hello, when I try to install the package
virtualbox-guest-dkms
the installer asks me to choose linux-heathers
I’ve tried them all and answer me that
object not found: linux-zen-headers
My kernel is
Linux 5.9.1-1-MANJARO x86_64
Thanks
My kernel is
Thanks
linux-zen is an Arch kernel - unsupported on Manjaro.
uninstall the kernel and try again
sudo pacman -Rns linux-zen
As per @linux-aarhus you’re doing something which you’re not supposed to do so I’m thinking you have an XY Problem so please describe in plain English without using any technical terms what you’re trying to accomplish and then we’ll tell you what to do exactly to resolve your original issue…
