Screen Recorder is working fine though.
Kernel: 6.1.80-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet avail: acpi_pm
root=UUID=f48d994e-c928-4379-8442-a607bddaabd8 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: N/A wm: kwin_wayland
with: latte-dock dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506IH_FA506IH
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FA506IH v: 1.0 serial: <filter>
uuid: a8b88a53-ee0a-8341-8b7e-bc8cd6176cb5 UEFI: American Megatrends
v: FA506IH.316 date: 03/12/2021
ID-1: BAT1 charge: 32.5 Wh (100.0%) condition: 32.5/48.1 Wh (67.7%)
volts: 12.3 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
System RAM: total: 16 GiB available: 15.05 GiB used: 7.42 GiB (49.3%)
(unregistered) size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2
max: 1.2 width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A1K43DB1-CWE serial: <filter>
Info: model: AMD Ryzen 5 4600H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1933 high: 3000 min/max: 1400/3000 boost: enabled
base/boost: 3000/4000 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 3000 2: 1400 3: 3000 4: 1400
5: 1400 6: 3000 7: 1400 8: 1400 9: 3000 10: 1400 11: 1400 12: 1400
bogomips: 71897
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f99 class-ID: 0300
Device-2: AMD Renoir [Radeon RX Vega 6 ] vendor: ASUSTeK driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 60.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 13d3:56a2
Display: server: X.Org v: 23.2.4 with: Xwayland v: 23.2.4
compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: Najing CEC Panda 0x002d built: 2018 res: 1920x1080
hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48") diag: 395mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: radeonsi
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 16.0.6 DRM 3.49 6.1.80-1-MANJARO) device-ID: 1002:1636 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.276 layers: 2 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 550.54.14
device-ID: 10de:1f99 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RENOIR) driver: mesa radv
v: 24.0.2-manjaro1.1 device-ID: 1002:1636 surfaces: xcb,xlib
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.80-1-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off tools: jack_control,qjackctl
Server-3: PipeWire v: 1.0.3 status: n/a (root, process) with:
1: pipewire-pulse status: active 2: pipewire-media-session status: active
3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli
vendor: ASUSTeK RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lite-On driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:c822
class-ID: 0280
Info: services: NetworkManager, nginx, sshd, systemd-timesyncd,
wpa_supplicant
Device-1: Lite-On Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 04ca:4005
Local Storage: total: 942.7 GiB used: 236.61 GiB (25.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD
lanes: 4 tech: SSD serial: <filter> fw-rev: P6MA001 temp: 46.9 C
scheme: GPT
SMART: yes health: PASSED on: 1y 21d 13h cycles: 2,919
read-units: 70,769,076 [36.2 TB] written-units: 54,864,357 [28.0 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
family: Micron Client SSDs size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: M3CR043
temp: 36 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 83d 11h cycles: 711
written: 5.1 TiB
ID-1: / raw-size: 273.44 GiB size: 268.08 GiB (98.04%)
used: 175.36 GiB (65.4%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: N/A uuid: f48d994e-c928-4379-8442-a607bddaabd8
ID-2: /run/media/hydra/ExternalWin raw-size: 97.66 GiB
size: 97.65 GiB (100.00%) used: 26.1 MiB (0.0%) fs: exfat block-size: 512 B
dev: /dev/sda2 maj-min: 8:2 label: ExternalWin uuid: 67FE-BC8E
ID-3: /srv/mmedia raw-size: 368.1 GiB size: 361.26 GiB (98.14%)
used: 61.22 GiB (16.9%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: External-Linux
uuid: 1bcf4134-86d3-4721-9900-4bd126368ed5
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: E465-6F98
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 202.73 GiB fs: ntfs label: N/A
uuid: 648069A180697B06
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 674 MiB fs: ntfs label: N/A
uuid: B69804FD9804BE3D
Device-1: 1-4:2 info: IMC Networks USB2.0 HD UVC WebCam type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Device-1: 3-1:2 info: Lite-On Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 04ca:4005 class-ID: e001 serial: <filter>
Device-1: 4-2:2 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E ASM1153
3Gb/s ASM1153E bridge type: mass storage driver: uas interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 174c:55aa
class-ID: 0806 serial: <filter>
System Temperatures: cpu: 70.6 C mobo: N/A gpu: amdgpu temp: 60.0 C
Fan Speeds (rpm): cpu: 3400
Processes: 364 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.01 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: 2503 pm: pacman pkgs: 2465 libs: 511 tools: octopi,pamac,yay
pm: flatpak pkgs: 38 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Sudo (sudo)
v: 1.9.15p5 default: Bash v: 5.2.26 running-in: yakuake inxi: 3.3.33
